Página 7 de 7 PrimeiroPrimeiro ... 234567
  1. Nao precisa enviar o script mais nao ....
    no seu script esta assim
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip dst-address 10.0.1.254 flowid 1:60
    deve ficar assim:
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip dst 10.0.1.254 flowid 1:60
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip src 10.0.1.254 flowid 1:60
    com a opcao "ip dst" vc indica que tudo que possuir destino for a maquina 10.0.1.254 deve trafegar a 100mbit.
    com a opcao "ip src" vc indica que tudo quer possuir origem 10.0.1.254 deve trafegar a 100mbit independente do destino, seja rede interna ou rede externa.
  2. vamos lá..então ficou assim:
    rede interna eth1:
    #!/bin/bash
    tc qdisc del dev eth1 root
    tc qdisc add dev eth1 root handle 1:0 htb default 50
    #squid
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 100mbit
    #squid
    tc class add dev eth1 parent 1:1 classid 1:60 htb rate 100mbit prio 1
    tc class add dev eth1 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth1 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth1 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth1 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth1 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    #squid
    tc qdisc add dev eth1 parent 1:60 handle 60: sfq perturb 10
    tc qdisc add dev eth1 parent 1:10 handle 10: sfq perturb 10
    tc qdisc add dev eth1 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth1 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth1 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth1 parent 1:50 handle 50: sfq perturb 10
    #squid
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5060 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5061 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 10000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 20000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 2 u32 match ip sport 53 0xffff flowid 1:20
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip sport 3389 0xffff flowid 1:30
    tc filter add dev eth1 parent 1:0 protocol ip prio 4 u32 match ip sport 80 0xffff flowid 1:40
    rede externa eth0:
    #!/bin/bash
    tc qdisc del dev eth0 root
    tc qdisc add dev eth0 root handle 1:0 htb default 50
    tc class add dev eth0 parent 1:0 classid 1:1 htb rate 1024kbit
    tc class add dev eth0 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth0 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth0 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth0 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth0 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    tc qdisc add dev eth0 parent 1:10 handle 10: pfifo limit 10
    tc qdisc add dev eth0 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth0 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth0 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth0 parent 1:50 handle 50: sfq perturb 10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 5060 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 5061 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 10000 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 20000 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 2 u32 match ip dport 53 0xffff flowid 1:20
    tc filter add dev eth0 parent 1:0 protocol ip prio 3 u32 match ip dport 3389 0xffff flowid 1:30
    tc filter add dev eth0 parent 1:0 protocol ip prio 4 u32 match ip dport 80 0xffff flowid 1:40
    e no squid adicionei as linhas:
    #CACHE FULL
    refresh_pattern (/cgi-bin/|\?) 0 0% 0
    refresh_pattern . 0 20% 4
    entào fui fazer o teste..com minha máquina limpei o cookies e etc...depois baixei o acrobat que tem 23mb no site www.baixaki.com.br...ele baixou usando 80KB/s a 90KB/s da minha rede que tem no total 100KB/s de link embratel...depois disso exluir o arquivo da minha máquina cliente, limpei novamente os cookies e etc... e fui baixar para testar o cache full...resultado:
    baixou com o mesmo tempo e na mesma velocidade..o que pode estar errado??
  3. amaia me ajuda por favor preciso ativar esse cache full!!
    outra coisa não teria que colocar algo do ZPH no squid.conf?
    Última edição por lfernandosg; 26-01-2009 às 20:43.
  1. Migrar proxy autenticado linux para mikrotik
    Por lfernandosg no fórum Redes
    Último Post: 08-07-2014, 08:05
  2. Respostas: 11
    Último Post: 05-11-2012, 12:22
  3. Qual melhor Linux para Servidor de Internet? Vou tercerizar
    Por CAPITU-RP no fórum Servidores de Rede
    Respostas: 17
    Último Post: 11-09-2005, 16:46
  4. migrar servidor Samba para outra versão
    Por dctalk no fórum Servidores de Rede
    Último Post: 31-08-2005, 07:31
  5. wual o melhor antivirus para servidor de internet ?????
    Por fbdalpra no fórum Servidores de Rede
    Último Post: 25-10-2004, 15:57
