  1. Citação Postado originalmente por galahad Ver Post
    quando você roda o postfix reload, ele mostra alguma coisa no log com relação aos mapas de aliases?
    você chegou a rodar o postmap /var/lib/mailman/data/virtual-mailman e postmap /var/lib/mailman/data/aliases?
    No log do postfix não tem erro nenhum.
    Já havia rodado antes.
    postmap /var/lib/mailman/data/virtual-mailman (Não tem erros)
    postmap: warning: /var/lib/mailman/data/aliases, line 10: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 11: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 12: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 13: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 14: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 15: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 16: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 17: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 18: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 19: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 24: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 25: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 26: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 27: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 28: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 29: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 30: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 31: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 32: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 33: record is in "key: value" format; is this an alias file?
    postmap: warning: /var/lib/mailman/data/aliases, line 35: record is in "key: value" format; is this an alias file?
    Se eu rodo postalias no /var/lib/mailman/data/aliases não dá esse erro.
    Última edição por darkwarrior; 12-07-2008 às 07:59.
  2. Desculpa a demora... vamos ver se esse arquivo está mesmo funcionando... supondo que o seu arquivo /var/lib/mailman/data/aliases tenha uma entrada no formato:
    Código :
    nome-da-lista@blah.com.br     lista1
    digite o seguinte comando:
    Código :
     postmap -q nome-da-lista@blah.com.br hash:/var/lib/mailman/data/aliases
    Ele tem que te retornar lista1.
  3. funcionou ambos os abaixo:
    # postmap -q funcionarios hash:/var/lib/mailman/data/aliases
    "|/usr/lib/mailman/mail/mailman post funcionarios"
    # postmap -q funcionarios@dominio.com.br hash:/var/lib/mailman/data/virtual-mailman
    funcionarios
    # postmap -q root hash:/etc/postfix/aliases
    jean@dominio.com.br
    Última edição por darkwarrior; 13-07-2008 às 01:10.
  4. o mais estranho é que nos logs ele diz que acha o alias:
    Jul 13 02:15:40 onca postfix/smtpd[29034]: maps_find: local_recipient_maps: hash:/var/lib/mailman/data/aliases(0,lock|fold_fix): funcionarios = "|/usr/lib/mailman/mail/mailman post funcionarios"
    Jul 13 02:15:40 onca postfix/smtpd[29034]: mail_addr_find: funcionarios@dominio.com.br -> "|/usr/lib/mailman/mail/mailman post funcionarios"
    Mas mesmo assim, logo depois:
    Jul 13 02:15:40 onca postfix/pipe[29038]: 2B9C411C0A8: to=<funcionarios@dominio.com.br>, relay=maildrop, delay=0.32, delays=0.14/0.02/0/0.17, dsn=5.1.1, status=bounced (user unknown. Command output: Invalid user specified. )
    O que eu acho mais estranho é o relay=maildrop, não teria que ficar local? algo assim, quando fossem para a lista?
  5. Consegui resolver:
    no main.cf coloquei:
    transport_maps = hash:/etc/postfix/transport
    e no arquivo transport coloquei uma linha para cada alias do mailman, a exemplo dessa abaixo:
    funcionarios local:
    Daí as chamadas para eles passaram a ser locais e não pelo maildrop, assim rodou certinho
  1. Problemas com Postfix (URGENTE)
    Por LinuxKids no fórum Servidores de Rede
    Último Post: 02-09-2006, 15:26
  2. Problema com Postfix+sasl2+cyrus-imapd
    Por Schakal no fórum Servidores de Rede
    Último Post: 28-10-2005, 08:45
  3. problemas com postfix
    Por perdiga no fórum Servidores de Rede
    Último Post: 19-10-2005, 14:11
  4. Problemas com Postfix com determinado dominio
    Último Post: 20-01-2005, 09:24
  5. Problemas com Postfix mais Qpopper
    Por fablinux1 no fórum Servidores de Rede
    Último Post: 12-01-2005, 10:43
