  1. A configuração abaixo são as regras aplicadas apenas estas, sem nenhum outra configuração, o que esta acontecendo é que durante o acesso ao site dos bancos os IPs são alterados, e a sessão é encerrada com o servidor, por este motivo, tentei marcar as conexões com destino na porta 443, e determinar uma rota, e tambem fazer nat nesta porta pra 1 endereço IP, porem sem sucesso, a rede fica lenta apos aplicar estas regras
    ENDEREÇAMENTO IP
    / ip address
    add address=189.47.176.133/24 network=189.47.176.0 broadcast=189.47.176.255 interface=ADSL01 comment="" disabled=no
    add address=189.47.130.139/24 network=189.47.130.0 broadcast=189.47.130.255 interface=ADSL02 comment="" disabled=no
    add address=192.168.100.1/24 network=192.168.100.0 broadcast=192.168.100.3 interface=RADIOS comment="" disabled=no
    ROTAS
    / ip route
    add dst-address=0.0.0.0/0 gateway=189.47.130.1 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=0.0.0.0/0 gateway=189.47.130.1 scope=255 target-scope=10 routing-mark=segunda_rota comment="" disabled=no
    add dst-address=0.0.0.0/0 gateway=189.47.176.1 scope=255 target-scope=10 routing-mark=primeira_rota comment="" disabled=no
    MANGLE
    / ip firewall mangle
    add chain=prerouting in-interface=RADIOS connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=primeiro passthrough=yes comment="Loadbalance" disabled=no
    add chain=prerouting in-interface=RADIOS connection-mark=primeiro action=mark-routing new-routing-mark=primeira_rota passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=RADIOS connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=segunda passthrough=yes comment="" disabled=no
    add chain=prerouting in-interface=RADIOS connection-mark=segunda action=mark-routing new-routing-mark=segunda_rota passthrough=no comment="" disabled=no
    NAT
    / ip firewall nat
    add chain=srcnat connection-mark=primeiro action=src-nat to-addresses=189.47.176.139 to-ports=0-65535 comment="NAT" disabled=no
    add chain=srcnat connection-mark=segunda action=src-nat to-addresses=189.47.130.133 to-ports=0-65535 comment="" disabled=no
  2. Ola cleciorodrigo,
    ... apenas para reafirmar:
    a regra da direcionamento tcp:443 voce colocou onde? No inicio de tabela "ip firewall nat"?
    Poste a versao do seu RouterOS.
    Aparentemente está tudo correto no meu ponto de vista.
    Sendo assim aproveito para convidar todos os leitores a participar dessa discussão.
    Abraços,
  3. Caro mson77, sim amig esta no inicio da talela nat, é primeira regra no topo de cima para baixo, porem oq acontece é que ao acionar esta regra a navegação fika muito lenta, vc tem um exemplo da regra.
    Clecio Rodrigo
    Citação Postado originalmente por mson77 Ver Post
    Ola cleciorodrigo,
    Abraços,
  4. Ola cleciorodrigo,
    sua afirmação de navegação lenta me parece ser extensiva... ou seja, "O TODO" passa a ficar mais lento. É isso mesmo que voce está afirmando?
    Implica que uma navegação http comum ficou mais lenta?
    Implica que um ftp/pop3/smtp passa a ficar mais lento apos ativação dessa regra que deveria atingir somente o protocolo tcp:443?
    Novamente: Qual versao do seu RouterOS? 2.9.x? 3.x????
    Sem a regra NAT sobre tcp:443... o LB está como desejado? Digo... com respeito ao tráfego convencional... o tráfego de dados pelos ADSL01 e ADSL02 estão compativeis com o trafego pelo RADIOS?
    Observando /interfaces...:
    A soma dos TXD (ADSL01+ADSL02) ==> lembra RXD (RADIOS)?
    A soma dos RXD (ADSL01+ADSL02) ==> lembra TXD (RADIOS)?
    Abracos,
  5. Caro mason boa noite,
    sim a soma do trafego da interface radios, onde esta os clientes, e o trafego na interface ADSL01 e ADSL02 somados, a as 2 tem mais ou menos os mesmo consumo, e tambem nas regras do mangle a marcação é quase igual, mudando muito pouco, testei apenas o trafego http.
    Clecio
    Ola cleciorodrigo,
    Abracos,
  1. Load Balance com Sites de Bancos
    Por thiagotgc no fórum Redes
    Respostas: 19
    Último Post: 29-05-2015, 00:22
  2. PCC com VPN e sites de Banco.
    Por lacierdias no fórum Redes
    Respostas: 6
    Último Post: 23-03-2011, 10:28
  3. Respostas: 5
    Último Post: 22-03-2011, 18:42
  4. balance cisco RV06 problemas com sites de bancos
    Por boneco no fórum Servidores de Rede
    Respostas: 5
    Último Post: 07-12-2010, 14:55
  5. Olá estou tendo problemas com Webmail
    Por PDP-7 no fórum Servidores de Rede
    Respostas: 5
    Último Post: 11-08-2006, 10:33
