# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
myhostname = doido.coringa.br
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = $myorigin, localhost.$myorigin, , localhost
relayhost =
mynetworks = 127.0.0.0/8
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
##Anti-SPAM##
#disable_vrfy_command = yes
#strict_rfc821_envelopes = yes
#smtpd_hard_error_limit = 1 #acusa erro no relay test
#bounce_queue_lifetime = 2d
#maximal_queue_lifetime = 2d
#smtpd_helo_required = yes
##SASL##
smtpd_sasl_auth_enable = yes
broken_sasl_auth_clients = yes
smtpd_sasl_security_options = noanonymous
##TLS##
smtpd_tls_auth_only = no
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/smtpd.key
smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.crt
smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
#smtp_use_tls = yes
##AMAVIS##
content_filter=smtp-amavis:[127.0.0.1]:10024
smtpd_client_restrictions = permit_mynetworks,
permit_sasl_authenticated,
reject_unknown_client_hostname
smtpd_helo_restrictions= permit_mynetworks,
reject_invalid_helo_hostname,
reject_non_fqdn_helo_hostname,
reject_unknown_helo_hostname
smtpd_sender_restrictions = permit_sasl_authenticated,
reject_non_fqdn_sender,
reject_unknown_sender_domain,
reject_unlisted_sender,
reject_authenticated_sender_login_mismatch,
smtpd_recipient_restrictions = permit_mynetworks,
reject_unauth_destination,
reject_non_fqdn_recipient,
reject_unknown_recipient_domain,
check_policy_service inet:127.0.0.1:60000
