    Citação Postado originalmente por galahad Ver Post
    posta aqui pra mim o resultado dos seguintes comandos:
    uname -a
    ls -l /usr/src
    e o modelo da sua placa broadcom.
    la vai...
    [email protected]:~# uname -a
    Linux pabx 2.4.33.3 #1 Fri Sep 1 01:48:52 CDT 2006 i686 athlon-4 i386 GNU/Linux
    [email protected]:~# ls -l /usr/src/
    total 18156
    drwxr-xr-x 24 root root 4096 2008-06-26 08:16 asterisk-1.4.21/
    -rw-r--r-- 1 root root 11525298 2008-06-25 14:38 asterisk-1.4.21.tar.gz
    drwxr-xr-x 9 1000 1000 4096 2008-06-25 16:56 asterisk-addons-1.4.0/
    -rw-r--r-- 1 root root 995313 2008-06-25 16:52 asterisk-addons-1.4.0.tar.gz
    drwxr-sr-x 11 root root 4096 2008-06-25 16:49 asterisk-addons-1.4.7/
    -rw-r--r-- 1 root root 799192 2008-06-25 16:23 asterisk-addons-1.4.7.tar.gz
    drwxr-xr-x 3 1000 1000 4096 2005-12-06 21:36 asterisk-sounds-1.2.1/
    -rw-r--r-- 1 root root 3249876 2008-06-25 16:22 asterisk-sounds-1.2.1.tar.gz
    drwxr-xr-x 4 root root 4096 2007-05-05 09:02 etc/
    drwxr-xr-x 2 root root 4096 2007-05-05 09:02 install/
    drwxr-xr-x 3 root root 4096 2007-05-05 09:02 lib/
    drwxr-sr-x 3 root root 4096 2008-06-25 14:44 libpri-1.4.4/
    -rw-r--r-- 1 root root 91880 2008-06-25 14:38 libpri-1.4.4.tar.gz
    lrwxrwxrwx 1 root root 14 2008-06-25 05:56 linux -> linux-2.4.33.3/
    drwxr-xr-x 15 root root 4096 2008-07-02 15:19 linux-2.4.33.3/
    drwxr-xr-x 7 root root 4096 2008-07-01 17:14 ndiswrapper/
    -rwxr--r-- 1 root root 123668 2008-07-01 17:12 ndiswrapper-1.43_2.4.33.3-i486-1McD.tgz*
    drwxr-xr-x 4 root root 4096 2007-05-28 12:12 ndiswrapper-1.45/
    drwxr-xr-x 7 root root 4096 2003-10-29 04:08 rpm/
    drwxr-xr-x 2 root root 4096 2007-05-05 09:02 sbin/
    drwxr-xr-x 4 root root 4096 2007-05-05 09:02 slackbuilds/
    drwxr-xr-x 2 root root 4096 2006-08-23 00:13 speakup-2.4.33.3/
    drwxr-xr-x 6 root root 4096 2007-05-05 09:02 usr/
    drwxr-sr-x 8 root root 4096 2008-06-25 16:48 zaptel-1.4.11/
    -rw-r--r-- 1 root root 1681384 2008-06-25 14:38 zaptel-1.4.11.tar.gz
    e obrigado pela pescistencia!
  2. #14
    Não tem que agradecer ainda! Vamos primeiro resolver seu problema
    Já compilou um kernel antes? Vamos lá, execute os seguintes passos:
    1 - cd /usr/src/linux
    2 - make clean
    3 - make oldconfig (pode ser que ele pare pra te fazer algumas perguntas, é só apertar enter e ficar com o padrão)
    4 - make dep
    5 - make && make modules
    Em princípio, seguindo os passos até aqui você vai ter um kernel exatamente igual ao que está rodando na sua máquina. Vamos ao ndiswrapper:
    1 - cd /usr/src/ndiswrapper-1.45 (última versão, certo?)
    2 - make clean && make distclean
    3 - ./configure [qualquer opção que você queira adicionar]
    4 - make
    5 - make install
    6 - depmod -ae
    7 - modprobe ndiswrapper
    E vamos ver se funciona... se não funcionar, vamos partir para a instalação do kernel e uma nova tentativa. E, como último recurso, uma versão mais antiga do ndiswrapper.
    Só uma coisa, se der qualquer erro, poste ele aqui pra eu poder acompanhar, ok?
  3. #15
    2 - make clean
    4 - make dep
    4 - make
    5 - make install
    6 - depmod -ae
    blz cara agora sim, a questão do kernel não funfou mas realmente foi como vc falou com uma versão mais antiga do ndiswrapper ele compilou normal usei a 1.25 valeu mesmo
  4. #16
    Sem problemas!
    As versões mais novas do ndiswrapper devem fazer uso de parâmetros o kernel 2.6, por isso dos erros na hora de carregar o módulo. Bom, só uma especulação, eu não cheguei a olhar o site do ndiswrapper nem os ChangeLogs.
