Password:
root ~ # -> cd /cdrom
root /cdrom # -> sh setup.sh
BORLAND KYLIX 3
Checking dependencies...
WARNING: could not locate libX11.so
Kernel version >= 2.2.0....OK
Glibc version >= 2.1.2....OK
X11 Server....OK
Libjpeg version >= 6.2.0....OK
Libgtk version >= 1.2.0....OK
----====== Borland Kylix 3 installation program ======----
You are running a x86 machine with glibc-2.1 or later.
Hit Control-C anytime to cancel this installation program.
BORLAND SOFTWARE CORPORATION
LICENSE TERMS
KYLIX 3 ENTERPRISE
NOTICE: THIS BORLAND SOFTWARE PRODUCT (TOGETHER WITH ITS
ACCOMPANYING DOCUMENTATION, THE "PRODUCT") IS THE PROPERTY
OF BORLAND SOFTWARE CORPORATION ("BORLAND"). THE PRODUCT
IS MADE AVAILABLE TO YOU, THE ORIGINAL PURCHASER, SUBJECT
TO THE FOLLOWING LICENSE AGREEMENT ("LICENSE"). PLEASE
READ THIS LICENSE CAREFULLY BEFORE INSTALLING OR USING THE
PRODUCT. A COPY OF THIS LICENSE IS AVAILABLE FOR YOUR
FUTURE REFERENCE IN THE "LICENSE.TXT" FILE PROVIDED WITH
THE PRODUCT.
YOU MAY ACCEPT THIS LICENSE BY CLICKING ON THE "I AGREE"
BUTTON BELOW. YOU MAY REJECT THIS LICENSE, AND TERMINATE
THIS INSTALLATION PROCESS, BY CLICKING THE "CANCEL" BUTTON
BELOW. IF YOU DO NOT ACCEPT THIS LICENSE, THEN YOU MAY NOT
INSTALL OR USE THE PRODUCT. IN THAT CASE, YOU MAY, WITHIN
TEN (10) DAYS AFTER YOU FIRST RECEIVED THE PRODUCT, RETURN
IT TO BORLAND OR YOUR BORLAND AUTHORIZED RESELLER, ALONG
WITH ITS ORIGINAL PACKAGING AND PROOF-OF-PURCHASE, FOR A
Do you agree with the license? [Y/n] Y
Would you like to read the README file ? [Y/n] n
Please enter the installation path [/usr/local/kylix3] /usr/local/kylix3
Please enter the path in which to create the symbolic links [/usr/local/bin] /us
r/local/bin
Install Main Program Files? [Y/n/?] Y
Install dbExpress (includes InterBase and MySQL drivers)? [Y/n/?] Y
Install dbExpress Oracle Driver? [Y/n/?] Y
Install dbExpress DB2 Driver? [Y/n/?] Y
Install dbExpress Informix Driver? [Y/n/?] Y
Install dbExpress PostgreSQL Driver? [Y/n/?] Y
Install Help Files? [Y/n/?] Y
Install Internet Components? [Y/n/?] Y
Install WebSnap? [Y/n/?] Y
Install Mozilla Preview Widget? [Y/n/?] Y
Install Web Services? [Y/n/?] Y
Install VisiBroker/CORBA Components for Delphi? [N/y/?] N
Do you want to install GNOME/KDE menu items? [Y/n] Y
Installing to /usr/local/kylix3
6762 MB available, 439 MB will be installed.
Continue install? [Y/n] Y
error: failed dependencies:
ld-linux.so.2 is needed by kylix3_main_program_files-1.0-1
libICE.so.6 is needed by kylix3_main_program_files-1.0-1
libSM.so.6 is needed by kylix3_main_program_files-1.0-1
libX11.so.6 is needed by kylix3_main_program_files-1.0-1
libXext.so.6 is needed by kylix3_main_program_files-1.0-1
libc.so.6 is needed by kylix3_main_program_files-1.0-1
libdl.so.2 is needed by kylix3_main_program_files-1.0-1
libjpeg.so.62 is needed by kylix3_main_program_files-1.0-1
libm.so.6 is needed by kylix3_main_program_files-1.0-1
libpthread.so.0 is needed by kylix3_main_program_files-1.0-1
libXpm.so.4 is needed by kylix3_main_program_files-1.0-1
libstdc++-libc6.1-1.so.2 is needed by kylix3_main_program_files-1.0-1
libutil.so.1 is needed by kylix3_main_program_files-1.0-1
libz.so.1 is needed by kylix3_main_program_files-1.0-1
libc.so.6(GLIBC_2.0) is needed by kylix3_main_program_files-1.0-1
libc.so.6(GLIBC_2.1) is needed by kylix3_main_program_files-1.0-1
libdl.so.2(GLIBC_2.0) is needed by kylix3_main_program_files-1.0-1
libdl.so.2(GLIBC_2.1) is needed by kylix3_main_program_files-1.0-1
libm.so.6(GLIBC_2.0) is needed by kylix3_main_program_files-1.0-1
libm.so.6(GLIBC_2.1) is needed by kylix3_main_program_files-1.0-1
libpthread.so.0(GLIBC_2.0) is needed by kylix3_main_program_files-1.0-1
libpthread.so.0(GLIBC_2.1) is needed by kylix3_main_program_files-1.0-1
libutil.so.1(GLIBC_2.0) is needed by kylix3_main_program_files-1.0-1
Unable to install RPM file: 'setup.data/packages/kylix3_main_program_files-1.0-1.i386.rpm'
setup.data/regvers.sh: line 7: /usr/local/kylix3/bin/kylixpath: Arquivo ou diretório não encontrado
cp: impossível fazer stat em `/home/root/.borland/delphi69rc': Arquivo ou diretório não encontrado
cp: impossível fazer stat em `/home/root/.borland/bcb69rc': Arquivo ou diretório não encontrado
cp: impossível fazer stat em `/home/root/.borland/debug69rc': Arquivo ou diretório não encontrado
An error has occurred during installation.
Error Code: -10
Setup cannot continue.
If this error persists, please contact technical support.
Install aborted - cleaning up files
root /cdrom # ->
