    Talking
    Opa...
    Pegando carona no topico do colega, eu uso a versão 3.20 com hotspot e estou com o mesmo problema, as vezes os clientes baixam usando o maximo do cache, ai olho no consumo do link tá topado, depois volto no queue e está praticamente zerado.
    Obrigado.
    Última edição por NetoGO23; 20-03-2009 às 21:32.
  2. #14
    Uso hotspot sim, o problema continua, hehehehe
  3. #15
    Thumbs up
    EU CONSEGUI COLOCA PARA FUNCIONAR SEM O HOTPORT!!!!!
  4. #16
    ai esta o cache full do 2.9.27 ...vlw
    / ip firewall mangle
    add chain=output protocol=tcp src-port=8080 content="X-Cache: HIT" action=mark-connection new-connection-mark=squid-connection-HIT passthrough=yes \ comment="Cache-squid" disabled=no
    add chain=output connection-mark=squid-connection-HIT action=mark-packet new-packet-mark=squid-packet-HIT passthrough=no comment="" disabled=no
    add chain=output action=return connection-mark=squid-connection-HIT comment="" disabled=no
    add chain=prerouting in-interface=Saida src-address=192.168.2.0/24 action=mark-packet new-packet-mark=test-up passthrough=no comment="UP TRAFFIC" \ disabled=no
    add chain=forward src-address=192.168.2.0/24 action=mark-connection new-connection-mark=test-conn passthrough=yes comment="CONN-MARK" disabled=no
    add chain=forward in-interface=Entrada connection-mark=test-conn action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-DIRECT CONNECTION" disabled=no
    add chain=output out-interface=Saida dst-address=192.168.2.0/24 action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-VIA PROXY" disabled=no
    / queue tree
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT \ limit-at=2048000 queue=default priority=8 max-limit=2048000 burst-limit=0 \ burst-threshold=0 burst-time=0s disabled=no
    add name="upstream" parent=global-in packet-mark=test-up limit-at=2048000 \ queue=default priority=8 max-limit=2048000 burst-limit=0 burst-threshold=0 \ burst-time=0s disabled=no
    fui !
    bjunda
  5. #17
    Mikrotiando..
    Sep 2007
    São Paulo
    Citação Postado originalmente por frilton Ver Post
    Amigo, observa se você tem essa regra em "nat", se você não tiver essa regra não vai funcionar com hotspot.
    Lembrando de trocar onde esta: bridge1, pela sua interface correta (se não estiver em bridge, e ports se não for 3128 a do seu proxy).
    /ip firewall nat
    add chain=pre-hotspot in-interface=bridge1 protocol=tcp dst-port=80 \
    hotspot=auth action=redirect to-ports=3128 comment="REDIRECIONAMENTO DE \
    PROXY HOTSPOT" disabled=no
    Última edição por ddllss; 10-04-2009 às 19:15.
  6. #18
    Mikrotiando..
    Sep 2007
    São Paulo
    Citação Postado originalmente por Raniel Ver Post
    Já tentaram controlar o cache miss?
    /ip firewall mangle
    add chain=prerouting action=mark-connection new-connection-mark=conn-miss passthrough=yes in-interface=wan content=X-Cache: MISS
    add chain=prerouting action=mark-packet new-packet-mark=miss passthrough=no connection-mark=conn-miss
    Olá Raniel,
    Dei uma pesquisada nesse "cache MISS" e encontrei 2 definições para ele:
    1 - Uma situação alternativa, que ocorre quando a cache é consultada e não contém um dado com a etiqueta desejada, é conhecida como cache miss (erro do cache).
    2- A CPU cache is a cache used by the central processing unit of a computer to reduce the average time to access memory. ...
    Tambem dei uma olhada aqui no forum, tem essa sitação "cache miss", mas não explicando o que seria isso.
    Eu não uso essa regra no meu mk, seria alguma dessas 2 definições que achei?
    Abraços,
