Postado originalmente por
minelli
What's new in 3.11:
*) fixed bug - in some cases web proxy https with parent-proxy did not work;
*) added default-route-distance setting for DHCP client;
*) mesh protocol - bridge interface in a mesh did not work well, fixed;
*) multicast - fixed bootstrap router (BSR) mechanism;
*) user manager - users can now be redirected to HotSpot login page after
PayPal payment;
*) added ability to dst. nat only address or port, not both at the same time;
*) ospf - fixed default route;
*) ipsec - fixed tunnel mode with dynamically generated policy;
*) port remote-access - fixed allowed-addresses check;
*) ethernet half duplex modes on rb400 series work now;
*) console - fixed entering of IPv6 prefixes;
*) console - fixed crash on window size change;
*) console - bit operations (& ^ | << >>) now work with numbers, too;
*) console - brace syntax for array declarations ( { value ; value ; value } )
now can be used also where () expressions can be used, previously
worked only inside the expressions. Example:
:foreach i in {1;2;3;4} do={
ut $i}
*) console - inside expressions ',' operator can be used to concatenate arrays,
unlike '.' which works with strings. Arguments that are not arrays are
treated like arrays with single element. Example:
{1,2,3;4,5,6;7,8,9} produces value {{1;2;3};{4;5;6};{7;8;9}}
(1,{2},{{3;4}},5,{},{6,7},8) produces value {1;2;{3;4};5;{6;7},8}
*) console - 'move' commands no allow list of source items to be empty and
to contain duplicate items. The porpose is to simplify scripts that use
'find' commands to move items. Example:
move ([find dynamic],[find inactive]) - moves all 'dynamic' and
'inactive' items to the end of the list, does not raise error if
any item is both 'dynamic' and 'inactive', or if there are no items;
*) console - 'move' command does not update item numbers anymore;
