    Padrão Scripts Prontos
    Um assunto ja discutido aqui várias vezes, mas muita gente ainda procura por scripts prontos para o mk, vou postar alguns e espero que possa ajudar alguém.
    OBS: Todos foram coletados aqui mesmo
    TODOS OS SCRIPTS DEVEM SER INSERIDOS VIA WINBOX NO MENU SYSTEM>SCRIPTS OU VIA "NEW TERMINAL" /
    system script
    SCRIPT PARA REBOOTAR AUTOMATICAMENTE
    l add name="reboot" source="/system reboot" \
    l policy=ftp,reboot,read,write,policy,test,winbox,pa ssword
    SCRIPT PARA PARA WEB-CACHE
    l add name="Parar_Proxy" source="/ip web-proxy set enabled=no" \
    SCRIPT PARA LIMPAR WEB-CACHE
    l add name="Limpar_Proxy" source="/ip web-proxy clear-cache" \
    SCRIPT PARA RECRIAR (RENICIALIZAR) WEB-CACHE
    l add name="Criar_Proxy" source="/ip web-proxy set enabled=yes" \
    SCRIPT PARA BACKUP AUTOMÁTICO DO MIKROTIK
    l add name="backup_diario" source="/sy ba sav name=mk_bkp.backup" \
    SCRIPTS PARA HABILITAR E DESABILITAR TODA A BANDA
    DESABILITA
    l add name="queue_disable" source="/queue simple { disable \[find \
    l name=LIBERA_TUDO\] }" \
    l policy=ftp,reboot,read,write,policy,test,winbox,password
    HABILITA
    l add name="queue_enable" source="/queue simple { enable \[find \
    AGENDAMENTOS ÚTEIS
    Devem ser aplicados via winbox (menus system>scheduler) ou via "new terminal" em / system scheduler
    AGENDAMENTO PARA REBOOT DE 15 EM 15 DIAS
    l add name="reboot" on-event=reboot start-date=nov/15/2006 start-time=06:05:00 \
    l interval=4w2d comment="REBOOT DE 15 EM 15 DIAS" disabled=no
    AGENDAMENTOS PARA MANUTENÇÃO AUTOMÁTICA DO WEB-PROXY (5 em 5 DIAS
    l add name="Parar_Proxy" on-event=Parar_Proxy start-date=nov/15/2006 \
    l start-time=05:00:00 interval=5d comment="" disabled=no
    l add name="Limpar_Proxy" on-event=Limpar_Proxy start-date=nov/15/2006 \
    l start-time=05:03:00 interval=5d comment="" disabled=no
    l add name="Criar_Proxy" on-event=Criar_Proxy start-date=nov/15/2006 \
    l start-time=05:10:00 interval=5d comment="MANUTEN O AUTOM TICA DO \
    WEB-PROXY" disabled=no
    AGENDAMENTO PARA BACKUP AUTOMÁTICO DE 6 EM 6 HORAS
    l add name="backup diario" on-event=backup_diario start-date=jan/16/2007 \
    l start-time=00:00:00 interval=6h comment="CRIA BACKUP DE 6 EM 6 HORAS" \
    l disabled=no
    Citação Postado originalmente por rps67 Ver Post
    system script
    DESABILITA
    HABILITA
    AGENDAMENTOS ÚTEIS
    l disabled=no
    Rapaz, estes scripts são pessoais meus. Até os nomes são iguais... Copiou de algum cliente meu, né?
    A maioria deles estão no manual passo a passo que eu criei de Mikrotik.
    Lembrando que cache não se limpa, por vista estes scripts para manutenção de cache não servem para nada.
    Última edição por catvbrasil; 13-03-2009 às 09:49.
    no inicio eu disse:
    Foram Coletados aqui mesmo CATV e não em clientes, so quiz dar uma ajuda a galera inciciante.
    Valeu ae ...... hehe !
    Padrão scripts
    quem criou esse script do proxy que não serve ?
    Citação Postado originalmente por pedrovigia Ver Post
    O script funciona perfeitamente.. A princípio a uns 3 anos atrás, acho que fui eu, pois incorporei eles no manual do MK, mas depois de muita pesquisa e um toque do amigo sérgio em um treinamento, resolvi tirá-los do manual do MK. Os scripts funcionam perfeitamente, só que no exemplo do manual, eles eram utilizados de forma incorreta.
    Padrão scripts
    se alguem precisar de mais scripts do que estes em Scripts - MikroTik Wiki tem vários...
