Pessoal, estou compilando o net-snmp para configurar o Nagios.
Quando faço o ./configure OK. Termina sem problemas
Quando faço o make apresenta o erro abaixo.
Como resolver ?
# make
gcc -E -Iinclude -I./include -I./agent/mibgroup -I. -I. -DDONT_INC_STRUCTS -DBINDIR=/usr/local/bin -x c ./sedscript.in | egrep '^s[/#]' | sed 's/REMOVEME//g;s# */#/#g;s/ *#/#/g;s#/ *#/#g;s/# g/#g/;' > sedscript
echo 's#DATADIR#/usr/local/share#g' >> sedscript
echo 's#LIBDIR#/usr/local/lib#g' >> sedscript
echo 's#BINDIR#/usr/local/bin#g' >> sedscript
echo 's#PERSISTENT_DIRECTORY#/var/net-snmp#g' >> sedscript
echo 's#SYSCONFDIR#/usr/local/etc#g' >> sedscript
/usr/bin/sed -f sedscript ./EXAMPLE.conf.def > EXAMPLE.conf
making all in /usr/local/src/net-snmp-5.3.1/snmplib
make[1]: Entrando no diretório `/usr/local/src/net-snmp-5.3.1/snmplib'
/bin/sh ../libtool --mode=compile gcc -I../include -I. -I../snmplib -g -O2 -Dlinux -I/usr/include/rpm -c -o snmp_client.lo snmp_client.c
mkdir .libs
gcc -I../include -I. -I../snmplib -g -O2 -Dlinux -I/usr/include/rpm -c snmp_client.c -fPIC -DPIC -o .libs/snmp_client.lo
In file included from /usr/include/bits/errno.h:25,
from /usr/include/errno.h:36,
from snmp_client.c:45:
/usr/include/linux/errno.h:4:23: asm/errno.h: No such file or directory
snmp_client.c: In function `snmp_synch_response_cb':
snmp_client.c:1018: error: `EINTR' undeclared (first use in this function)
snmp_client.c:1018: error: (Each undeclared identifier is reported only once
snmp_client.c:1018: error: for each function it appears in.)
snmp_client.c: In function `snmp_sess_synch_response':
snmp_client.c:1097: error: `EINTR' undeclared (first use in this function)
make[1]: ** [snmp_client.lo] Erro 1
make[1]: Saindo do diretório `/usr/local/src/net-snmp-5.3.1/snmplib'
make: ** [subdirs] Erro 1
