- ddclient
ddclient
Ola pessoal, estou tentando fazer esse script rodar mas nao funciona por nada, segui as instrucoes de instalacao conforme o explicado, to com perl 5.8.XX onde o minimo exigido eh o 5.0.0.4. Configuro o script e coloco ele no /etc/ddclient.conf, coloco o executavel em /usr/bin e o modulo para iniciar em /etc/rc.d/init.d/ddclient.
So que nao esta atualizando meus dados la no dyndns.org. Qdo dou um ps -efa ele aparece sleeping for XXX seconds, esperado o tempo, outro ps resulkta em connecting to members.dyndns.org .... e fica assim pra sempre, estou anexando meu arquivo de configuracao, as vezes configurei algo errado.
Ahhh, estou usando velox....
ddclient.conf
## Define default global variables with lines like:
## var=value [, var=value]*
## These values will be used for each following host unless overridden
## with a local variable definition.
## Define local variables for one or more hosts with:
## var=value [, var=value]* host.and.domain[,host2.and.domain...]
## Lines can be continued on the following line by ending the line
## with a \
daemon=300 # check every 300 seconds
syslog=yes # log update msgs to syslog
mail=root # mail all msgs to root
mail-failure=root # mail failed update msgs to root
pid=/var/run/ddclient.pid # record PID in file.
#use=watchguard-soho, fw=192.168.111.1:80 # via Watchguard´s SOHO FW
#use=netopia-r910, fw=192.168.111.1:80 # via Netopia R910 FW
#use=smc-barricade, fw=192.168.123.254:80 # via SMC´s Barricade FW
#use=netgear-rt3xx, fw=192.168.0.1:80 # via Netgear´s internet FW
#use=linksys, fw=192.168.1.1:80 # via Linksys´s internet FW
#use=maxgate-ugate3x00, fw=192.168.0.1:80 # via MaxGate´s UGATE-3x00 FW
#use=elsa-lancom-dsl10, fw=10.0.0.254:80 # via ELSA LanCom DSL/10 DSL Router
#use=elsa-lancom-dsl10-ch01, fw=10.0.0.254:80 # via ELSA LanCom DSL/10 DSL Router
#use=elsa-lancom-dsl10-ch02, fw=10.0.0.254:80 # via ELSA LanCom DSL/10 DSL Router
#use=alcatel-stp, fw=10.0.0.138:80 # via Alcatel Speed Touch Pro
#use=xsense-aero, fw=192.168.1.1:80 # via Xsense Aero Router
#use=allnet-1298, fw=192.168.1.1:80 # via AllNet 1298 DSL Router
#use=3com-oc-remote812, fw=192.168.0.254:80 # via 3com OfficeConnect Remote 812
#use=e-tech, fw=192.168.1.1:80 # via E-tech Router
#use=cayman-3220h, fw=192.168.0.1:1080 # via Cayman 3220-H DSL Router
#fw-login=admin, fw-password=XXXXXX # FW login and password
## To obtain an IP address from FW status page (using fw-login, fw-password)
#use=fw, fw=192.168.1.254/status.htm, fw-skip=´IP Address´ # found after IP Address
## To obtain an IP address from Web status page (using the proxy if defined)
#use=web, web=checkip.dyndns.org/, web-skip=´IP Address´ # found after IP Address
#use=ip, ip=127.0.0.1 # via static IP´s
use=if, if=eth0 # via interfaces
#use=web # via web
protocol=dyndns2 # default protocol
#proxy=fasthttp.sympatico.ca:80 # default proxy
server=members.dyndns.org # default server
#server=members.dyndns.org:8245 # default server (bypassing proxies)
login=XXXXXXXXXXXXX # default login
password=XXXXXXXXXX # default password
#mx=mx.for.your.host # default MX
#backupmx=yes|no # host is primary MX?
#wildcard=yes|no # add wildcard CNAME?
## dyndns.org dynamic addresses
## (supports variables: wildcard,mx,backupmx)
# server=members.dyndns.org, \
# protocol=dyndns2 \
# vinicius.kicks-ass.net
## dyndns.org static addresses
# static=yes, \
# your-static-host.dyndns.org
## dyndns.org custom addresses
custom=yes, \
protocol=dyndns2 \
## ZoneEdit (zoneedit.com)
# server=www.zoneedit.com, \
# protocol=zoneedit1, \
# login=your-zoneedit-login, \
# password=your-zoneedit-password \
# your.any.domain,your-2nd.any.dom
## EasyDNS (easydns.com)
# server=members.easydns.com, \
# protocol=easydns, \
# login=your-easydns-login, \
# password=your-easydns-password \
# your.any.domain,your-2nd.any.domain
## Hammernode (hn.org) dynamic addresses
# server=dup.hn.org, \
# protocol=hammernode1, \
# login=your-hn-login, \
# password=your-hn-password \
# your-hn-host.hn.org,your-2nd-hn-host.hn.org
## dslreports.com dynamic-host monitoring
# server=members.dslreports.com \
# protocol=dslreports1, \
# login=dslreports-login, \
# password=dslreports-password \
# dslreports-unique-id
## OrgDNS.org account-configuration
#use=web, web=members.orgdns.org/nic/ip
# server=www.orgdns.org \
# login=yourLoginName \
# password=yourPasswort \
# yourSubdomain.orgdns.org
## dnspark.com
## (supports variables: mx, mxpri)
# use=web, web=ipdetect.dnspark.com, web-skip=´Current Address:´
# protocol=dnspark, \
# server=www.dnspark.com, \
# your-host.dnspark.com
