ALGUEM POR AI SABE MIM INFORMAR COMO CONFIGURA UM CISCO AIRONET 4800
VIA HIPER TERMINAL COM1 OU VIA RJ45 .
Cisco AP4800E V8.65 Main Menu RNODFAE1AP01
Option Value Description
1 - Privilege [ off ] - Set console privilege level
2 - Help - Introduction
Enter an option number or name
ai depois entrei na segunda 1 opção
> 0:25:33 E Unable to locate IP address 010.111.194.001
0:25:41 S No response from DHCP server
Enter one of [off, readonly, write] :
Enter one of [off, readonly, write] : write
Enter a password :
ai pediu password aonde digitei "admin, password e recovery" e nada de senha da certo
como fazer para reset e configura esse radio Cisco ap4800
qual comando preciso para configura e reset
na segunda op 2
Cisco AP4800E V8.65 HELP RNODFAE1AP01
Menu choices are displayed as a number followed by a name, a
current value and a short description. The text "menu" instead
of a value indicates the existence of a sub-menu for that choice.
To select an item you type its number, or enough characters of
its name to be unique, followed by a <CR>.
If the selection is a sub-menu, the new menu will be displayed.
Otherwise a command will start to prompt for its arguments. Each argument
prompt will display a list of valid choices. With fixed string arguments
you need only type the first unique characters. Finish each argument
by typing a <CR>.
Some commands with a limited argument choice (ie on/off) will cycle through
the choices rather than prompting.
Certain keys perform special operations:
<BS> - Delete the last character
<DEL> - Delete all characters
<ESC> - Menu : return to parent menu; Command : cancel
"=" - return to the main menu,
<SPACE> - complete the word being typed (disabled by quoting (") it),
<CR> - terminates data input
Hit any key to continue ...
sera que alguem mim ajuda
