ioperm error: Operation not permitted
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0xB79618FB
Function=(null)
Library=/usr/java/j2sdk1.4.2_04/jre/lib/i386/libparport.so
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at parport.ParallelPort.readOneByte(Native Method)
at parport.ParallelPort.read(ParallelPort.java:19)
at Oxilab.RecebeValorParalela(Oxilab.java:2314)
at Oxilab$6.mouseClicked(Oxilab.java:578)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:212)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:211)
at java.awt.Component.processMouseEvent(Component.java:5103)
at java.awt.Component.processEvent(Component.java:4897)
at java.awt.Container.processEvent(Container.java:1569)
at java.awt.Component.dispatchEventImpl(Component.java:3615)
at java.awt.Container.dispatchEventImpl(Container.java:1627)
at java.awt.Component.dispatchEvent(Component.java:3477)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:3483)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3207)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3128)
at java.awt.Container.dispatchEventImpl(Container.java:1613)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:456)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:145)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:137)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:100)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:07 121943 /usr/java/j2sdk1.4.2_04/bin/java
0804e000-0804f000 rwxp 00005000 03:07 121943 /usr/java/j2sdk1.4.2_04/bin/java
0804f000-08322000 rwxp 0804f000 00:00 0 [heap]
aa8c1000-aa8dc000 r-xp 00000000 03:07 123088 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libdcpr.so
aa8dc000-aa8ef000 rwxp 0001a000 03:07 123088 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libdcpr.so
aa970000-aa9a7000 r-xp 00000000 03:07 123099 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libjpeg.so
aa9a7000-aa9a8000 rwxp 00036000 03:07 123099 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libjpeg.so
aac2d000-aac2f000 r-xp 00000000 03:07 687 /usr/lib/gconv/ISO8859-15.so
aac2f000-aac31000 rwxp 00001000 03:07 687 /usr/lib/gconv/ISO8859-15.so
aac31000-aac37000 r-xs 00000000 03:07 773 /usr/lib/gconv/gconv-modules.cache
aac57000-aac75000 r-xp 00000000 03:07 26715 /usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2
aac75000-aac77000 rwxp 0001e000 03:07 26715 /usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2
aac77000-aac7f000 r-xp 00000000 03:07 26782 /usr/X11R6/lib/libXrender.so.1.2.2
aac7f000-aac80000 rwxp 00007000 03:07 26782 /usr/X11R6/lib/libXrender.so.1.2.2
aac80000-aac89000 r-xp 00000000 03:07 26752 /usr/X11R6/lib/libXcursor.so.1.0.2
aac89000-aac8a000 rwxp 00008000 03:07 26752 /usr/X11R6/lib/libXcursor.so.1.0.2
aac94000-aac9f000 rwxs 00000000 00:07 1146887 /SYSV00000000 (deleted)
aac9f000-aaca1000 r-xp 00000000 03:07 26716 /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
aaca1000-aaca2000 rwxp 00001000 03:07 26716 /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
aaca2000-aad5c000 r-xp 00000000 03:07 123090 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libfontmanager.so
aad5c000-aad76000 rwxp 000b9000 03:07 123090 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libfontmanager.so
aad77000-aadde000 r-xs 00000000 03:07 123749 /home/softwares/eclipse/workspace/oxilabIII/mysql-connector-java-3.1.10-bin.jar
aadde000-aadf5000 r-xp 00000000 03:07 26730 /usr/X11R6/lib/libICE.so.6.4
aadf5000-aadf6000 rwxp 00016000 03:07 26730 /usr/X11R6/lib/libICE.so.6.4
aadf8000-aae00000 r-xp 00000000 03:07 26734 /usr/X11R6/lib/libSM.so.6.0
aae00000-aae01000 rwxp 00008000 03:07 26734 /usr/X11R6/lib/libSM.so.6.0
aae01000-aaed7000 r-xp 00000000 03:07 26736 /usr/X11R6/lib/libX11.so.6.2
aaed7000-aaedb000 rwxp 000d6000 03:07 26736 /usr/X11R6/lib/libX11.so.6.2
aaedb000-aaeea000 r-xp 00000000 03:07 26760 /usr/X11R6/lib/libXext.so.6.4
aaeea000-aaeeb000 rwxp 0000e000 03:07 26760 /usr/X11R6/lib/libXext.so.6.4
aaeeb000-aaf3f000 r-xp 00000000 03:07 26786 /usr/X11R6/lib/libXt.so.6.0
aaf3f000-aaf42000 rwxp 00054000 03:07 26786 /usr/X11R6/lib/libXt.so.6.0
aaf43000-aaf96000 r-xp 00000000 03:07 123103 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libmlib_image.so
aaf96000-aaf97000 rwxp 00052000 03:07 123103 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libmlib_image.so
aaf97000-ab262000 r-xp 00000000 03:07 123086 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libawt.so
ab262000-ab278000 rwxp 002ca000 03:07 123086 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libawt.so
ab4a1000-ab4cd000 r-xp 00000000 03:07 26288 /usr/share/locale/ISO-8859-15/LC_CTYPE
b577b000-b5837000 r-xs 00000000 03:07 123027 /usr/java/j2sdk1.4.2_04/jre/lib/ext/localedata.jar
b5837000-b583d000 r-xs 00000000 03:07 123752 /usr/java/j2sdk1.4.2_04/jre/lib/ext/jcl.jar
b583d000-b5877000 r-xs 00000000 03:07 123760 /usr/java/j2sdk1.4.2_04/jre/lib/ext/mysql-connector-java-3.0.16-ga-bin.jar
b5877000-b5884000 r-xs 00000000 03:07 123037 /usr/java/j2sdk1.4.2_04/jre/lib/ext/ldapsec.jar
b5884000-b58a0000 r-xs 00000000 03:07 123039 /usr/java/j2sdk1.4.2_04/jre/lib/ext/sunjce_provider.jar
b58a0000-b58bd000 r-xs 00000000 03:07 121032 /usr/java/j2sdk1.4.2_04/jre/lib/ext/comm.jar
b58bd000-b58be000 r-xs 00000000 03:07 131550 /usr/java/j2sdk1.4.2_04/jre/lib/ext/ParallelPort.jar
b58be000-b58bf000 r-xs 00000000 03:07 123761 /usr/java/j2sdk1.4.2_04/jre/lib/ext/SerialMRS.jar
b58bf000-b58c2000 r-xs 00000000 03:07 123036 /usr/java/j2sdk1.4.2_04/jre/lib/ext/dnsns.jar
b58c2000-b5e1b000 r-xs 00000000 03:07 123130 /usr/java/j2sdk1.4.2_04/jre/lib/charsets.jar
b5e1b000-b5e2c000 r-xs 00000000 03:07 123129 /usr/java/j2sdk1.4.2_04/jre/lib/jce.jar
b5e2c000-b5f07000 r-xs 00000000 03:07 123174 /usr/java/j2sdk1.4.2_04/jre/lib/jsse.jar
b5f07000-b5f1d000 r-xs 00000000 03:07 123181 /usr/java/j2sdk1.4.2_04/jre/lib/sunrsasign.jar
b5f67000-b7907000 r-xs 00000000 03:07 123614 /usr/java/j2sdk1.4.2_04/jre/lib/rt.jar
b7907000-b791b000 r-xp 00000000 03:07 123109 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libzip.so
b791b000-b791e000 rwxp 00013000 03:07 123109 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libzip.so
b791e000-b793e000 r-xp 00000000 03:07 123094 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libjava.so
b793e000-b7940000 rwxp 0001f000 03:07 123094 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libjava.so
b7940000-b7950000 r-xp 00000000 03:07 123108 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libverify.so
b7950000-b7952000 rwxp 0000f000 03:07 123108 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libverify.so
b7952000-b7956000 rwxs 00000000 03:07 129126 /tmp/hsperfdata_rafael/3909
b7956000-b795f000 r-xp 00000000 03:07 500 /lib/libnss_files-2.3.5.so
b795f000-b7961000 rwxp 00008000 03:07 500 /lib/libnss_files-2.3.5.so
b7961000-b7962000 r-xp 00000000 03:07 131513 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libparport.so
b7962000-b7963000 rwxp 00000000 03:07 131513 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libparport.so
b7963000-b7967000 r-xp 00000000 03:07 26762 /usr/X11R6/lib/libXfixes.so.3.0
b7967000-b7968000 rwxp 00003000 03:07 26762 /usr/X11R6/lib/libXfixes.so.3.0
b7968000-b796d000 r-xp 00000000 03:07 26788 /usr/X11R6/lib/libXtst.so.6.1
b796d000-b796e000 rwxp 00004000 03:07 26788 /usr/X11R6/lib/libXtst.so.6.1
b796e000-b7975000 r-xp 00000000 03:07 26778 /usr/X11R6/lib/libXp.so.6.2
b7975000-b7976000 rwxp 00006000 03:07 26778 /usr/X11R6/lib/libXp.so.6.2
b7976000-b797e000 r-xp 00000000 03:07 123111 /usr/java/j2sdk1.4.2_04/jre/lib/i386/native_threads/libhpi.so
b797e000-b797f000 rwxp 00007000 03:07 123111 /usr/java/j2sdk1.4.2_04/jre/lib/i386/native_threads/libhpi.so
b797f000-b79a2000 r-xp 00000000 03:07 523 /lib/tls/libm-2.3.5.so
b79a2000-b79a4000 rwxp 00022000 03:07 523 /lib/tls/libm-2.3.5.so
b79a4000-b79b4000 r-xp 00000000 03:07 484 /lib/libnsl-2.3.5.so
b79b4000-b79b6000 rwxp 0000f000 03:07 484 /lib/libnsl-2.3.5.so
b79b8000-b7db3000 r-xp 00000000 03:07 123083 /usr/java/j2sdk1.4.2_04/jre/lib/i386/client/libjvm.so
b7db3000-b7dce000 rwxp 003fa000 03:07 123083 /usr/java/j2sdk1.4.2_04/jre/lib/i386/client/libjvm.so
b7de2000-b7f0b000 r-xp 00000000 03:07 521 /lib/tls/libc-2.3.5.so
b7f0b000-b7f0c000 r-xp 00128000 03:07 521 /lib/tls/libc-2.3.5.so
b7f0c000-b7f0f000 rwxp 00129000 03:07 521 /lib/tls/libc-2.3.5.so
b7f11000-b7f13000 r-xp 00000000 03:07 480 /lib/libdl-2.3.5.so
b7f13000-b7f15000 rwxp 00001000 03:07 480 /lib/libdl-2.3.5.so
b7f15000-b7f23000 r-xp 00000000 03:07 525 /lib/tls/libpthread-0.10.so
b7f23000-b7f25000 rwxp 0000d000 03:07 525 /lib/tls/libpthread-0.10.so
b7f27000-b7f29000 r-xp 00000000 03:07 121363 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libSerialMRS.so
b7f29000-b7f2a000 rwxp 00001000 03:07 121363 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libSerialMRS.so
b7f2a000-b7f3a000 r-xp 00000000 03:07 123105 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libnet.so
b7f3a000-b7f3b000 rwxp 0000f000 03:07 123105 /usr/java/j2sdk1.4.2_04/jre/lib/i386/libnet.so
b7f3b000-b7f3c000 r-xs 00000000 03:07 128161 /home/softwares/eclipse/workspace/oxilabIII/SerialMRS.jar
b7f3d000-b7f52000 r-xp 00000000 03:07 467 /lib/ld-2.3.5.so
b7f52000-b7f53000 r-xp 00014000 03:07 467 /lib/ld-2.3.5.so
b7f53000-b7f54000 rwxp 00015000 03:07 467 /lib/ld-2.3.5.so
bfb3d000-bfb52000 rwxp bfb3d000 00:00 0 [stack]
ffffe000-fffff000 ---p 00000000 00:00 0 [vdso]
Heap at VM Abort:
Heap
def new generation total 576K, used 438K [0xab6d0000, 0xab770000, 0xabbb0000)
eden space 512K, 73% used [0xab6d0000, 0xab72d958, 0xab750000)
from space 64K, 100% used [0xab750000, 0xab760000, 0xab760000)
to space 64K, 0% used [0xab760000, 0xab760000, 0xab770000)
tenured generation total 2572K, used 1921K [0xabbb0000, 0xabe33000, 0xaf6d0000)
the space 2572K, 74% used [0xabbb0000, 0xabd907f8, 0xabd90800, 0xabe33000)
compacting perm gen total 5120K, used 5113K [0xaf6d0000, 0xafbd0000, 0xb36d0000)
the space 5120K, 99% used [0xaf6d0000, 0xafbce4f0, 0xafbce600, 0xafbd0000)
Local Time = Tue Aug 15 09:56:12 2006
Elapsed Time = 14
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
# An error report file has been saved as hs_err_pid3909.log.
# Please refer to the file for further information.
