    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    olha depois que tu salvar ele vai ir direto para a flash
  2. #14
    Padrão ainda nao foi
    Cara fiz do geito que vc falou ... configurei so o ip da Fastethernet pra agilizar dei write memory --->building .... depois desliguei o router e de novo ele aparece a tela
    Would you like to enter the initial configuration dialog?( yes/no )
    to achando q o boot dele ta indo pra outro lugar ....vo copiar oq ele ta fazendo e colocar ai
  3. #15
    Padrão ai vai
    ystem Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
    TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
    Copyright (c) 2001 by cisco Systems, Inc.
    C1700 platform with 65536 Kbytes of main memory
    Allocating additional 5955395 bytes to IO Memory.
    PMem allocated: 57713293 bytes; IOMem allocated: 9395571 bytes
    If any of the above Memory Requirements are
    "UNKNOWN", you may be using an unsupported
    configuration or there is a software problem and
    system operation may be compromised.
    Restricted Rights Legend
    Use, duplication, or disclosure by the Government is
    subject to restrictions as set forth in subparagraph
    (c) of the Commercial Computer Software - Restricted
    Rights clause at FAR sec. 52.227-19 and subparagraph
    (c) (1) (ii) of the Rights in Technical Data and Computer
    Software clause at DFARS sec. 252.227-7013.
    cisco Systems, Inc.
    170 West Tasman Drive
    San Jose, California 9513
    Cisco Internetwork Operating System Software
    IOS (tm) C1700 Software (C1700-SY7-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
    Copyright (c) 1986-2005 by cisco Systems, Inc.
    Compiled Thu 25-Aug-05 20:28 by ssearch
    Image text-base: 0x8000816C, data-base: 0x80E5340C
    cisco 1751 (MPC860P) processor (revision 0x600) with 56360K/9176K bytes of memor
    y.
    Processor board ID JAD06370DZR (3022442426), with hardware revision 0000
    MPC860P processor: part number 5, mask 2
    Bridging software.
    X.25 software, Version 3.0.0.
    1 FastEthernet/IEEE 802.3 interface(s)
    2 Serial(sync/async) network interface(s)
    32K bytes of non-volatile configuration memory.
    16384K bytes of processor board System flash (Read/Write)
    --- System Configuration Dialog ---
    Would you like to enter the initial configuration dialog? [yes/no]:
  4. #16
    Cara, verifica o config register esse router... pode ser isso.
    Se voce der um show startup-config e ve se as configs q vc fez estoa laá
  5. #17
    Padrão Certo Mestre
    Primeiramente ... queria agradecer a todos pela ajuda que estao me dando .
    Certo Mestre Misty.....apos dizer aquela msg de configuração inicial ( yes / no ) eu dizendo no ... e entrando no modo de configuração .... se eu der (show startup-config) aparece sim as configurações que eu tinha feito ( somente Ip da fastethernet - nao foi feito + nada so pra testar ) porem o router nao esta inicializando por ela ..... alguam coisa devo ter feito errado ....pq ele fica dando aquela msg segue abaixo STARTUP-CONFIG
    Using 580 out of 29688 bytes
    version 12.3
    service timestamps debug datetime msec
    service timestamps log datetime msec
    no service password-encryption
    hostname Router
    boot-start-marker
    boot system flash
    boot-end-marker
    mmi polling-interval 60
    no mmi auto-configure
    no mmi pvc
    mmi snmp-timeout 180
    no aaa new-model
    ip subnet-zero
    p cef
    interface FastEthernet0/0
    ip address 10.0.3.1 255.255.255.0
    speed auto
    interface Serial0/0
    no ip address
    shutdown
    interface Serial1/0
    no ip address
    shutdown
    ip classless
    no ip http server
    line con 0
    line aux 0
    line vty 0 4
    Aguardo ....
  6. #18
    Bom, me deu um branco agora e eu nao tenho um cisco para mecher.. então faça o seguinte:
    entre no modo de configuracao global e bote la
    (config)# config-register 0x2102
    salve, e reboote o router
