    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão PCQ parâmetros e exemplos
    PCQ - Parâmetros e Exemplos.
    Usage:
    PCQ was introduced to optimize massive QoS systems, where most of the queues are exactly the same for different sub-streams. For example a sub-stream can be download or upload for one particular client (IP) or connection to server.
    PCQ algorithm is very simple - at first it uses selected classifiers to distinguish one sub-stream from another, then applies individual FIFO queue size and limitation on every sub-stream (witch is exactly the same for every sub-stream), then group all sub-streams together and apply global FIFO queue size and limitation
    PCQ parameters:
    • pcq-classifier (dst-address | dst-port | src-address | src-port; default: "") : selection of sub-stream identifiers
    • pcq-rate (number) : maximal available data rate of each sub-steam
    • pcq-limit (number) : queue size of one sub-stream in packets
    • pcq-total-limit (number) : queue size of global FIFO queue
    http://wiki.mikrotik.com/images/thum...px-PCQ_Alg.png
    So instead of having 100 queues with 1000kbps limitation for download we can have one PCQ queue with 100 sub-streams
    Classification Examples:
    To better understand classification we will take a list of 18 packet streams from specific address and port, to a specific address and port. Then we will choose a classifier and divide all 18 packet streams into PCQ sub-streams
    http://wiki.mikrotik.com/images/thum...Q_Example1.png
    http://wiki.mikrotik.com/images/thum...Q_Example2.png
    PCQ Rate Examples:
    Here it is possible to see what happens if PCQ-rate is, or isn't specified. I must noted that if both limits (pcq-rate and max-limit) are unspecified, queue behavior can be imprecise. So it is strongly suggested to have at least one of these options set.
    http://wiki.mikrotik.com/images/thum...500px-PCQ3.png
    http://wiki.mikrotik.com/images/thum...500px-PCQ4.png
    Última edição por Magal; 21-03-2009 às 11:10.
    Existe a possibilidade de usar PCQ + PPPOE + RADIUS?
    Muito bom, sera que tem como alguem explicar a parte onde vc coloca o PCQ em 0 e toda a banda sera dividida, e os e tabem o que é aquele limit e total limit, e se os valores colocados la são em kb. Obrigado!
    Tradução do texto do magal e comentários:
    PCQ - Traduzido e comentado por M4D3
    Padrão Resposta
    queue, queue type, + para nova, da um nome pra ela, escolhe pcq em general, em settings tu coloca limit 50 (ou zero se não quizer controlar o numero de filhos), total limit "0" <-- aqui
    Padrão Re: PCQ parâmetros e exemplos
    wiki.mikrotik.com
    Texto completamente retirado de lá
    coloque créditos velho!
    marcelofabio,
    Cara*** meu irmão, tu já ajudou alguém neste fórum, eu fico p*** da vida com este tipo de usu*SNO.
    Desculpa ae moderação, mas é froids...
    vc pode criar uma simple queue pra controlar todos pelo pcq ou tbm criar uma regra pra cada cliente marcando os pacotes que vc queira, tipo proxy.
    sim funciona sim
    Citação Postado originalmente por m4d3 Ver Post
    marcelofabio,
    Verdade, se não ajuda então não atrapalhe!
