Página 5 de 5 PrimeiroPrimeiro 12345
  1. E galera meu problema ainda continua, estou achando que o unico jeito no momento e tentar dividir essas conexões em mais servidores, sera que consigo utilizar alguma técnica de balanceamento de carga com o squid olha o numero de conexoes
    bankai:/var/log/squid# netstat -nat | grep ":3128" |wc -l
    1514
    Segue a parte principal do meu squid.conf
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    acl apache rep_header Server ^Apache
    detect_broken_pconn on
    pipeline_prefetch on
    broken_vary_encoding allow apache
    cache_mem 512 MB
    cache_swap_low 95
    cache_swap_high 98
    memory_replacement_policy heap GDSF
    cache_replacement_policy heap LFUDA
    maximum_object_size 16384 KB
    maximum_object_size_in_memory 100 KB
    #logformat MEU_LOG IP do cliente: %>a - Username: %un - Horario: [%tl] - Metodo: %rm - URL: %ru - Status HTTP: %Hs - Status Squid: %Ss
    #access_log /var/log/squid/gerencia.log MEU_LOG
    access_log /var/log/squid/access.log squid
    #cache_dir diskd /var/spool/squid 2048 16 256
    cache_dir diskd /var/spool/squid01 1024 16 256 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid02 1024 16 256 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid03 1024 16 256 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid04 1024 16 256 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid05 1024 16 256 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid06 1024 16 256 Q1=64 Q2=72
    #dns_nameservers 172.17.0.1
    hosts_file /etc/hosts
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 81 # https
    acl SSL_ports port 563 # snews
    acl SSL_ports port 873 # rsync
    acl Safe_ports port 80 81 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl Safe_ports port 631 # cups
    acl Safe_ports port 873 # rsync
    acl purge method PURGE
    acl CONNECT method CONNECT
    ############### Autenticacao ###########################
    auth_param basic program /usr/lib/squid/msnt_auth
    auth_param basic children 8
    auth_param basic realm Lab. Info. Unicsul >> ENTRE COM SEU LOGIN E SENHA (O MESMO UTILIZADO PARA LOGAR NOS COMPUTADORES)
    auth_param basic credentialsttl 5 minutes
    acl limit_user max_user_ip -s 1
    acl usr_usuario proxy_auth REQUIRED
    abs
  2. Citação Postado originalmente por info24hs Ver Post
    Olha a anos atrás quando o html era puro eu acredito que este valor de 3k a 16k realmente era um valor médio, e pra quem tem 128mb de cache na ram acredito ser um valor pequeno.
    E se realmente o valor de 3k a 16k for um valor médio hj em dia não tem problema nenhum ter configurado um valor maior para suportar "poucos" arquivos maiores...
    Abraço..
    Observe que falo da média do tamanho dos OBJETOS, e nao de uma página inteira.
  1. squid muito lento
    Por jasonlinux no fórum Servidores de Rede
    Respostas: 5
    Último Post: 28-06-2007, 11:43
  2. squid nao fuciona "muito lento"
    Por fsoaress76 no fórum Servidores de Rede
    Respostas: 9
    Último Post: 04-12-2006, 17:22
  3. Squid muito lento
    Por b0rin no fórum Servidores de Rede
    Último Post: 30-08-2006, 04:21
  4. Squid Muito Lento
    Por MarceloPC no fórum Servidores de Rede
    Último Post: 05-10-2005, 09:35
  5. Squid muito lento...
    Por jadirorza no fórum Servidores de Rede
    Respostas: 8
    Último Post: 23-06-2005, 13:39
