    Padrão Página de Aviso com PPPoE + FreeRadius
    Olá pessoal ,
    Estou tentando colocar uma pagina de aviso para os usuários bloqueados no radius usando o parametro "Filter-Id"
    Colocando o parametro "Filter-Id" no radius , o Mk cria duas dinamicas em
    /ip firewall filter , mas não estou conseguindo redirecionar o trafego da porta 80 para o servidor web externo que vai conter a página de aviso.
    Alguem já fez essa configuração ?
    INSERT INTO `radcheck` VALUES (1,'machado','Password','==','machado');
    INSERT INTO `radgroupcheck` VALUES (1,'128','Simultaneous-Use',':=','1');
    INSERT INTO `radgroupcheck` VALUES (2,'128burst','Simultaneous-Use',':=','1');
    INSERT INTO `radgroupreply` VALUES (1,'128','Mikrotik-Rate-Limit',':=','128k/128k',0);
    INSERT INTO `radgroupreply` VALUES (2,'128','Framed-Pool',':=','ipreal',0);
    INSERT INTO `radgroupreply` VALUES (5,'128burst','Mikrotik-Rate-Limit',':=','128k/128k 256k/256k 200k/200k 180/180',0);
    INSERT INTO `radgroupreply` VALUES (6,'128burst','Framed-Pool',':=','ipreal',0);
    INSERT INTO `radgroupreply` VALUES (7,"block", "Mikrotik-Rate-Limit", ":=", "64k/64k",0);
    INSERT INTO `radgroupreply` VALUES (7,"block", "Filter-Id", ":=", "bloqueado",0);
    INSERT INTO `usergroup` VALUES (1,'machado','block');
    Filter-Id - firewall filter chain name. It is used to make a dynamic firewall rule. Firewall chain name can have suffix .in or .out, that will install rule only for incoming or outgoing traffic. Multiple Filter-id can be provided, but only last ones for incoming and outgoing is used. For PPPs - filter rules in ppp chain that will jump to the specified chain, if a packet has come to/from the client (that means that you should first create a ppp chain and make jump rules that would put actual traffic to this chain). The same applies for HotSpot, but the rules will be created in hotspot chain
Nome:	         mk.JPG
Visualizações:	483
Tamanho: 	74,2 KB
    Estas regras de redirecionamento tem que estarem em /ip firewall nat
    Amigo,
    tente testar as regras pelo terminal do Mikrotik, e verá que são da mesma forma.
    []'s
    Ola amigo, como ta sua configuração Radius??
    Citação Postado originalmente por aka2005 Ver Post
    O radius está todo configurado num servidor FreeBSD ,
    estou é com dificuldade para conseguir fazer as regras no Mikrotik.
    Ja está autenticando , e criando duas regras dinamicas ( JUMP com JUMP-TARGET ) , só não estou conseguindo redirecionaro trafego web para aonde desejo !
    As regras dinamicas são criadas em :
    /ip firewall filter
    e o recirect deve ser em :
    /ip firewall nat
    Não sou especialista em MK , trabalho com desenvolvimento de sistema , então to quebrando a cabeça !
    Padrão Faz com Pool
    Cria um Pool no MK, "Bloqueado" e redireciona todo esse pool pra um ip de bloqueio e cria um filtro, bloqueando todo o range de ip do pool e só libera a porta 80... Com radius é mamata....
