Boa noite pessoal.
Estou apanhando do squid 3.2.13.
O arquivo de conf da versao 2.6 não funciona de jeito nenhum.
Entao resolvi realizar a configuração apartir do exemplo mesmo.
Resolvi começar simples e depois ir adicionando mais funcionalidades.
A topologia é a seguinte:
A maquina onde o squid esta instalado tem 2 interfaces de rede, cada uma em uma subnet diferente (8/24).
Esta maquina tb faz o compartilhamento do link.
Tentei criar apenas 1 acl e deixa-la como deny, mas o bloqueio nao funciona nem a pau.
Segue:
# Recommended minimum configuration:
# Example rule allowing access from your local networks.
# Adapt to list your (internal) IP networks from where browsing
# should be allowed
acl localnet src 192.168.0.0/24
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl CONNECT method CONNECT
# Recommended minimum Access Permission configuration:
# Only allow cachemgr access from localhost
http_access allow localhost manager
http_access deny manager
# Deny requests to certain unsafe ports
http_access deny !Safe_ports
# Deny CONNECT to other than secure SSL ports
# We strongly recommend the following be uncommented to protect innocent
# web applications running on the proxy server who think the only
# one who can access services on "localhost" is a local user
http_access deny to_localhost
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# Adapt localnet in the ACL section to list your (internal) IP networks
# from where browsing should be allowed
http_access deny localnet
http_access deny localhost
#http_access deny localnet
# And finally deny all other access to this proxy
http_access deny all
# Squid normally listens to port 3128
http_port 3128 transparent
# Uncomment and adjust the following to add a disk cache directory.
cache_dir ufs /var/spool/squid 100 16 256
# Leave coredumps in the first cache dir
coredump_dir /var/spool/squid
# Add any of your own refresh_pattern entries above these.
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern . 0 20% 4320
Nao vejo como pode ser mais simples que isso ... o problema é que mesmo depois de reiniciar o servico, o bloqueio nao é efetuado.
alguma dica ??
