Página 3 de 11 PrimeiroPrimeiro 12345678 ... ÚltimoÚltimo
  1. Citação Postado originalmente por lfernandosg Ver Post
    certo muito obrigado e clarerou muito..vou te mostrar o script que uso hoje de hTB:
    essa é minha placa de acesso a rede interna:
    #!/bin/bash
    tc qdisc del dev eth1 root
    tc qdisc add dev eth1 root handle 1:0 htb default 50
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 1024kbit
    tc class add dev eth1 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth1 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth1 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth1 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth1 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    tc qdisc add dev eth1 parent 1:10 handle 10: sfq perturb 10
    tc qdisc add dev eth1 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth1 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth1 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth1 parent 1:50 handle 50: sfq perturb 10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5060 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5061 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 10000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 20000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 2 u32 match ip sport 53 0xffff flowid 1:20
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip sport 3389 0xffff flowid 1:30
    tc filter add dev eth1 parent 1:0 protocol ip prio 4 u32 match ip sport 80 0xffff flowid 1:40
    eu tenho 1mb de link dedicado embratel e preciso dividir o link em 512k para internet/terminal service e etc.. e 512k para nosso voip então fora o que está acima o que devo alterar para o download ficar com taxa de 10Mbps e acelerar as páginas de internet?
    sei que essa linha tem que ser alterada para a veloidade da placa de rede ficando mais ou menos assim:
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 100mbit
    mas o restante o que devo acrescentar??se puder me ajudar pois essa parte de HTB não entendo muito pois esse scritp achei na net.E queria saber como acrescentar o path para o HTB que vc fala..pois instalei só o iproute e etc...
    Apesar de sua rede estar no padrão que , supostamente, pode alcaçar 100mbits esses valores só são alcançados em condições especiais , não quer dizer que ela vá trabalhar a 100mbits.
    se fosse comigo, primeiro eu alteraria a taxa da classe raiz para 10Mbits, que é 10% da taxa máxima da rede.
    esta linha que você colocou
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 10Mbit
    #!/bin/bash
    #----------------------alterar essa linha-------------------
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 10mbit
    #--------------adiciona essa classe para receber o tráfego do zph
    tc class add dev eth2 parent 1: classid 1:60 htb rate 5mbit prio 1 #ZPH
    tc qdisc add dev eth1 parent 1:60 handle 60: sfq perturb 10
    #-------------e finalmente o filtro que vai classificar o tráfego e jogar na classe certa
    tc filter add dev eth2 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:60
    feito isso não há motivo para nao funcionar. Para ver o tráfego na classe digite o seguinte comando:
    tc -s -d class show dev eth1
    que deverá retornar as estatísticas das classes nessa placa de rede. Algo como isso abaixo para cada classe pra ver se realmente está tendo tráfego na classe 1:60 verique os números que ficam a frente do parâmetro Send . Se ficar em zero é por que não há tráfego sendo desviado pra ela.
    class htb 1:60 root prio 5 quantum 1000 rate 512000bit ceil 512000bit burst 1855b/8 mpu 0b overhead 0b cburst 1855b/8 mpu 0b overhead 0b level 0
    Sent 1233769731 bytes 1207747 pkt (dropped 0, overlimits 0 requeues 0)
    rate 187504bit 26pps backlog 0b 0p requeues 0
    lended: 1207747 borrowed: 0 giants: 0
    tokens: 1408 ctokens: 1408
  2. Citação Postado originalmente por ALVERNEPAIVA Ver Post
    #!/bin/bash
    Corrigindo pois eu coloquei a interface eth2 nas linhas que adicionei e esta é a minha interface. No seu caso eth1.
    Agora corrigido.
    #!/bin/bash
    tc class add dev eth1 parent 1: classid 1:60 htb rate 5mbit prio 1 #ZPH
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:60
  3. cara nem sei como te agradecer mas não sei se ficou correto olha o que fiz:
    no script da placa de rede interna coloquei o script que vc passou:
    #!/bin/bash
    #--------------adiciona essa classe para receber o tr�fego do zph
    #-------------e finalmente o filtro que vai classificar o tr�fego e jogar na classe certa
    depois no squid.conf adicionei as linhas:
    #ZPH cache FULL
    zph_mode tos
    zph_option 136
    zph_parent 0
    zph_sibling 0
    rodei os scripts...estou baixando um arquivo para ver depois com qual velocidade ele vai ser baixado mas nos testes que vc passou o sent está me "0"
    class htb 1:60 root leaf 60: prio 1 quantum 62500 rate 5000Kbit ceil 5000Kbit burst 1600b/8 mpu 0b overhead 0b cburst 1600b/8 mpu 0b overhead 0b level 0
    Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
    rate 0bit 0pps backlog 0b 0p requeues 0
    lended: 0 borrowed: 0 giants: 0
    tokens: 2500 ctokens: 2500
    nas outras classes tem valores na frente do sent mas na 1.60 não tem...o que pode estar faltando? outra coisa na placa de rede externa(recebe o ip valido da embratel) precisa colocar algo?
  4. Faltou o ZPH_LOCAL ai no squid.conf. Aqui está trabalhando bem, minhas configurações são tipo essa sua mesmo. Porém tenho sub-classes dividindo a banda do cache full para cada usuário.
  5. agora acho que está do jeito que vc passou:
    #ZPH cache FULL
    zph_mode tos
    zph_option 136
    zph_parent 0
    zph_sibling 0
    zph_local 0x60
    e no HTB:
    #!/bin/bash
    mas os testes continuam com o sent zerado...e baixei um arquivo para testar..limpei o cache do navegador e ele foi baixado na mesma velocidade da internet 49KB/s
    o que pode estar faltando?meu squid é autendicado não sei se isso pode interferir mas acho que não!se puder me ajudar...preciso colocar algo no script da placa externa de rede?
    está assim meu script:
    #!/bin/bash
    tc qdisc del dev eth0 root
    tc qdisc add dev eth0 root handle 1:0 htb default 50
    tc class add dev eth0 parent 1:0 classid 1:1 htb rate 1024kbit
    tc class add dev eth0 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth0 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth0 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth0 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth0 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    tc qdisc add dev eth0 parent 1:10 handle 10: pfifo limit 10
    tc qdisc add dev eth0 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth0 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth0 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth0 parent 1:50 handle 50: sfq perturb 10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 5060 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 5061 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 10000 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 20000 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 2 u32 match ip dport 53 0xffff flowid 1:20
    tc filter add dev eth0 parent 1:0 protocol ip prio 3 u32 match ip dport 3389 0xffff flowid 1:30
    tc filter add dev eth0 parent 1:0 protocol ip prio 4 u32 match ip dport 80 0xffff flowid 1:40
    não alterei nada!!
  1. Diferença com e sem ZPH
    Por Elliott no fórum Servidores de Rede
    Respostas: 7
    Último Post: 23-04-2008, 13:10
  2. hotspot qual o segredo?
    Por daniloacr no fórum Redes
    Respostas: 6
    Último Post: 11-03-2008, 00:48
  3. zph=tos_hit_tos + squid + htb
    Por megatek no fórum Servidores de Rede
    Respostas: 6
    Último Post: 09-06-2007, 01:15
  4. O segredo que ninguém fala... rssss
    Por adelsonbbg no fórum Servidores de Rede
    Respostas: 7
    Último Post: 06-03-2007, 10:36
  5. Link Dedicado Qual segredo ????
    Por adelsonbbg no fórum Redes
    Respostas: 6
    Último Post: 18-02-2007, 14:06
