    Padrão Nova Versao 3.10!!!
    ae pessoal mais uma nova versao, cada dia melhorando mais e mais.
    What's new in 3.10:
    *) added Multilink PPP to PPPoE client - just specify multiple interfaces
    to enable it;
    *) added ability to add dynamicly PPTP, L2TP & PPPoE client addresses
    to firewall address-list, specified in ppp profile,
    or via RADIUS in Mikrotik:19;
    *) added address-list attribute support in user-manager;
    *) added fan control for RB433;
    *) console:
    fixed 'interface wireless print detail', now shows the same output as
    'interface wireless print basic';
    fixed print to file, now writes complete contents, fixed resource leak;
    show name of running scripts in '/system script job', update
    'last-started' value;
    could not use item names for '/interface ovpn-server' and
    '/interface ovpn-client', fixed;
    fixed problems with export:
    some settings were not included in full export, such as
    '/interface wireless nstreme');
    some settings had duplicate entries with an error, such as
    '/system ntp client' when ntp package was enabled;
    long parameter values were incorrectly split across multiple lines;
    export now quotes all values that are split across multiple lines, it
    also adds line split before all newline characters, which improves
    readability of exported script sources;
    *) api - some properties were included multiple times in getall responses;
    *) port - properly tag all inactive ports;
    *) port - fixed memory leak that was triggered by addition/removal of
    USB serial ports;
    *) changed post-boot critical log messages - write a separate log entry
    explainig the cause of an non-administrative reboot, such as watchdog
    ping timeout, even if system rebooted cleanly;
    *) fixed user-manager 'database rebuild' command to correct database errors;
    *) fixed bug - user-manager customer password was not decoded
    correctly when database backup was transferred
    between Intel/RB100/RB500 and RB300/RB400/RB600/RB1000;
    *) fixed bug - "/blink" command did not work on RB300/RB600/RB1000;
    *) allow to configure OSPF authentication key ID;
    *) allow to include bridge interface in a mesh interface;
    *) ipsec - added Dead Peer Detection;
    *) fixed some random crashes on RB411 & RB433;
    *) fixed bug - OpenVPN could corrupt data on high load and force other end to disconnect;
    *) fixed bug - DHCP server did not return DHCP options in response to
    DHCPINFORM request;
    Smile
    ja estou testando a versao mk 3.10
    e ainda o proxy continua do mesmo jeito, na versao 3
    Citação Postado originalmente por edielsonps Ver Post
    Como assim do mesmo jeito ???
    Eu to registrando essa semana a versão 3.9
    o proxy da versao 3 e muito lento o melhor proxy ainda é da versao 2.9.X pois o proxy da versao 2.9.x é o squid da linux
    e o da versao 3 e um proxy proprietário da Mikrotik mais ainda nao esta legal
    Ah ... entendi .. eu tenho um aqui 2.9.50 rodando com parent proxy ... muito perfeito ... eh uma economia de link de 60% pelo meu ver ... mas isso depende muito de como se configura o Squid ... tem que saber configurar direitinhu e ter um bom pc pra fazer isso ... agora nesse caso ai eu to pensando em Rodar o proxy por fora do mikrotik 3.9 se for lento mesmo ... e eu nem verifiquei se essas versões trabalham com parent proxy !
    se vc for usar a versao mk 3.X pe melhor coloca um proxy externo com linux
    amigo tive uma pessima experiencia com mk 3.x principalmente no proxy.. tanto por lentidao.. quanto pelo parent proxy.. da mesma forma que fiz no mk 2.9x.. funcionando perfeitamente.. o 3.x nao repassava o parent proxy.. lixo..
    eu como servidor nao coloco mais 3.x soh nos radios..
    fora quer perdi 3x meu controle de banda.. do nada.. se nao foce o backup diario tava fu..
    xiiiiiiiiiiiiiiiiiiiiiiiiiii ... entaum nem vou migrar
    Algum de vcs tem experiencia em HotSpot com o 2.9.50 ?????
    O problema Edielson são as limitações do 2.9.50 como 1Gb de Memória RAM somente, só reconhece HD IDE e fora os bugs que eu desconheco ... gostaria que vc desse uma olhadinha na versão 3.9 que foi a que eu baixei essa semana ... e me desse um parecer se possivel ! Testa pra mim por favor essa verssão 3.1 com proxy externo ...
    amigo em alguns clientes meus q usam hd sata tive q instala a versao 3.x hoje estou usando a versao 3.10 e tambem eu tenho um sistema que integro ao mikrotik o "MyRouter" onde eu instalo ele em um Linux Debian e faço a intergração ao mikrotik por FreeRadius ai ja uso a linux para configura um Squid para fazer o cache dos clientes sso usando o mikrotik 3.x + myrouter.
    agora usando a versao 2.9.x eu uso o proxy do Mikrotik mesmo..
