    galera confirmado mesmo algum bug na versão 3.15 ?como anda os teste de quem já atualizou as torres ?
  2. #14
    Citação Postado originalmente por Snake_jp Ver Post
    acabou de sair a nova versao do mk, com varia melhoria sera que dessa ves o proxy funciona?
    What's new in 3.15:
    *) added workaround for non-standards compliant CPE with timestamp issue;
    *) added ability to manage multiple disks & stores under /store;
    *) added support for storing user-manager database on secondary media via /store;
    *) /store should be used to set up secondary disk as web proxy cache;
    *) added support for Mesh in WinBox;
    *) fixed client roaming in mesh protocol;
    *) fixed bug in MME routing protocol:
    routes sometimes were lost from routing table;
    *) fixed some bugs in routing-test;
    *) fixed traffic forwarding when VRF (virtual routing and forwarding) is used;
    *) fixed problem - USB did not work on Geode LX boards;
    *) fixed problem - farsync cards did not negotiate links;
    *) added support for Novatel EU870D;
    *) added support for Intel 82575EB & 8257GB gigabit ethernet PCI-Express cards;
    *) removed support for all synchronous cards but farsync;
    *) graphing - all target (source) addresses displayed in queue statistics page;
    *) bridge firewall broute table is removed - it did not work as expected anyway;
    *) ingress-priority matcher added to bridge firewall
    *) fixed use-dns property of console traceroute command, default now is
    use-dns=no;
    *) updated UK 5.8 FIXED regulatory domain info;
    *) /system ssh now by default uses name of logged in user instead of "admin";
    *) fixed support for some microSD cards on RB400;
    *) include Relay-Session-ID in packets sent by PPPoE client if required;
    *) added ability to specify src. address for radius client;
    *) dns cache - improved static entry behavior;
    *) fixed dial-on-demand on ppp interfaces;
    http://www.mikrotik.com/download.html
    outra novidade:
    foi acresentado um botao MESH
    Desde a última versão o proxy do Mikrotik funciona perfeitamente.
  3. #15
    aqui ta tudo beleza
    e o proxy ta funcionando razoavelmente bem
  4. #16
    Padrão Cache full
    O meu web-proxy tá funcionando para as páginas porém, eu gostaria muito de fazer cache full, não estou conseguindo (preciso de uma ajudinha de vcs)...outra coisa na versao 3.15 existe um botao store, é pra adicionar mais de um hd como web-proxy é isso?
    Abraços,
  5. #17
    Para fazer o cache full você deve setar o valor do DSCP (ToS) referente a versão 3.x que é DSCP=4.
    Em relação ao store, seria o local de armazenamento.
  6. #18
    Padrão Versão 3.15
    A versão até o presente momento tem se saido a melhor possivel firewall , queues , cache full , tudo funcionando 100% inclusive até melhor que as anteriores
