PCC
  1. Citação Postado originalmente por exclusivenet Ver Post
    amigo, coloquei essa opção no meu mais não vai, na hora que habilito o hotspot, a rede para, continua em abrir a pagina de autenticação ..
    segue as regras novamente ..
    Código :
    /ip firewall nat
    add action=passthrough chain=unused-hs-chain comment=\
        "place hotspot rules here" disabled=yes
    add action=masquerade chain=srcnat comment="masquerade hotspot network" \
        disabled=no src-address=10.10.10.0/24
    add action=masquerade chain=srcnat comment="Mascaramento do PCC" disabled=no \
        out-interface=Oi_UP_512
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=\
        Oi_UP_256
    Código :
    /ip firewall mangle
    add action=mark-connection chain=input comment="" connection-state=new \
        disabled=no in-interface=Oi_UP_256 new-connection-mark=Oi_UP_256_conn \
        passthrough=yes
        disabled=no in-interface=Oi_UP_512 new-connection-mark=Oi_UP_512_conn \
        passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=\
        Oi_UP_256_conn disabled=no new-routing-mark=to_Oi_UP_256_conn \
        passthrough=yes
        Oi_UP_512_conn disabled=no new-routing-mark=to_Oi_UP_512_conn \
        passthrough=yes
    add action=accept chain=prerouting comment="" disabled=no dst-address=\
        189.80.16.80/29 in-interface=Rede_Local
        189.80.219.80/29 in-interface=Rede_Local
    add action=mark-connection chain=prerouting comment="" disabled=no \
        dst-address-type=!local in-interface=Rede_Local new-connection-mark=\
        Oi_UP_512_conn passthrough=yes per-connection-classifier=\
        both-addresses:2/0
        Oi_UP_256_conn passthrough=yes per-connection-classifier=\
        both-addresses:2/1
    add action=mark-routing chain=prerouting comment="" connection-mark=\
        Oi_UP_512_conn disabled=no in-interface=Rede_Local new-routing-mark=\
        to_Oi_UP_512_conn passthrough=yes
        Oi_UP_256_conn disabled=no in-interface=Rede_Local new-routing-mark=\
        to_Oi_UP_256_conn passthrough=yes
    Código :
    ip>route
    add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
        189.80.16.81 routing-mark=to_Oi_UP_256_conn scope=30 target-scope=10
    add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
        189.80.16.81 scope=30 target-scope=10
        189.80.219.81 routing-mark=to_Oi_UP_512_conn scope=30 target-scope=10
        189.80.219.81 scope=30 target-scope=10
    Código :
    /ip address
    add address=10.10.10.1/24 broadcast=10.10.10.255 comment=\
        "Rede Local - Clientes Rua" disabled=no interface=Rede_Local network=\
        10.10.10.0
    add address=189.80.16.82/29 broadcast=189.80.16.87 comment="Link Oi 256" \
        disabled=no interface=Oi_UP_256 network=189.80.16.80
    add address=189.80.219.82/29 broadcast=189.80.219.87 comment="Link Oi 512" \
        disabled=no interface=Oi_UP_512 network=189.80.219.80
    Amigo sinceramente n testei esse script do pcc com hotspot na mesma maquina, sei q no site internacional tem um script adptado por eles para funcionar hotspot e pcc na mesma maquina, de uma procurada la e adpte seu pcc para o mesmo q o deles, ou faça pcc separado do hotspot
  2. Grande tiagomatias, tenho uma web page em um servidor local, depois que coloquei o PCC rodar, não consigo acessar minha pagina externamente, quando desativo o PCC eu consigo acessar normalmente, tirei o ip que recebe as requisições externa com uma regra de accept e coloquei acima do PCC mais mesmo assim não vai de maneira alguma, tenho uma maquina exclusiva para o load, com 3 ADSL sendo 1 ip fixo(IP Profissional), meu load ta 100% poi fiço seguindo suas dicas, mais esse problema eu não consegui resolver...
    Se puder me dar uma mão eu agradeço!
  3. Citação Postado originalmente por rogeriodj Ver Post
    1 - qual esta sendo a rota padrão ?
    2 - poste a regra de redirecionamento de portas para esse servidor web
    3 - poste a regra de accept tirando o servidor web do balanceamento
  4. Citação Postado originalmente por tiagomatias Ver Post
    Tiago, muito obrigado .., vou tirar aqui da minha cabeça esse negocio de fazer o balance PCC e o hotspot na mesma maquina, vou começar a configurar um server novo para o hotspot agora, queria saber só se tem algum topico já aberto especifico, dizendo como fazer os 2 servidores se comunicar, para aproveitar o balance do primeiro servidor ?
    Ou eu teria um servidor normal, sendo que a WAN, seria a saida do loadbalance ? e a última, nesse servidor que será o load, eu poderia ter por exemplo um QoS também configurando juntamente com o load ? ou a maquina tem que ser especifica para load ?
    Agradeço desde já, e lá vai eu para a segunda madrugada seguida, lutando para montar esse sistema ..
    valeu a todos ..
  5. Citação Postado originalmente por exclusivenet Ver Post
    valeu a todos ..
    Ou eu teria um servidor normal, sendo que a WAN, seria a saida do loadbalance ? exatamente isso
    faça o QoS no seu servidor mikrotik. deixa o PCC apenas com as regras de PCC
  1. PCC Balance de 3 a 16 links - Por: M4D3
    Por m4d3 no fórum Redes
    Respostas: 509
    Último Post: 30-05-2016, 12:59
  2. Ajuda PCC Mikrotik
    Por marsilba no fórum Redes
    Respostas: 5
    Último Post: 19-09-2009, 20:32
  3. Problemas depois de implementar PCC
    Por antonoel no fórum Redes
    Último Post: 14-08-2009, 09:57
  4. Lentidão depois do PCC
    Por Evilazio no fórum Redes
    Respostas: 17
    Último Post: 04-08-2009, 22:56
  5. Respostas: 2
    Último Post: 24-07-2009, 19:11
