olá pessoal
Essa é a primeira vez q estou configurando o postfix e já estou com problemas!!!hehehe
qdo envio um email d uma estacao da rede da uma messagem de erro no outlook de Relay access denied!!!
mas da estacao consigo pingar o smtp.teste.com.br e o pop.teste.com.br
aki está o meu log
Apr 25 23:58:08 laboratorio postfix/postfix-script: warning: /var/spool/postfix/etc/localtime and /etc/localtime differ
Apr 25 23:58:08 laboratorio postfix/postfix-script: starting the Postfix mail system
Apr 25 23:58:08 laboratorio postfix/master[3004]: daemon started
Apr 25 23:02:11 laboratorio postfix/smtpd[3016]: connect from unknown[192.168.0.15]
Apr 25 23:02:11 laboratorio postfix/smtpd[3016]: BA68E11B1C4: client=unknown[192.168.0.15]
Apr 25 23:02:11 laboratorio postfix/smtpd[3016]: reject: RCPT from unknown[192.168.0.15]: 554 <[email protected]>: Recipient address rejected: Relay access denied; from=<[email protected]> to=<[email protected]>
Apr 25 23:02:17 laboratorio postfix/smtpd[3016]: disconnect from unknown[192.168.0.15]
Apr 25 23:03:13 laboratorio postfix/smtpd[3016]: connect from unknown[192.168.0.15]
Apr 25 23:03:13 laboratorio postfix/smtpd[3016]: 0EAA111B1C4: client=unknown[192.168.0.15]
Apr 25 23:03:13 laboratorio postfix/smtpd[3016]: reject: RCPT from unknown[192.168.0.15]: 554 <[email protected]>: Recipient address rejected: Relay access denied; from=<[email protected]> to=<[email protected]>
Apr 25 23:03:18 laboratorio postfix/smtpd[3016]: disconnect from unknown[192.168.0.15]
aki a configuracao do Postfix
command_directory = /usr/sbin
daemon_directory = /usr/libexec/postfix
mail_owner = postfix
default_privs = nobody
myhostname = mail.teste.com.br
mydomain = teste.com.br
mynetworks = 168.168.0.0/24, 127.0.0.0/8
relay_domains = $mydestination
alias_maps = hash:/etc/postfix/aliases
mailbox_command = /usr/bin/procmail
default_transport = smtp
smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
debug_peer_level = 2
debugger_command =
PATH=/usr/bin:/usr/X11R6/bin
xxgdb $daemon_directory/$process_name $process_id & sleep 5
sendmail_path = /usr/sbin/sendmail.postfix
newaliases_path = /usr/bin/newaliases.postfix
mailq_path = /usr/bin/mailq.postfix
setgid_group = postdrop
sample_directory = /usr/share/doc/postfix-1.1.11/samples
readme_directory = /usr/share/doc/postfix-1.1.11/README_FILES
alias_database = hash:/etc/postfix/aliases
aki
o conteudo do arquivo
/etc/postfix/relay
192.168.0 OK
teste.com.br OK
o q estou fazendo d errado???
agradeco desde ja a colaboracao d todos
