    Padrão Problemas com LB rotas Estaticas
    Boa Tarde
    Sei que tem varios posts a respeito, ja paguei pra pessoas aqui fazerem, mas os que me suportaram nao conseguiram e acabaram me bloqueando apos o pgto, com isso queria uma solução do pessoal de forum que se mostra sempre a ajudar.
    tenho o sequinte ambiente
    link1 pppoe brideg mk autenticando
    link2 moden roteado 10.1.1.1 gw
    link3 moden roteado 10.0.0.18 gw
    com isso queria balancear esses 3 links de 4mb
    hoje tenho assim mas nao funciona, queria deixar um link pra youtube e rapidsahres outro pra 443 e orkut banco e o ppoe pra default, eu nao faço cache so balance versao 2.9.51
    Agradeço a todos
    / ip route
    add dst-address=0.0.0.0/0 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 routing-mark=Media comment="" \
    disabled=no
    add dst-address=32.0.0.0/3 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="" disabled=yes
    add dst-address=64.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="msn" disabled=yes
    add dst-address=65.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="msn" disabled=yes
    add dst-address=66.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="" disabled=yes
    add dst-address=67.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=72.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="Ytb" disabled=yes
    add dst-address=74.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="ytb" disabled=yes
    add dst-address=75.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=82.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=87.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=88.208.0.0/16 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=94.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=146.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=174.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=194.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=195.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=199.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=200.98.249.120/32 gateway=10.1.1.1,10.1.1.1 distance=2 scope=255 target-scope=10 comment="NO \
    REMOVER TESTE LINK2" disabled=yes
    add dst-address=200.146.79.165/32 gateway=200.204.210.232,200.204.210.232 distance=1 scope=255 target-scope=10 \
    comment="NO REMOVER TESTE LINK1" disabled=no
    add dst-address=200.176.3.142/32 gateway=10.0.0.138,10.0.0.138 distance=3 scope=255 target-scope=10 comment="NO \
    REMOVER TESTE LINK3" disabled=yes
    add dst-address=200.201.174.0/24 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="msn" disabled=no
    add dst-address=201.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="TEsTE" disabled=no
    add dst-address=204.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="TEsTE" disabled=no
    add dst-address=206.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=207.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="msn" disabled=yes
    add dst-address=208.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="ytb" disabled=yes
    add dst-address=209.0.0.0/8 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    add dst-address=213.0.0.0/8 gateway=10.1.1.1 distance=2 scope=255 target-scope=10 comment="" disabled=yes
    add dst-address=216.239.32.0/19 gateway=10.0.0.138 distance=3 scope=255 target-scope=10 comment="" disabled=no
    Brasil.
    Poste o seu firewall completo. Principalmente o Mangle e o nat.
    Padrão OK ae esta
    / ip firewall nat
    add chain=srcnat action=masquerade src-address=192.168.0.0/16 comment="" disabled=no
    add chain=dstnat action=dst-nat to-addresses=192.168.7.2 to-ports=3389 dst-port=3389 protocol=tcp comment="Acesso \
    Remoto" disabled=yes
    / ip firewall mangle
    add chain=prerouting action=mark-routing new-routing-mark=Media passthrough=yes dst-port=554 protocol=tcp \
    comment="radio" disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=p2p_conn passthrough=yes p2p=all-p2p \
    comment="Marcando Protocolo P2P" disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=p2p_conn passthrough=yes dst-port=0 protocol=tcp \
    add chain=prerouting action=mark-connection new-connection-mark=p2p_conn passthrough=yes dst-port=0 protocol=udp \
    add chain=prerouting action=mark-connection new-connection-mark=p2p_conn passthrough=yes p2p=warez comment="" \
    disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=p2p_conn passthrough=yes dst-port=4660-4675 \
    protocol=udp comment="" disabled=no
    protocol=tcp comment="" disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=p2p_conn passthrough=yes dst-port=6340-6400 \
    add chain=prerouting action=mark-packet new-packet-mark=p2p_packet passthrough=no connection-mark=p2p_conn \
    so tem isso mais nada
    Brasil.
    Dá para fazer sim, mas demanda de um pouco de tempo. Assim que puder tentarei te ajudar. Nesse intervalo de tempo é necessario rotear o seu modem.
    Padrão ok
    Citação Postado originalmente por interhome Ver Post
    Ok ja esta tudo pronto
    Brasil.
    Bom dia,
    a idéia é marcar as conexoes do que se quer no mangle, assim vc vai criando várias marcações. Quanto mais marcações, maior a mobilidade em direcionar o fluxo para o que se quer.
    Sentei para tentar te ajudar mas me falta algumas coisas:
    Informar o nome correto de cada interface e seu gateway.
    Link1 = ?
    Link2 = 10.1.1.1
    LINK3 = 10.0.0.18
    CLIENTES= ?
    Deve informar corretamente. Se esses numeros estão corretos, a regra que vc tem esta direcionando para o gateway 10.0.0.138. Quem é esse gateway?
    Vc só tem link adsl ?
    Última edição por interhome; 01-02-2009 às 11:12.
