    Padrão O que significa essas mensagens no syslog?
    Olá pessoal!
    O meu server está caindo constatemente, e está aparecendo estas mensagens no syslog:
    Dec 14 10:00:04 server last message repeated 4 times
    Dec 14 10:01:44 server last message repeated 11 times
    Dec 14 10:02:40 server last message repeated 10 times
    Dec 14 10:03:46 server last message repeated 14 times
    Dec 14 10:03:55 server last message repeated 5 times
    Dec 14 10:04:05 server kernel: NET: 2 messages suppressed.
    Dec 14 10:04:05 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:04:06 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:04:10 server kernel: NET: 1 messages suppressed.
    Dec 14 10:04:10 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:04:43 server kernel: NET: 1 messages suppressed.
    Dec 14 10:04:43 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:04:54 server last message repeated 3 times
    Dec 14 10:06:09 server last message repeated 4 times
    Dec 14 10:07:16 server last message repeated 9 times
    Dec 14 10:08:14 server last message repeated 9 times
    Dec 14 10:09:09 server last message repeated 4 times
    Dec 14 10:10:03 server last message repeated 6 times
    Dec 14 10:11:15 server last message repeated 20 times
    Dec 14 10:11:17 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:11:23 server kernel: NET: 2 messages suppressed.
    Dec 14 10:11:23 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:12:04 server kernel: NET: 2 messages suppressed.
    Dec 14 10:12:04 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:12:11 server last message repeated 8 times
    Dec 14 10:12:15 server kernel: NET: 4 messages suppressed.
    Dec 14 10:12:15 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:12:23 server last message repeated 2 times
    Dec 14 10:12:29 server kernel: NET: 1 messages suppressed.
    Dec 14 10:12:29 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:12:33 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:12:40 server kernel: NET: 1 messages suppressed.
    Dec 14 10:12:40 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:12:48 server kernel: NET: 1 messages suppressed.
    Dec 14 10:12:48 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 10:13:03 server last message repeated 4 times
    Dec 14 10:13:07 server kernel: NET: 1 messages suppressed.
    Dec 14 11:01:06 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:01:35 server last message repeated 3 times
    Dec 14 11:09:56 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:11:12 server last message repeated 8 times
    Dec 14 11:12:09 server last message repeated 9 times
    Dec 14 11:12:34 server last message repeated 2 times
    Dec 14 11:14:14 server last message repeated 7 times
    Dec 14 11:15:16 server last message repeated 16 times
    Dec 14 11:15:45 server last message repeated 3 times
    Dec 14 11:17:12 server last message repeated 9 times
    Dec 14 11:18:15 server last message repeated 14 times
    Dec 14 11:19:16 server last message repeated 10 times
    Dec 14 11:20:16 server last message repeated 9 times
    Dec 14 11:21:13 server last message repeated 7 times
    Dec 14 11:22:07 server last message repeated 13 times
    Dec 14 11:23:16 server last message repeated 9 times
    Dec 14 11:23:54 server last message repeated 9 times
    Dec 14 11:25:07 server last message repeated 17 times
    Dec 14 11:25:13 server kernel: NET: 4 messages suppressed.
    Dec 14 11:25:13 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:25:29 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:26:40 server last message repeated 2 times
    Dec 14 11:27:21 server last message repeated 5 times
    Dec 14 11:29:21 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:29:49 server last message repeated 14 times
    Dec 14 11:29:51 server kernel: NET: 10 messages suppressed.
    Dec 14 11:29:51 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:29:56 server kernel: NET: 6 messages suppressed.
    Dec 14 11:29:56 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:05 server kernel: NET: 5 messages suppressed.
    Dec 14 11:30:05 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:07 server kernel: NET: 4 messages suppressed.
    Dec 14 11:30:07 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:14 server kernel: NET: 2 messages suppressed.
    Dec 14 11:30:14 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:21 server kernel: NET: 2 messages suppressed.
    Dec 14 11:30:21 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:22 server kernel: NET: 1 messages suppressed.
    Dec 14 11:30:22 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:26 server kernel: NET: 5 messages suppressed.
    Dec 14 11:30:26 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:38 server kernel: NET: 2 messages suppressed.
    Dec 14 11:30:38 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:39 server kernel: ipt_unclean: UDP zero destination port
    Dec 14 11:30:43 server kernel: NET: 2 messages suppressed.
    Obrigado a todos pela atenção!!!!
    cara...
    experimenta colocar estas regras... e.. sendo a primeira de cada tabela
    Código :
    # iptables -t filter -A INPUT -m state --state INVALID -j DROP
    # iptables -t filter -A FORWARD -m state --state INVALID -j DROP
    outra coisa.. funcionando ou não, poste o resultado depois.
    valeu
    Obrigado pela ajuda, mas não funcionou.
    São mensagens normal do sistema cara...
    Você está utilizando o módulo unclean do iptables?
    Então, ele está informando sobre os pacotes que forma classificados como maliciosos... ai no caso um pacote UDP com destino a porta 0... Parece que estão enviando muitas...
    Citação Postado originalmente por PEdroArthurJEdi Ver Post
    Estou usando o módulo unclen, somente com está regra:
    iptables -A FORWARD -m unclean -j DROP
    Mas antes não aparecia tantas mensagens. Existe alguma regra para travar esses pacotes UDP zerado?
    Estou tendo algumas quedas no server!
    eu já tive esse problema, mas não estou encontrando a regra que usei pra poder parar com estar mensagens... nem no oráculo estou encontrando... parece que não existem mais as referências nele...
    experimentar colocar:
    Código :
    iptables -t filter -I FORWARD -p udp -m udp --dport 0 -j DROP
    Citação Postado originalmente por Submundo Ver Post
    Cara, o módulo enclean é experimental... Não tem muita vantagem em usa-lo... é muito melhor investir em regras baseadas em estados e tomar como política padrão DROP.
