  1. Bom pessoal... sou novo no ramo de servidores mikrotik
    Estou configurando um PC com routerOS 2.9.27 para testes
    fiz passo a passo como descrito no video porém... arquivos em cache nao vem full.. vem limitados a velocidades definidas na simple queue..
    vou mandar as configurações para vcs verem o q fiz errado
    CODE:
    SIMPLE QUEUE
    0 name="Tiago" target-addresses=192.168.0.62/32 dst-address=0.0.0.0/0
    interface=Local parent=none direction=both priority=8
    queue=default/default limit-at=0/0 max-limit=128000/128000
    total-queue=default-small
    1 D name="<hotspot1>" dst-address=0.0.0.0/0 interface=Local parent=none
    direction=both priority=8 queue=hotspot-default/hotspot-default
    limit-at=0/0 max-limit=0/0 total-queue=default-small
    TREE QUEUE
    0 name="squid" parent=global-out packet-mark=squid-packet-HIT limit-at=0
    queue=ethernet-default priority=8 max-limit=1000000 burst-limit=0
    burst-threshold=0 burst-time=0s
    1 name="hotspot" parent=global-out packet-mark=hotspot limit-at=0
    queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0
    burst-time=0s
    NAT
    0 chain=srcnat out-interface=Internet src-address=192.168.0.0/26
    action=masquerade
    1 ;;; web proxy
    chain=dstnat src-address=192.168.0.0/26 protocol=tcp dst-port=80
    action=redirect to-ports=3128
    MANGLE
    0 chain=output protocol=tcp src-port=3128 content=X-Cache: HIT
    action=mark-connection new-connection-mark=squid-connection-HIT
    passthrough=yes
    1 chain=output connection-mark=squid-connection-HIT action=mark-packet
    new-packet-mark=squid-packet-HIT passthrough=yes
    2 chain=output out-interface=Local protocol=udp src-port=64872
    action=mark-connection new-connection-mark=hotspot-out passthrough=yes
    3 chain=output out-interface=Local protocol=tcp src-port=64872
    4 chain=output out-interface=Local protocol=tcp src-port=64873
    5 chain=output out-interface=Local protocol=tcp src-port=64874
    6 chain=output out-interface=Local protocol=tcp src-port=64875
    web proxy
    enabled: yes
    src-address: 0.0.0.0
    port: 3128
    hostname: "proxy"
    transparent-proxy: yes
    parent-proxy: 0.0.0.0:0
    cache-administrator: "webmaster"
    max-object-size: 4096KiB
    cache-drive: system
    max-cache-size: 10000000KiB
    max-ram-cache-size: unlimited
    status: running
    reserved-for-cache: 9999360KiB
    reserved-for-ram-cache: 162816KiB
    conto com a ajuda de vcs.. abraços!!!
  2. Tava apanhando para por em pratica e não funcionava no hotspot.....segui a recomendação do amigo que me indicou e ta foncionando perfeitamente.....só videos do youtube que falha de vez em quando
  3. agora a noite que a maioria dos usuarios esta on line tive varias reclamações de clientes e tive que desabilitar o cache full. Acho que tem alguma coisa a ver com hotspot. Alguem poderia me dar uma mãozinha, se da certo com hotspot ou não?
  4. Tenho o hotspot funcionando com cache full (controlado) e não tenho problemas. O que faço é desmarcar a opção de Transparent Proxy.
  5. Citação Postado originalmente por Raniel Ver Post
    Raniel como vc faz o dhcp ip fixo .. static only ou addres pool e o controle de banda vc faz em cima dos perfis do hotspot no nome de usuario e senha com quees dinamicas ou seta as quess simples staticas amarrando o ip ao mac ..e desmarcando o proxy transparente como fica a situação dos programas MSN EMULE Por exemplo obrigado
  1. Cache full no Mikrotik
    Por Pauloneto no fórum Redes
    Respostas: 6
    Último Post: 22-01-2011, 11:26
  2. Cache-full no Mikrotik
    Por alexandrecorrea no fórum Redes
    Respostas: 10
    Último Post: 23-08-2009, 18:44
  3. Problema com cache full no mikrotik
    Por adenilso no fórum Redes
    Respostas: 6
    Último Post: 27-07-2009, 17:09
  4. Bruno.cache full no mikrotik?
    Por richardson no fórum Servidores de Rede
    Último Post: 01-07-2008, 01:50
  5. Cache full no mikrotik 3.9 impossível?
    Por Atus no fórum Redes
    Respostas: 7
    Último Post: 12-06-2008, 07:20
