Página 10 de 10 PrimeiroPrimeiro ... 5678910
  1. eu usei as seguintes configurações:
    / ip address
    add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local comment="" disabled=no
    add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=wlan2 comment="" disabled=no
    add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=wlan1 comment="" disabled=no
    / ip firewall mangle
    add chain=prerouting in-interface=Local connection-state=new nth=1,1,0 action=mark-connection new-connection-mark=odd passthrough=yes comment="" disabled=no
    add chain=prerouting in-interface=Local connection-mark=odd action=mark-routing new-routing-mark=odd passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=Local connection-state=new nth=1,1,1 action=mark-connection new-connection-mark=even passthrough=yes comment="" disabled=no
    add chain=prerouting in-interface=Local connection-mark=even action=mark-routing new-routing-mark=even passthrough=no comment="" disabled=no
    / ip firewall nat
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=10.111.0.2 to-ports=0-65535 comment="" disabled=no
    add chain=srcnat connection-mark=even action=src-nat to-addresses=10.112.0.2 to-ports=0-65535 comment="" disabled=no
    / ip route
    add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 routing-mark=odd comment="" disabled=no
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 routing-mark=even comment="" disabled=no
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 comment="" disabled=no
    amigo em uma o trafego esta bem alto 900kb e a outra nao passa de 90kb ok e isto se eu inverto o modem da o mesmo me ajude por favor preciso muito deste load balance.
    Última edição por andrelns; 04-09-2009 às 11:44.
  2. Neste momento não tenho como eu te ajudar !
    Mas faça assim me add no msn giovani.agco@ig.com.br, e assim que eu tiver disponivel eu coloco pra rodar junto contigo !
  3. Amigos estou com problemas para fazer um load balancing entre dois velox de 1 MB cada e ate agora o unico que tentou me ajudar foi o giovani pow galera da um forcinha ai gente ja encontrei varias maneiras de fazer um load balance mas nenhuma pegou ate agora ja faz umas duas semana que pesquiso e nada o giovani e indicou uns tutorias bons mais fiz tudo o que estava la e não deu certo vejan o que ta de errado
    olá amigo!
    você tem que ter 3 placas de rede na maquina !
    se for ADSL de operadoras diferentes utilize DNS publico !
    ex: primario 200.165.132.155
    secundario 200.149.55.142
    estes DNS Do VELOX .
    MUDEI O IP DOS MODEMS
    MODEM 1 PARA 10.111.0.1 LIGADO AO ether2
    MODEM 2 PARA 10.112.0.1 LIGADO AO ether2
    SEM DHCP
    Meus Modem Em ROUTER
    MUDEI OS NOMES DAS INTERFACE
    LOCAL PARA ether1
    LINK1 PARA ether2
    LINK2 PARA ether3
    Bom o comando a seguir você tem que digitar no terminal do mikrotik ou por SSH.
    lembrado que a cada diretorio diferente para os comandos você tem que iniciar uma sessão nova !
    2 ADSL
    / ip address
    add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=ether1 comment="" \
    disabled=no
    add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=ether2 \
    add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=ether3 \
    add chain=prerouting in-interface=ether1 connection-state=new nth=1,1,0 \
    action=mark-connection new-connection-mark=odd passthrough=yes comment="" \
    disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=odd action=mark-routing \
    add chain=prerouting in-interface=ether1 connection-state=new nth=1,1,1 \
    action=mark-connection new-connection-mark=even passthrough=yes comment="" \
    disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=even action=mark-routing \
    / ip firewall nat
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=10.111.0.2 \
    add chain=srcnat connection-mark=even action=src-nat to-addresses=10.112.0.2 \
    / ip route
    add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 routing-mark=odd \
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 routing-mark=even \
    add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 comment="" \
    disabled=no
    TA TUDO CERTO PORQUE NÃO PEGA ? ME AJUDEM POR FAVOR JA ESTOU ENLOUQUECENDO COM ESTE LOAD BALANCE PRECISO DELE COM HURGENCIA POIS MINHA REDE ESTA SUPERLOTADA UM DETALHE EU USO HOTSPOT SERA QUE E ISTO NÃO PODE TER HOTSPOT OU PODE OBG A TODOS ATE MAIS TCHAL
  4. Não te vejo on-line no msn !
  1. Erro de inicialização: an error occurred while mountg /media/sda1
    Por lukcruz no fórum Sistemas Operacionais
    Último Post: 25-01-2014, 15:32
  2. ROTEADOR GTS Telecom (urgente) preciso de ajuda!
    Por JECORDEIRO no fórum Redes
    Último Post: 11-08-2011, 21:57
  3. ajuda loadbalance controle de banda
    Por raswilson no fórum Redes
    Respostas: 9
    Último Post: 01-11-2010, 23:35
  4. Ajuda para configurar Super AP GTS
    Por batistaxande no fórum Redes
    Respostas: 8
    Último Post: 30-12-2009, 19:04
  5. FEDORA - error occurred during the file sistem check
    Por rfdasilva1 no fórum Servidores de Rede
    Último Post: 24-11-2004, 21:37
