  1. Install and Configure Cacti
    1. Extract the distribution tarball.
      shell> tar xzvf cacti-version.tar.gz
    2. Create the MySQL database:
      shell> mysqladmin --user=root create cacti
    3. Import the default cacti database:
      shell> mysql cacti < cacti.sql
    4. Optional: Create a MySQL username and password for Cacti.
      shell> mysql --user=root mysqlmysql> GRANT ALL ON cacti.* TO cactiuser@localhost IDENTIFIED BY 'somepassword';mysql> flush privileges;
    5. Edit include/config.php and specify the database type, name, host, user and password for your Cacti configuration.
      $database_type = "mysql";$database_default = "cacti";$database_hostname = "localhost";$database_username = "cactiuser";$database_password = "cacti";
    6. Set the appropriate permissions on cacti's directories for graph/log generation. You should execute these commands from inside cacti's directory to change the permissions.
      shell> chown -R cactiuser rra/ log/(Enter a valid username for cactiuser, this user will also be used in the next step for data gathering.)
    7. Add a line to your /etc/crontab file similar to:
      */5 * * * * cactiuser php /var/www/html/cacti/poller.php > /dev/null 2>&1Replace cactiuser with the valid user specified in the previous step.
      Replace /var/www/html/cacti/ with your full Cacti path.
    8. Point your web browser to:
      Log in the with a username/password of admin. You will be required to change this password immediately. Make sure to fill in all of the path variables carefully and correctly on the following screen.
    se seguir isso ae, tem q fungar...
    abraçosssssss
  2. 7.Add a line to your /etc/crontab file similar to:
    Essa linha ai, vai depedende da versao do PHP q se usa, e da posta onde ta instalado o CACTI, e do comando, POLLER, ou CMD... e é justamente essa linha q cria as RRA, pra gerar os graficos... entao tem q ta batendo conforme instalado o cacti.
    Esse seu tuto ai q se pego, ta com PHP antigo, mysql, e apache1..
    o q eu fiz usei apache2 mysql.5.7 php5... mas o q vale é funciona.
  3. sim sim, eu vi q o seu está atualizdo, só passei pra ver se ajuda alguem, talves fosse um detalhe como esse,...e ae já tem a permissão q vc falou o amigo thenet....abraçossssssss
  4. amigos...verifiquei aqui e o que ta acontecendo, é que não está sendo criado os arquivos rrd na pasta /rra ... talvez seja permissão, mas ja tentei de tudo e nao vai.
    alguem pode me dar uma luz? rsrs
    valew
  5. Citação Postado originalmente por thenet Ver Post
    valew
    é Permissao na PASTA... se tem q coloca 7777... e coloca o usuario cacti tbm pra ter acesso, mas no seu caso é a pasta mesmo... libera acesso pra toda pasta CACTI, nao so a pasta RRA e LOG..
  1. Gravar gráfico de tráfego no Mikrotik
    Por shimatani no fórum Redes
    Último Post: 08-02-2016, 01:15
  2. Criando Gráficos de consumo no mikrotik.
    Por csalex no fórum Redes
    Último Post: 03-12-2014, 11:37
  3. Gerenciamento de PPPoe no Mikrotik
    Por maxtex no fórum Redes
    Respostas: 6
    Último Post: 12-03-2007, 11:17
  4. Pings bons, mas com perda de pacotes no Mikrotik...
    Por cristianoduarte no fórum Redes
    Último Post: 26-02-2007, 12:22
  5. Problemas de desconexão no Mikrotik .
    Por FEenuX no fórum Redes
    Último Post: 24-10-2006, 22:13
