/ip address add address=201.xxx.xxx.xxx/29 interface=ether2
# interface pppoe-client ------------------------------------------------
/interface pppoe-client add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 dial-on-demand=no disabled=no interface=ether3 max-mru=1480 max-mtu=1480 mrru=disabled name=ether3adsl password=pass profile=default service-name="" use-peer-dns=no user=user
/interface pppoe-client add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 dial-on-demand=no disabled=no interface=ether4 max-mru=1480 max-mtu=1480 mrru=disabled name=ether4adsl password=pass profile=default service-name="" use-peer-dns=no user=user
/interface pppoe-client add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 dial-on-demand=no disabled=no interface=ether5 max-mru=1480 max-mtu=1480 mrru=disabled name=ether5adsl password=pass profile=default service-name="" use-peer-dns=no user=user
# ip dns ----------------------------------------------------------------
/ip dns set primary-dns=192.168.0.1
/ip dns set secondary-dns=201.10.128.3
/ip dns static add address=192.168.0.1 comment="" disabled=no name=192.168.0.1.dns.com.br ttl=1d
# ip firewall Filter-----------------------------------------------------
/ip firewall filter add action=accept chain=input disabled=no in-interface=!ether2 src-address=192.168.0.1/24
# ip firewall nat--------------------------------------------------------
/ip firewall nat add action=masquerade chain=srcnat disabled=no out-interface=ether2
/ip firewall nat add action=masquerade chain=srcnat disabled=no out-interface=ether3adsl
/ip firewall nat add action=masquerade chain=srcnat disabled=no out-interface=ether4adsl
/ip firewall nat add action=masquerade chain=srcnat disabled=no out-interface=ether5adsl
# ip firewall mangle-----------------------------------------------------
/ip firewall mangle add action=accept chain=prerouting comment="HTTPS FORA DO LOADBALACED" disabled=no protocol=tcp dst-port=443 in-interface=ether1
/ip firewall mangle add action=accept chain=prerouting comment="FORA DO LOADBALACED" disabled=no dst-address-list=loopback in-interface=ether1
/ip firewall mangle add action=change-ttl chain=forward comment="Filtro Tracert / Traceroute" disabled=no new-ttl=set:30 protocol=icmp
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no in-interface=ether2 new-connection-mark=ether2_conn passthrough=yes
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no in-interface=ether3adsl new-connection-mark=ether3adsl_conn passthrough=yes
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no in-interface=ether4adsl new-connection-mark=ether4adsl_conn passthrough=yes
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no in-interface=ether5adsl new-connection-mark=ether5adsl_conn passthrough=yes
/ip firewall mangle add action=mark-routing chain=output connection-mark=ether2_conn disabled=no new-routing-mark=to_ether2 passthrough=yes
/ip firewall mangle add action=mark-routing chain=output connection-mark=ether3adsl_conn disabled=no new-routing-mark=to_ether3adsl passthrough=yes
/ip firewall mangle add action=mark-routing chain=output connection-mark=ether4adsl_conn disabled=no new-routing-mark=to_ether4adsl passthrough=yes
/ip firewall mangle add action=mark-routing chain=output connection-mark=ether5adsl_conn disabled=no new-routing-mark=to_ether5adsl passthrough=yes
/ip firewall mangle add action=accept chain=prerouting disabled=no dst-address=xxx.xxx.xxx.xxx/29 in-interface=ether1
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=ether1 new-connection-mark=ether2_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:5/0
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=ether1 new-connection-mark=ether3adsl_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:5/1
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=ether1 new-connection-mark=ether4adsl_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:5/2
/ip firewall mangle add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=ether1 new-connection-mark=ether5adsl_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:5/3
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=ether2_conn disabled=no in-interface=ether1 new-routing-mark=to_ether2 passthrough=yes
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=ether3adsl_conn disabled=no in-interface=ether1 new-routing-mark=to_ether3adsl passthrough=yes
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=ether4adsl_conn disabled=no in-interface=ether1 new-routing-mark=to_ether4adsl passthrough=yes
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=ether5adsl_conn disabled=no in-interface=ether1 new-routing-mark=to_ether5adsl passthrough=yes
# ip route---------------------------------------------------------------
/ip route add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=xxx.xx.xxx.xxx routing-mark=to_ether2 comment="Link1"
/ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether3adsl routing-mark=to_ether3adsl comment="Link2"
/ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether4adsl routing-mark=to_ether4adsl comment="Link3"
/ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether5adsl routing-mark=to_ether5adsl comment="Link4"
/ip route add check-gateway=ping comment="Link1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=201.xxx.xxx.xxx scope=30 target-scope=10
/ip route add comment="Link2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=ether3adsl scope=30 target-scope=10
/ip route add comment="Link3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=ether4adsl scope=30 target-scope=10
/ip route add comment="Link4" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=ether5adsl scope=30 target-scope=10
# ip firewall address-list-----------------------------------------------
/ip firewall address-list add address=200.155.80.0-200.155.255.255 comment=BRADESCO disabled=no list=loopback
/ip firewall address-list add address=200.220.186.0/24 comment=BRADESCO disabled=no list=loopback
/ip firewall address-list add address=200.220.178.0/24 comment=BRADESCO disabled=no list=loopback
/ip firewall address-list add address=64.38.29.0/24 comment=RapidShare disabled=no list=loopback
/ip firewall address-list add address=208.69.32.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=208.67.217.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=201.7.178.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=201.7.176.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=200.159.128.0/24 comment=BRADESCO disabled=no list=loopback
/ip firewall address-list add address=201.7.176.0/20 comment="Vídeos - Globo" disabled=no list=loopback
/ip firewall address-list add address=208.84.247.0/24 comment="Vídeos - terratv" disabled=no list=loopback
/ip firewall address-list add address=200.154.56.0/24 comment="Vídeos - terratv" disabled=no list=loopback
/ip firewall address-list add address=200.201.160.0/24 comment="Caixa Economica Federal" disabled=no list=loopback
/ip firewall address-list add address=200.201.166.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=200.201.173.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=200.201.174.0/24 comment="" disabled=no list=loopback
/ip firewall address-list add address=200.141.207.3 comment=Detran disabled=no list=loopback
