    Aug 2007
    São Paulo, Brazil, Brazil
    Citação Postado originalmente por lelyrock Ver Post
    isso isso isso!rs
    sera q há alguma chance de criar um patch no thunder para isso?
    aproveitando....
    sera que alguem pode me ajudar nesse topico?
    Thunder Cache detalhado - Página 5
    Nao sei se é possivel nao, ai no caso só tentando fazer um plugin pra ver, no site do thunder tem ensinando como fazer um plugin, eu tentei fazer mais nao consegui :s,
    Sobre o topico que você pediu ajuda ja postei alguma coisa la
    Falow abraços
  2. #282
    Jul 6 09:10:20 justin kernel: [ 765.912829] ata1.00: status: { DRDY ERR }
    Jul 6 09:10:20 justin kernel: [ 765.912829] ata1.00: error: { UNC }
    Jul 6 09:10:20 justin kernel: [ 765.933961] ata1.00: configured for UDMA/133
    Jul 6 09:10:20 justin kernel: [ 765.933967] ata1: EH complete
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: BMDMA stat 0x24
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: cmd 25/00:08:b7:0d:0f/00:00:28:00:00/e0 tag 0 dma 4096 in
    Jul 6 09:10:24 justin kernel: [ 769.654224] res 51/40:00:bd:0d:0f/40:00:28:00:00/e0 Emask 0x9 (media error)
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: status: { DRDY ERR }
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: error: { UNC }
    Jul 6 09:10:24 justin kernel: [ 770.002100] ata1.00: configured for UDMA/133
    Jul 6 09:10:24 justin kernel: [ 770.002100] ata1: EH complete
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: BMDMA stat 0x24
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: cmd 25/00:08:b7:0d:0f/00:00:28:00:00/e0 tag 0 dma 4096 in
    Jul 6 09:10:27 justin kernel: [ 773.268897] res 51/40:00:bd:0d:0f/40:00:28:00:00/e0 Emask 0x9 (media error)
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: status: { DRDY ERR }
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: error: { UNC }
    Jul 6 09:10:27 justin kernel: [ 773.291928] ata1.00: configured for UDMA/133
    Jul 6 09:10:27 justin kernel: [ 773.291940] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
    Jul 6 09:10:27 justin kernel: [ 773.291945] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
    Jul 6 09:10:27 justin kernel: [ 773.291953] Descriptor sense data with sense descriptors (in hex):
    Jul 6 09:10:27 justin kernel: [ 773.291956] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
    Jul 6 09:10:27 justin kernel: [ 773.291974] 28 0f 0d bd
    Jul 6 09:10:27 justin kernel: [ 773.291981] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
    Jul 6 09:10:27 justin kernel: [ 773.291988] end_request: I/O error, dev sda, sector 672075197
    Jul 6 09:10:27 justin kernel: [ 773.292034] ata1: EH complete
    Jul 6 09:10:27 justin kernel: [ 773.292120] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    Jul 6 09:10:27 justin kernel: [ 773.294756] sd 0:0:0:0: [sda] 1465149168 512-byte hardware sectors (750156 MB)
    Jul 6 09:10:27 justin kernel: [ 773.751757] sd 0:0:0:0: [sda] Write Protect is off
    Jul 6 09:10:27 justin kernel: [ 773.751761] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    Jul 6 09:10:27 justin kernel: [ 773.751795] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    consegui colocar o Thunder aqui, funcionando perfeitamente, adequei o sistema a minha maquina, tal config como memoria, Espaço em HD e tudo mais, agora surgiu estes erros, alguem pode me dar uma dica? o servidor trava e para de responder qd segue estes erros...
  3. #283
    Aug 2007
    Citação Postado originalmente por raus Ver Post
    Raus, você desativou o orkut do thunder?
    Tenta desativar pode ser o orkut e ve se para
    Falow
  4. #284
    Citação Postado originalmente por edcomrocha Ver Post
    Falow
    Orkut desativado desde o principio...
    'fiz umas mudanças depois do post, parou um pouco e voltou com os erros, maquina zerada...
    vou ver q q agilizo por aqui, mais tarde volto a posta se resolver o problema, e quem ja sab o que e e quiser dar uma força, ficarei agradecido.
  5. #285
    Avatar de stevens144
    Oct 2007
    Campo Grande MS
    aqui to usando o orkut ta ok... mas queria usalo somente para fotos de alta resolucao! alguem tem esse plugin alterado?
  6. #286
    Citação Postado originalmente por stevens144 Ver Post
    No plugin do ortut tem referencia para as seguintes pastas
    $domain_small = "orkut/small";
    $domain_mili = "orkut/mili";
    $domain_klein = "orkut/klein";
    $domain_mittel = "orkut/mittel";
    $domain_albums = "orkut/albums";
    $domain_photos = "orkut/photos";
    $domain_medium = "orkut/medium";
    Acredito que é só comentar "#" a que você não quer fazer cache, falta só identificar quem é quem
  7. #287
    Aug 2008
    Araguari - Minas Gerais
    Citação Postado originalmente por eternal Ver Post
    Se comentar, vai dar erro no script, e o loader.php vai travar...
    Tem que editar o arquivo e remover as partes que não precisam, quem entende de php é fácil.
  8. #288
    Oct 2007
    Campo Grande MS
    Pois é to doido pra faze um curso de PHP... entendo pouco...
  9. #289
    Estou desenvolvendo um software aqui em php e estou tendo que aprender tudo como sempre, na leitura.
    Onde moro estes tipos de cursos não pitam e grana anda um tanto escaça.
    Desculpem aí por sair do propósito do forum.
  10. #290
    Oct 2007
    Campo Grande MS
    Citação Postado originalmente por Raniel Ver Post
    Intão tem até bastante cursos online... com um pouco de tempo da até pra arriscar aprender pela web... vi cursos de 19.90... fora material free que vc acha de quilo...
    em questao do plugin se nao me engano os caras fizeram um somente para as fotos de alta resolucao
  11. #291
    Thunder Cache funcionando 4 horas sem parar funciona perfeitamente,
    depois de este tempo +-, começa a dar pagina em branco nos clientes, ae tenho que desativar a regra que redireciona...
    Alguem ja passou por isso poderia dar uma dica?
    Tudo configurado de acordo com minhas necessidades e de acordo com o forum, Thunder.php, squid.conf, dentre outras...
    Obs: Li o topico por inteiro rsrsrs...
    Obrigado.
  12. #292
    Boa noite Pessoal, sou novo por aqui, nem sei se estou digitando no lugar certo, mais o que eu queria dizer a todos voces, é sobre as configuraçoes do Mikrotik, tenho uma rb1000 aqui para usar como servidor, quando comprei ela, pensei que fosse quase tudo automatico, que com o pouco de conhecimento que sei, conseguiria configura-la e pronto, assim fiz, maissssss: com um link dedicado de 2m full, quando pendurava uns 20 clientes saturava a banda, pesquisando aqui no forum, vi algumas dicas do Roberto21, resolvi entrar em contato com ele, e vou dizer a voces, ele configurou meu Mikrotik com algumas configuraçoes avançadas e virou o bicho, rs, alem do loadbalance que ele fez, configurou tambem meu firewall, minha rede virou outra coisa, ta leve e ainda tem as regras de prioridade para os serviços essenciais, ficou um serviço 100% profissional,
    e aproveito aqui a oportunidade de agradece-lo mais uma vez, pela atençao e agilidade, tornando meu pequeno provedor com qualidade de uma grande empresa, obrigado Roberto, que Deus continue te iluminando.
  13. #293
    Opa, tudo joia? To tendo problemas com o windows update, somente o windows xp não atualiza, ele fica abrindo a pagina e não vai pra frente.... já tentei tudo q é forma, mas ae qdo tiro do proxy ele funciona normalmente, o q pode ser isso???
    Obrigado!
  14. #294
    É isso ai, o Roberto é realmente uma pessoa com bastante conhecimento.Ele tb fez o meu serviço e ficou de "tirar o chapeu". Muito bom profissional.
  15. #295
    Padrão Video carrega a primeira vez
    Estou há alguns dias tentando instalar Thunder, mas sem sucesso.
    Acontece que o vídeo pode ser exibido por streaming na primeira vez em que é acessado. Na segunda vez, quando deveria vir do cache, aparece a famosa mensagem "An error occured, try again later". Mas até é possível visualizar o vídeo se esperar ele carregar ou avançando ele, clicando na barra do player. E pelo que pude perceber, o vídeo é baixado novamente da Internet, e não do cache. Na barra de status do navegador até aparece "Aguardando resposta de <IP DO SERVIDOR DE CACHE>"
    Alguém já esteve nesta situação? Como resolveu?
    Mais algumas dúvidas:
    * Na última versão do Thunder é necessário alterar alguma configuração do Apache?
    * No thunder.conf, qual a diferença entre usar 301, 302 ou deixar em branco?
    * Para usar um diretório diferente de /var/www/thunder para o $cache_dir, basta alterar no thunder.conf ou é preciso alterar mais alguma configuração?
    * Qual o usuario e grupo deve ter permissão de acesso ao diretorio do cache? root, www-data, ou qual?
    * As linhas de redirecionamento para o Thunder, no squid. conf, podem ficar todas no final do arquivo, depois de todo o resto?
    * Lí sobre umas modificações que ocorreram em relação ao youtube. Usando para instalação o arquivo que está atualmente no site do Thunder, preciso realizar alguma outra configuração manual, além do tutorial de instalação?
    Estou usando Ubuntu Server 8.04
    Desculpa se estas perguntas já foram respondidas. Costumo pesquisar e ler bastante antes de postar perguntas, mas desta vez não estou conseguindo encontrar as informações, me parecem muito fragmentadas pelos tópicos do fórum.
    E parabéns às pessoas que desenvolvem o Thunder e obrigado a todos que colaboram, respondendo às perguntas do fórum.
  16. #296
    O teu problema eh generico, precisa ver o teu log e ver o q tá acontecendo...
    nao
    301 e 302 são redirecionamentos, se deixar em branco, apesar de ser reescrita a url, nao vai aparecer isso para o cliente.
    aconselho a vc usar links para salvar em outro lugar, senao a parte de configuração vai t dar dor de cabeça
    www-data e squid
    pode
    precisa ser atualizado o thunder.lst, e tb o squid.conf, vide forum do thunder cache
  17. #297
    Citação Postado originalmente por ricardowz Ver Post
    Ver respostas do mestre acima, porém discordo de algumas delas...Acho necessário sim mudar alguns parâmetros do apache, do squid, do php, mas isso vai de pessoa para pessoa ou de thunder para thunder, um thunder para 800 clientes o apache não poderia ter a configuração default...iria travar...os limites do squid também são importantes, não do squid.conf, ainda o resolv.conf, alguns agendamentos no contrab, mas como disse isso vai de thunder para thunder...mas em todo caso pode considerar corretas as respostas do Rodrigo acima...
  18. #298
    Citação Postado originalmente por rodrigomanga Ver Post
    Aqui que me veio a duvida, eu alterei o meu mas quando fui lá estava em branco, nem tava 301 302 nem nada. E mesmo assim tava funcionado.
    Como somos tomé e o tuto mostrava isso na epoca deixei o 301.
    kakakakakak.
  19. #299
    Olá grande Roberto , no meu caso já tenho o servidor ubuntu 9.0 server todo configurado já com thunder e os pacotes que necessitam pra uso dele ok ! , meu cenário e o seguinte hoje uso um servidor MK 2.9 com Hotspot+Dhcp+stático e Cache+proxy , Mk ip 192.168.10.1 , e faixa dos clientes referente ip mk 10.1 , eu configurei o Thunder com ip 192.168.10,2 , o problema e o seguinte , servidor MK com 3 placas de redes 1 link adsl 6 megas 192.168.254.254 , a outra Faixa do mk 10.1 e a 3 placa coloquei pra interligar o SRV thunder . Minha duvida e que vi em outro post que posso ligar o thunder >>> mk por cabo cross ou até mesmo no switch , qual seria melhor solução e qual e o nat que eu faria pra todos meus clientes passar pelo thunder cache ? com as regras queue ? , uma coisa eu sei que terei que desabilitar o cache do mk pra não ficar confuso o proxy . abraços se puder dar essa dica ficarei grato .
  20. #300
    Analista de Suporte em Ti Avatar de rpclanhouse
    Sep 2008
    Suzano SP
    Citação Postado originalmente por Barone10 Ver Post
    Meu cenario é identico, porem , qdo logo no servidor thunder, ele até pinga endereços de internet, mas nao ta fazendo cache, onde será que errei, vou refazer agora com debian, vamos ver o q vai dar !
