  1. Citação Postado originalmente por vialink Ver Post
    quando instala o squid ele já criou o nobody nogroup e deu permissão correto? Sendo assim era para funcionando quando executei o squid -z pela primeira vez. Será que eu posso ter feito algo errado na hora de instalar o squid? éu postei tbm o meu config, está tudo certo?
    tem esses números nessa linha mesmo:
    cache_dir aufs /var/cache/squid 20000 16 256
    Executei na orgem.
    bash-3.1# chown -fvR squid:squid /var/cache
    ownership of `/var/cache/cups' retained as squid:squid
    ownership of
    `/var/cache/fontconfig/2d31a572ce6667f6a0da9c8dc611898b-x86.cache-2'
    ownership of
    `/var/cache/fontconfig/30786aca7a961ef9f9799e540455831d-x86.cache-2'
    ownership of
    `/var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-x86.cache-2'
    ownership of
    `/var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-x86.cache-2'
    ownership of
    `/var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-x86.cache-2'
    ownership of
    `/var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-x86.cache-2'
    ownership of `/var/cache/fontconfig' retained as squid:squid
    ownership of `/var/cache/hald/fdi-cache' retained as squid:squid
    ownership of `/var/cache/hald' retained as squid:squid
    ownership of `/var/cache/iptraf' retained as squid:squid
    ownership of `/var/cache/samba' retained as squid:squid
    ownership of `/var/cache/squid' retained as squid:squid
    ownership of `/var/cache' retained as squid:squid
    Depois: ls -la /var/cache
    total 16
    drwxr-xr-x 8 squid squid 48 2009-01-25 16:13 .
    drwxr-xr-x 17 root root 4096 2009-01-25 16:10 ..
    drwxrwxr-x 2 squid squid 1 2007-05-09 16:28 cups
    drwxr-xr-x 2 squid squid 4096 2009-01-27 15:20 fontconfig
    drwxr-xr-x 2 squid squid 16 2009-01-25 15:25 hald
    drwxr-xr-x 2 squid squid 1 2006-12-27 17:27 iptraf
    drwxr-xr-x 2 squid squid 1 2007-06-26 22:36 samba
    drwxrwxrwx 2 squid squid 1 2009-01-25 16:13 squid
    Acho que agora está com permissão correto?
    executei o comando squid -z para criar os diretórios depois mandei executar o squid
    com o squid -DYC, e não foi apresentado msg alguma quando dei o ps aux | squid tbm não
    mostrou nada.... creio que o squid não está sendo carregado.
    Alguém tem idéia do que pode ser?
    Abaixo mostro meu config.
    http_port 3128 transparent
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
    cache_mem 64 MB
    maximum_object_size 40 MB
    cache_swap_low 90
    cache_swap_high 95
    access_log access.log #se quiserem colocar o access.log basta criar o arquivo e dá permissão de escrita
    cache_store_log none
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    http_access allow all
    http_reply_access allow all
    icp_access allow all
    zph_tos_local 0x30
    zph_tos_peer 0
    zph_tos_parent off
    zph_preserve_miss_tos on
    forwarded_for off
    coredump_dir /var/cache/squid
    detect_broken_pconn on
    pipeline_prefetch on
    cache_effective_user squid
  2. infelizmnte, não.. o proprietario de /var/cache/squid é (supostamente) o squid mas os outros (cups, named, fonts, hald) NÃO ERAM. Vc mudou o usuário/grupo do conjunto todo e, provavelmente, muita coisa vai deixar de funcionar.
    Sugestão: reinstalação do sistema inteiro.
  3. Citação Postado originalmente por irado Ver Post
    Certo, você pode me passar um passo a passo de como eu posso fazer isso de forma correta?
    Ou me apontar um doc me mostre isso? já tentei seguir vários exemplos que achei na internet e nada de sucesso.
    Eu vou montar um cache full para rodar em paralelo com o mikrotik. A parte de config do mk ta tranquilo o problema é só o squid.
    Eu li sobre o Diskd e que melhora bastante o desempenho.
    Estou com uma máquina muito boa e gostaria de aproveita-la o máximo.
    O que puder fazer para me ajudar ficarei grato.
    Última edição por vialink; 28-01-2009 às 10:17.
  4. Citação Postado originalmente por irado Ver Post
    amigo, consegui instalar.
    Obrigado pela ajuda.
  1. squid
    Por rosane no fórum Servidores de Rede
    Último Post: 26-05-2006, 18:11
  2. Bridge + Iptables + Squid Remoto
    Por Machado no fórum Servidores de Rede
    Último Post: 26-08-2003, 09:04
  3. Squid
    Por mauri no fórum Servidores de Rede
    Último Post: 03-06-2002, 20:43
  4. Bloquear sites no squid - urgente
    Por bauer no fórum Servidores de Rede
    Último Post: 21-05-2002, 22:53
  5. Squid
    Por luiz_nando no fórum Servidores de Rede
    Último Post: 10-05-2002, 19:05
