E o seguinte aqui na empresa nao tenho o firewall rodando ainda, estou apenas com o squid, estou bloqueando tudo pelo squid, estou bloqueando o msn (messenger) mas quando eu bloqueio ele o hotmail e automaticamente bloqueado tambem, descobri que o que estava bloqueando e a login.live.com, preciso bloquear o msn e liberar o email hotmail?
grato
o script do squid esta ai:
# WELCOME TO SQUID 3.0.STABLE10
################# Autenticação de Usuários ##########################
#auth_param basic program <uncomment and complete this line>
#auth_param basic children 5
#auth_param basic realm Squid proxy-caching web server
#auth_param basic credentialsttl 2 hours
#acl password proxy_auth REQUIRED//Qdo for usar a autent. descomentar
acl localhost src 127.0.0.1/32
#acl localnet src 10.0.0.0/8 # RFC1918 possible internal network
#acl localnet src 172.16.0.0/12 # RFC1918 possible internal network
acl redetoctao src 192.168.0.0/24 # RFC1918 possible internal network
##################### Regras ########################################
acl Safe_ports port 20 # programa oi
acl SSL_ports port 443 563 # https
acl Safe_ports port 553 # Autenticacao do outlook
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 89 # juridico 2ccago
acl IPliberados src "/etc/squid/regras/IPliberado.txt"
acl libera-msn src "/etc/squid/regras/libera-msn.txt"
acl bloqueados url_regex -i "/etc/squid/regras/bloqueados.txt"
acl ultrasurf dstdom_regex -i ([0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}($|:.+|/))
acl msn url_regex -i gateway.dll
acl msn_bloq dstdomain "/etc/squid/regras/msn_bloq.txt"
acl msn1 url_regex passport.com confi.messenger.msn.com
acl msn2 req_mime_type ^application/x-msn-messenger$
acl CONNECT method CONNECT
http_access deny manager
http_access deny !Safe_ports
####################### Permisões das Regras ########################
http_access allow IPliberados
http_access deny bloqueados
http_access deny CONNECT ultrasurf
http_access allow libera-msn
http_access deny msn !libera-msn
http_access deny msn_bloq !libera-msn
http_access deny msn1 !libera-msn
http_access deny msn2 !libera-msn
http_access allow redetoctao
http_access allow localhost
http_access deny all
icp_access allow redetoctao
icp_access deny all
htcp_access allow redetoctao
htcp_access deny all
############### Endereço do Servidor e Porta para Acesso############
http_port 192.168.0.204:3128
hierarchy_stoplist cgi-bin ?
######################## Tamanhos das Cache ########################
cache_dir ufs /var/cache/squid 500 16 256
cache_swap_low 90
cache_swap_high 95
########################### Caminhos dos Logs ######################
access_log /var/log/squid/access.log squid
cache_log /var/log/squid/cache.log
cache_store_log /var/log/squid/store.log
#######################Controle de Acessos #########################
refresh_pattern (cgi-bin|\?) 0 0% 0
refresh_pattern . 0 20% 4320
icp_port 3230
coredump_dir /var/cache/squid
