Pessoal boa tarde, estou aqui de novo e para variar um pouquinho procurando a ajuda de voces e contando com a paciência em mais um problema.
Seguinte instalei o squid e fiz as configurações .conf. Starto o mesmo e aparentemente esta tudo em ordem, coloquei as configurações de proxy nos navegores (IE) dos clientes e os mesmos não navegam.
Novamente não consigo achar o problema, mas vou colocar as mensagens do log (cache.log) para ver se alguem tem alguma ideia
2005/05/05 17:01:59| Starting Squid Cache version 2.5.STABLE9 for i686-redhat-linux-gnu...
2005/05/05 17:01:59| Process ID 4324
2005/05/05 17:01:59| With 1024 file descriptors available
2005/05/05 17:01:59| DNS Socket created at 0.0.0.0, port 1038, FD 5
2005/05/05 17:01:59| Adding nameserver 200.204.0.10 from /etc/resolv.conf
2005/05/05 17:01:59| Adding nameserver 200.204.0.138 from /etc/resolv.conf
2005/05/05 17:01:59| User-Agent logging is disabled.
2005/05/05 17:01:59| Referer logging is disabled.
2005/05/05 17:01:59| Unlinkd pipe opened on FD 10
2005/05/05 17:01:59| Swap maxSize 102400 KB, estimated 7876 objects
2005/05/05 17:01:59| Target number of buckets: 393
2005/05/05 17:01:59| Using 8192 Store buckets
2005/05/05 17:01:59| Max Mem size: 8192 KB
2005/05/05 17:01:59| Max Swap size: 102400 KB
2005/05/05 17:01:59| Rebuilding storage in /var/spool/squid (DIRTY)
2005/05/05 17:01:59| Using Least Load store dir selection
2005/05/05 17:01:59| Set Current Directory to /var/spool/squid
2005/05/05 17:01:59| Loaded Icons.
2005/05/05 17:02:00| Accepting HTTP connections at 0.0.0.0, port 3128, FD 11.
2005/05/05 17:02:00| Accepting ICP messages at 0.0.0.0, port 3130, FD 12.
2005/05/05 17:02:00| WCCP Disabled.
2005/05/05 17:02:00| Ready to serve requests.
2005/05/05 17:02:01| Done scanning /var/spool/squid swaplog (0 entries)
2005/05/05 17:02:01| Finished rebuilding storage from disk.
2005/05/05 17:02:01| 0 Entries scanned
2005/05/05 17:02:01| 0 Invalid entries.
2005/05/05 17:02:01| 0 With invalid flags.
2005/05/05 17:02:01| 0 Objects loaded.
2005/05/05 17:02:01| 0 Objects expired.
2005/05/05 17:02:01| 0 Objects cancelled.
2005/05/05 17:02:01| 0 Duplicate URLs purged.
2005/05/05 17:02:01| 0 Swapfile clashes avoided.
2005/05/05 17:02:01| Took 2.1 seconds ( 0.0 objects/sec).
2005/05/05 17:02:01| Beginning Validation Procedure
2005/05/05 17:02:01| Completed Validation Procedure
2005/05/05 17:02:01| Validated 0 Entries
2005/05/05 17:02:01| store_swap_size = 0k
2005/05/05 17:02:02| storeLateRelease: released 0 objects
Obrigado.
