Alo..
Tenho este arquivo...
"kdebase-3.4.1.tar.bz2"
Como faço para atualizar o meu sistema KDE., quales passos tenho que fazer.???
O meu sistema KDE e 3.2.3 rolando no conectiva 10.1
Alo..
thanks brother[size=24px][/size]
Ja desempakei o arquivo, ta num diretorio dentro do /home.
Cuando do o "./configure" dentro do mesmo diretorio onde ta o arquivo me sai isto:
[root@ozzy kdebase-3.4.1]# ./configure
checking build system type... i686-pc-linux-gnuoldld
checking host system type... i686-pc-linux-gnuoldld
checking target system type... i686-pc-linux-gnuoldld
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... no
checking for kde-config... /usr/lib/kde3/bin/kde-config
kde-config: Opción desconocida '--libsuffix'.
kde-config: Use --help para obtener una lista de las opciones disponibles en la línea de comandos.
checking where to install... /usr/lib/kde3 (as returned by kde-config)
checking for style of include used by make... none
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
a pergunta minha e... que eu vejo no "CONFIG.LOG"???
ESTE E O DETALHE DO "CONFIG.LOG"
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure
## Platform. ##
hostname = ozzy
uname -m = i686
uname -r = 2.6.5-63077cl
uname -s = Linux
uname -v = #1 Thu Jun 17 21:29:07 BRT 2004
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/lib/kde3/bin
PATH: /sbin
PATH: /usr/sbin
PATH: /bin
PATH: /usr/bin
PATH: /usr/X11R6/bin
PATH: /usr/local/bin
PATH: /usr/bin/X11
PATH: /usr/games
PATH: /usr/lib/java2/bin
PATH: /usr/lib/java2/jre/bin
PATH: /usr/lib/qt3/bin
## Core tests. ##
configure:1586: checking build system type
configure:1604: result: i686-pc-linux-gnuoldld
configure:1612: checking host system type
configure:1626: result: i686-pc-linux-gnuoldld
configure:1634: checking target system type
configure:1648: result: i686-pc-linux-gnuoldld
configure:1695: checking for a BSD-compatible install
configure:1750: result: /usr/bin/install -c
configure:1765: checking for -p flag to install
configure:1778: result: yes
configure:1789: checking whether build environment is sane
configure:1832: result: yes
configure:1884: checking for gawk
configure:1900: found /bin/gawk
configure:1910: result: gawk
configure:1920: checking whether make sets $(MAKE)
configure:1944: result: no
configure:2126: checking for kde-config
configure:2188: result: /usr/lib/kde3/bin/kde-config
configure:2284: checking where to install
configure:2288: result: /usr/lib/kde3 (as returned by kde-config)
configure:2343: checking for style of include used by make
configure:2371: result: none
configure:2519: checking for gcc
configure:2548: result: no
configure:2599: checking for cc
configure:2628: result: no
configure:2641: checking for cc
configure:2687: result: no
configure:2740: checking for cl
configure:2769: result: no
configure:2783: error: no acceptable C compiler found in $PATH
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnuoldld
ac_cv_build_alias=i686-pc-linux-gnuoldld
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnuoldld
ac_cv_host_alias=i686-pc-linux-gnuoldld
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_make_make_set=no
ac_cv_target=i686-pc-linux-gnuoldld
ac_cv_target_alias=i686-pc-linux-gnuoldld
kde_cv_path=/usr/lib/kde3/bin/kde-config
kde_cv_path_kde_config=/usr/lib/kde3/bin/kde-config
## Output variables. ##
ACLOCAL='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run aclocal-1.9'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run tar'
AR=''
ARTSCCONFIG=''
AUTOCONF='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run autoconf'
AUTODIRS=''
AUTOHEADER='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run autoheader'
AUTOMAKE='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run automake-1.9'
AWK='gawk'
CC=''
CCDEPMODE=''
CFLAGS=' '
COMPILE_GL_INFO_FALSE=''
COMPILE_GL_INFO_TRUE=''
CONF_FILES=' $(top_srcdir)/./admin/configure.in.min $(top_srcdir)/configure.in.in $(top_srcdir)/./kappfinder/configure.in.in $(top_srcdir)/./kcontrol/access/configure.in.in $(top_srcdir)/./kcontrol/accessibility/configure.in.in $(top_srcdir)/./kcontrol/crypto/configure.in.in $(top_srcdir)/./kcontrol/energy/configure.in.in $(top_srcdir)/./kcontrol/fonts/configure.in.in $(top_srcdir)/./kcontrol/info/configure.in.bot $(top_srcdir)/./kcontrol/info/configure.in.in $(top_srcdir)/./kcontrol/input/configure.in.bot $(top_srcdir)/./kcontrol/input/configure.in.in $(top_srcdir)/./kcontrol/joystick/configure.in.in $(top_srcdir)/./kcontrol/kfontinst/configure.in.bot $(top_srcdir)/./kcontrol/kfontinst/configure.in.in $(top_srcdir)/./kcontrol/nics/configure.in.in $(top_srcdir)/./kcontrol/randr/configure.in.in $(top_srcdir)/./kcontrol/smartcard/configure.in.in $(top_srcdir)/./kcontrol/usbview/configure.in.in $(top_srcdir)/./kcontrol/view1394/configure.in.in $(top_srcdir)/./kdeprint/configure.in.in $(top_srcdir)/./kdeprint/kprinter/configure.in.in $(top_srcdir)/./kdesktop/configure.in.in $(top_srcdir)/./kdesktop/lock/configure.in.in $(top_srcdir)/./kdesu/configure.in.in $(top_srcdir)/./kdm/configure.in.in $(top_srcdir)/./khotkeys/configure.in.in $(top_srcdir)/./kicker/applets/naughty/configure.in.in $(top_srcdir)/./kicker/extensions/kasbar/configure.in.in $(top_srcdir)/./kioslave/configure.in.bot $(top_srcdir)/./kioslave/configure.in.in $(top_srcdir)/./kioslave/filter/configure.in.in $(top_srcdir)/./kioslave/fish/configure.in.in $(top_srcdir)/./kioslave/ldap/configure.in.in $(top_srcdir)/./kioslave/media/configure.in.in $(top_srcdir)/./kioslave/smb/configure.in.bot $(top_srcdir)/./kioslave/smb/configure.in.in $(top_srcdir)/./kioslave/thumbnail/configure.in.in $(top_srcdir)/./konqueror/preloader/configure.in.in $(top_srcdir)/./konsole/configure.in.in $(top_srcdir)/./ksmserver/configure.in.in $(top_srcdir)/./ksplashml/themeengine/simple/configure.in.in $(top_srcdir)/./ksysguard/configure.in.in $(top_srcdir)/./kwin/kompmgr/configure.in.in $(top_srcdir)/./kxkb/configure.in.in $(top_srcdir)/configure.in.bot'
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DBUSQT_INCS=''
DBUSQT_LIBS=''
DBUS_INCS=''
DBUS_LIBS=''
DCOPIDL2CPP=''
DCOPIDL=''
DCOPIDLNG=''
DCOP_DEPENDENCIES=''
DEFS=''
DEPDIR='.deps'
DOXYGEN=''
DOXYGEN_PROJECT_NAME=''
DOXYGEN_PROJECT_NUMBER=''
DPMSINC=''
DPMSLIB=''
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ENABLE_PERMISSIVE_FLAG=''
EXEEXT=''
EXR_FLAGS=''
F77=''
FFLAGS=''
FRAMEWORK_COREAUDIO=''
GLINC=''
GLLIB=''
GMSGFMT=''
HALBACKEND=''
HAL_INCS=''
HAL_LIBS=''
HAVE_GCC_VISIBILITY=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL} $(INSTALL_STRIP_FLAG)'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
JAR=''
JAVAC=''
JAVAH=''
JVMLIBS=''
KCFG_DEPENDENCIES=''
KCHECKPASS_PAM_SERVICE=''
KCONFIG_COMPILER=''
KDECONFIG='/usr/lib/kde3/bin/kde-config'
KDE_BINDIR=''
KDE_EXTRA_RPATH=''
KDE_HAS_DOXYGEN=''
KDE_HAVE_DOT=''
KDE_INCLUDES=''
KDE_LDFLAGS=''
KDE_MT_LDFLAGS=''
KDE_MT_LIBS=''
KDE_NO_UNDEFINED=''
KDE_PLUGIN=''
KDE_RPATH=''
KDE_USE_CLOSURE_FALSE=''
KDE_USE_CLOSURE_TRUE=''
KDE_USE_FINAL_FALSE=''
KDE_USE_FINAL_TRUE=''
KDE_USE_NMCHECK_FALSE=''
KDE_USE_NMCHECK_TRUE=''
KDE_XSL_STYLESHEET=''
KDM_PAM_SERVICE=''
KRB4_INCS=''
KRB4_LIBS=''
KRB4_RPATH=''
KRB5_INCS=''
KRB5_LIBS=''
KRB5_RPATH=''
KSCREENSAVER_PAM_SERVICE=''
LDAP_INCS=''
LDAP_LIBS=''
LDAP_RPATH=''
LDFLAGS=''
LDFLAGS_AS_NEEDED=''
LDFLAGS_NEW_DTAGS=''
LIBALIB=''
LIBART_CFLAGS=''
LIBART_LIBS=''
LIBART_RPATH=''
LIBBZ2=''
LIBCFG=''
LIBCOMPAT=''
LIBCRYPT=''
LIBCURSES=''
LIBDEVINFO=''
LIBDL=''
LIBFONTCONFIG_CFLAGS=''
LIBFONTCONFIG_LIBS=''
LIBFONTCONFIG_RPATH=''
LIBFREETYPE_CFLAGS=''
LIBFREETYPE_LIBS=''
LIBFREETYPE_RPATH=''
LIBGEN=''
LIBHOSTS=''
LIBJPEG=''
LIBKSTAT=''
LIBMALLOC=''
LIBOBJS=''
LIBODM=''
LIBOSSAUDIO=''
LIBPNG=''
LIBPOSIX4=''
LIBPTHREAD=''
LIBRESOLV=''
LIBRPC=''
LIBS=''
LIBSENSORS=''
LIBSHADOW=''
LIBSM=''
LIBSOCKET=''
LIBSSL=''
LIBTOOL=''
LIBUCB=''
LIBUSBCONFIG=''
LIBUTEMPTER=''
LIBUTIL=''
LIBXDMCP=''
LIBXFT_LIB=''
LIBZ=''
LIB_EXR=''
LIB_FONT_ENC=''
LIB_KAB=''
LIB_KABC=''
LIB_KDECORE=''
LIB_KDEPIM=''
LIB_KDEPRINT=''
LIB_KDEUI=''
LIB_KDNSSD=''
LIB_KFILE=''
LIB_KFM=''
LIB_KHTML=''
LIB_KIMPROXY=''
LIB_KIO=''
LIB_KJS=''
LIB_KNEWSTUFF=''
LIB_KPARTS=''
LIB_KSPELL=''
LIB_KSYCOCA=''
LIB_KUTILS=''
LIB_KVM=''
LIB_LIBS=''
LIB_POLL=''
LIB_QPE=''
LIB_QT=''
LIB_SMB=''
LIB_TRU64_MACH=''
LIB_X11=''
LIB_XCURSOR=''
LIB_XEXT=''
LIB_XF86MISC=''
LIB_XINERAMA=''
LIB_XRANDR=''
LIB_XRENDER=''
LIB_XSS=''
LINUXCDPOLLING=''
LN_S=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/ozzy/install/kdebase-3.4.1/admin/missing --run makeinfo'
MAKEKDEWIDGETS=''
MCOPIDL=''
MD5SUM=''
MD5SUM_CUT=''
MEINPROC=''
MOC=''
MSGFMT=''
NOOPT_CFLAGS=''
NOOPT_CXXFLAGS=''
OBJEXT=''
PACKAGE='kdebase'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PAMLIBS=''
PASSWDLIBS=''
PATH_SEPARATOR=':'
PERL=''
PKG_CONFIG=''
QTDOCDIR=''
QTE_NORTTI=''
QT_INCLUDES=''
QT_LDFLAGS=''
RANLIB=''
RUN_KAPPFINDER=''
SASL2_LIBS=''
SETUIDFLAGS=''
SET_MAKE='MAKE=make'
SHELL='/bin/sh'
SMBCLIENT_EXTRA_LIBS=''
SSL_INCLUDES=''
SSL_LDFLAGS=''
STRIP=''
TOPSUBDIRS=''
UIC=''
UIC_TR=''
UNAME=''
USB_CFLAGS=''
USB_LIBS=''
USER_INCLUDES=''
USER_LDFLAGS=''
USE_EXCEPTIONS=''
USE_RTTI=''
USE_THREADS=''
VERSION='3.4.1'
WOVERLOADED_VIRTUAL=''
XGETTEXT=''
XMLLINT=''
XTESTLIB=''
X_EXTRA_LIBS=''
X_INCLUDES=''
X_LDFLAGS=''
X_PRE_LIBS=''
X_RPATH=''
ac_ct_AR=''
ac_ct_CC=''
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
all_includes=''
all_libraries=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include='#'
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
applnk_SUBDIR_included_FALSE=''
applnk_SUBDIR_included_TRUE=''
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnuoldld'
build_alias=''
build_cpu='i686'
build_os='linux-gnuoldld'
build_vendor='pc'
datadir='${prefix}/share'
doc_SUBDIR_included_FALSE=''
doc_SUBDIR_included_TRUE=''
drkonqi_SUBDIR_included_FALSE=''
drkonqi_SUBDIR_included_TRUE=''
exec_prefix='NONE'
have_xcursor_FALSE=''
have_xcursor_TRUE=''
host='i686-pc-linux-gnuoldld'
host_alias=''
host_cpu='i686'
host_os='linux-gnuoldld'
host_vendor='pc'
include_ARTS_FALSE=''
include_ARTS_TRUE=''
include_BZIP2_FALSE=''
include_BZIP2_TRUE=''
include_EXR_MODULES_FALSE=''
include_EXR_MODULES_TRUE=''
include_fontinst_tn_FALSE=''
include_fontinst_tn_TRUE=''
include_kcontrol_access_FALSE=''
include_kcontrol_access_TRUE=''
include_kcontrol_accessibility_FALSE=''
include_kcontrol_accessibility_TRUE=''
include_kcontrol_joystick_FALSE=''
include_kcontrol_joystick_TRUE=''
include_kcontrol_kfontinst_FALSE=''
include_kcontrol_kfontinst_TRUE=''
include_kcontrol_randr_FALSE=''
include_kcontrol_randr_TRUE=''
include_kcontrol_smartcard_FALSE=''
include_kcontrol_smartcard_TRUE=''
include_kcontrol_usbview_FALSE=''
include_kcontrol_usbview_TRUE=''
include_kcontrol_view1394_FALSE=''
include_kcontrol_view1394_TRUE=''
include_kioslave_ldap_FALSE=''
include_kioslave_ldap_TRUE=''
include_kioslave_smb_FALSE=''
include_kioslave_smb_TRUE=''
include_kompmgr_FALSE=''
include_kompmgr_TRUE=''
include_ksysguardd_FALSE=''
include_ksysguardd_TRUE=''
include_ksysguardd_freebsd_FALSE=''
include_ksysguardd_freebsd_TRUE=''
include_ksysguardd_irix_FALSE=''
include_ksysguardd_irix_TRUE=''
include_ksysguardd_linux_FALSE=''
include_ksysguardd_linux_TRUE=''
include_ksysguardd_netbsd_FALSE=''
include_ksysguardd_netbsd_TRUE=''
include_ksysguardd_openbsd_FALSE=''
include_ksysguardd_openbsd_TRUE=''
include_ksysguardd_solaris_FALSE=''
include_ksysguardd_solaris_TRUE=''
include_ksysguardd_tru64_FALSE=''
include_ksysguardd_tru64_TRUE=''
include_media_halbackend_FALSE=''
include_media_halbackend_TRUE=''
include_media_linuxcdpolling_FALSE=''
include_media_linuxcdpolling_TRUE=''
include_x11_FALSE=''
include_x11_TRUE=''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/home/ozzy/install/kdebase-3.4.1/admin/install-sh'
jni_includes=''
kappfinder_SUBDIR_included_FALSE=''
kappfinder_SUBDIR_included_TRUE=''
kate_SUBDIR_included_FALSE=''
kate_SUBDIR_included_TRUE=''
kcheckpass_SUBDIR_included_FALSE=''
kcheckpass_SUBDIR_included_TRUE=''
kcminit_SUBDIR_included_FALSE=''
kcminit_SUBDIR_included_TRUE=''
kcontrol_SUBDIR_included_FALSE=''
kcontrol_SUBDIR_included_TRUE=''
kdcop_SUBDIR_included_FALSE=''
kdcop_SUBDIR_included_TRUE=''
kde_appsdir=''
kde_bindir=''
kde_confdir=''
kde_datadir=''
kde_htmldir=''
kde_icondir=''
kde_includes=''
kde_kcfgdir=''
kde_libraries=''
kde_libs_htmldir='/usr/lib/kde3/share/doc/HTML'
kde_libs_prefix='/usr/lib/kde3'
kde_locale=''
kde_mimedir=''
kde_moduledir=''
kde_qtver=''
kde_servicesdir=''
kde_servicetypesdir=''
kde_sounddir=''
kde_styledir=''
kde_templatesdir=''
kde_wallpaperdir=''
kde_widgetdir=''
kdebugdialog_SUBDIR_included_FALSE=''
kdebugdialog_SUBDIR_included_TRUE=''
kdeinitdir=''
kdepasswd_SUBDIR_included_FALSE=''
kdepasswd_SUBDIR_included_TRUE=''
kdeprint_SUBDIR_included_FALSE=''
kdeprint_SUBDIR_included_TRUE=''
kdesktop_SUBDIR_included_FALSE=''
kdesktop_SUBDIR_included_TRUE=''
kdesu_SUBDIR_included_FALSE=''
kdesu_SUBDIR_included_TRUE=''
kdialog_SUBDIR_included_FALSE=''
kdialog_SUBDIR_included_TRUE=''
kdm_SUBDIR_included_FALSE=''
kdm_SUBDIR_included_TRUE=''
kdmlib_SUBDIR_included_FALSE=''
kdmlib_SUBDIR_included_TRUE=''
kfind_SUBDIR_included_FALSE=''
kfind_SUBDIR_included_TRUE=''
khelpcenter_SUBDIR_included_FALSE=''
khelpcenter_SUBDIR_included_TRUE=''
khotkeys_SUBDIR_included_FALSE=''
khotkeys_SUBDIR_included_TRUE=''
kicker_SUBDIR_included_FALSE=''
kicker_SUBDIR_included_TRUE=''
kioslave_SUBDIR_included_FALSE=''
kioslave_SUBDIR_included_TRUE=''
klipper_SUBDIR_included_FALSE=''
klipper_SUBDIR_included_TRUE=''
kmenuedit_SUBDIR_included_FALSE=''
kmenuedit_SUBDIR_included_TRUE=''
knetattach_SUBDIR_included_FALSE=''
knetattach_SUBDIR_included_TRUE=''
konqueror_SUBDIR_included_FALSE=''
konqueror_SUBDIR_included_TRUE=''
konsole_SUBDIR_included_FALSE=''
konsole_SUBDIR_included_TRUE=''
kpager_SUBDIR_included_FALSE=''
kpager_SUBDIR_included_TRUE=''
kpersonalizer_SUBDIR_included_FALSE=''
kpersonalizer_SUBDIR_included_TRUE=''
kreadconfig_SUBDIR_included_FALSE=''
kreadconfig_SUBDIR_included_TRUE=''
kscreensaver_SUBDIR_included_FALSE=''
kscreensaver_SUBDIR_included_TRUE=''
ksmserver_SUBDIR_included_FALSE=''
ksmserver_SUBDIR_included_TRUE=''
ksplashml_SUBDIR_included_FALSE=''
ksplashml_SUBDIR_included_TRUE=''
kstart_SUBDIR_included_FALSE=''
kstart_SUBDIR_included_TRUE=''
ksysguard_SUBDIR_included_FALSE=''
ksysguard_SUBDIR_included_TRUE=''
ksystraycmd_SUBDIR_included_FALSE=''
ksystraycmd_SUBDIR_included_TRUE=''
ktip_SUBDIR_included_FALSE=''
ktip_SUBDIR_included_TRUE=''
kwin_SUBDIR_included_FALSE=''
kwin_SUBDIR_included_TRUE=''
kxkb_SUBDIR_included_FALSE=''
kxkb_SUBDIR_included_TRUE=''
l10n_SUBDIR_included_FALSE=''
l10n_SUBDIR_included_TRUE=''
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
libkonq_SUBDIR_included_FALSE=''
libkonq_SUBDIR_included_TRUE=''
localstatedir='${prefix}/var'
mandir='${prefix}/man'
mkdir_p='mkdir -p --'
nogroup=''
nsplugins_SUBDIR_included_FALSE=''
nsplugins_SUBDIR_included_TRUE=''
oldincludedir='/usr/include'
pics_SUBDIR_included_FALSE=''
pics_SUBDIR_included_TRUE=''
program_transform_name='s,x,x,'
qt_includes=''
qt_libraries=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
supports_i8k_FALSE=''
supports_i8k_TRUE=''
sysconfdir='${prefix}/etc'
target='i686-pc-linux-gnuoldld'
target_alias=''
target_cpu='i686'
target_os='linux-gnuoldld'
target_vendor='pc'
unsermake_enable_pch_FALSE=''
unsermake_enable_pch_TRUE=''
x_includes='NONE'
x_libraries='NONE'
xdg_appsdir=''
xdg_directorydir=''
xdg_menudir=''
## confdefs.h. ##
#define PACKAGE "kdebase"
#define PACKAGE_BUGREPORT ""
#define PACKAGE_NAME ""
#define PACKAGE_STRING ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define VERSION "3.4.1"
configure: exit 1
Código :checking where to install... /usr/lib/kde3 (as returned by kde-config) checking for style of include used by make... none checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable C compiler found in $PATH See `config.log' for more details. [root@ozzy kdebase-3.4.1]#
Vc tem gcc? Se tiver verifique se ele está na variável $PATH.
# echo $PATH
nao tenho.
Então demoro pra vc instalar. Sem o compilador C não vai ter como mesmo.Postado originalmente por michigan
