PCQ - Parâmetros e Exemplos.
Usage:
PCQ was introduced to optimize massive QoS systems, where most of the queues are exactly the same for different sub-streams. For example a sub-stream can be download or upload for one particular client (IP) or connection to server.
PCQ algorithm is very simple - at first it uses selected classifiers to distinguish one sub-stream from another, then applies individual FIFO queue size and limitation on every sub-stream (witch is exactly the same for every sub-stream), then group all sub-streams together and apply global FIFO queue size and limitation
PCQ parameters:
http://wiki.mikrotik.com/images/thum...px-PCQ_Alg.png
- pcq-classifier (dst-address | dst-port | src-address | src-port; default: "") : selection of sub-stream identifiers
- pcq-rate (number) : maximal available data rate of each sub-steam
- pcq-limit (number) : queue size of one sub-stream in packets
- pcq-total-limit (number) : queue size of global FIFO queue
So instead of having 100 queues with 1000kbps limitation for download we can have one PCQ queue with 100 sub-streams
Classification Examples:
To better understand classification we will take a list of 18 packet streams from specific address and port, to a specific address and port. Then we will choose a classifier and divide all 18 packet streams into PCQ sub-streams
http://wiki.mikrotik.com/images/thum...Q_Example1.png
http://wiki.mikrotik.com/images/thum...Q_Example2.png
PCQ Rate Examples:
Here it is possible to see what happens if PCQ-rate is, or isn't specified. I must noted that if both limits (pcq-rate and max-limit) are unspecified, queue behavior can be imprecise. So it is strongly suggested to have at least one of these options set.
http://wiki.mikrotik.com/images/thum...500px-PCQ3.png
http://wiki.mikrotik.com/images/thum...500px-PCQ4.png
