PCC
  1. apos inumeras revisoes e testes com as regras do m4d3 e do wiki pcc ainda nao consegui, mas vou conseguir, mas ate la se alguem puder me dar essa luz agradeço.
  2. opa galera... estou usando as regras do M4D3, e tenho notado que o uso do pppoe-out1 ta maior que do pppoe-out2... e sempre que abro o Meu ip - Qual é o Meu IP? 74.86.20.154, ele amostra o ip do pppoe-out2... engraçado neh? poiseh...
    Address-list:
    /ip firewall address-list
    add address=200.155.80.0-200.155.255.255 comment=BRADESCO disabled=no list=sem_balance
    add address=201.7.178.0/24 comment=\\\"Videos Globo.com\\\" disabled=no list=sem_balance
    add address=201.7.180.0/24 comment=\\\"\\\" disabled=no list=sem_balance
    add address=201.7.176.0/24 comment=\\\"\\\" disabled=no list=sem_balance
    add address=200.154.56.0/24 comment=\\\"Videos Terra\\\" disabled=no list=sem_balance
    add address=208.84.247.0/24 comment=\\\"\\\" disabled=no list=sem_balance
    Mangle:
    /ip firewall mangle
    add action=change-mss chain=forward comment=\\\"\\\" disabled=no new-mss=1360 out-interface=pppoe-out1 protocol=tcp tcp-flags=syn tcp-mss=1453-65535
    add action=change-mss chain=forward comment=\\\"\\\" disabled=no in-interface=pppoe-out1 new-mss=1360 protocol=tcp tcp-flags=syn tcp-mss=1441-65535
    add action=change-mss chain=forward comment=\\\"\\\" disabled=no new-mss=1360 out-interface=pppoe-out2 protocol=tcp tcp-flags=syn tcp-mss=1453-65535
    add action=change-mss chain=forward comment=\\\"\\\" disabled=no in-interface=pppoe-out2 new-mss=1360 protocol=tcp tcp-flags=syn tcp-mss=1441-65535
    add action=mark-routing chain=prerouting comment=\\\"\\\" connection-mark=Rota1 disabled=yes in-interface=EthClientes new-routing-mark=Rota1 passthrough=no
    add action=mark-routing chain=prerouting comment=\\\"\\\" connection-mark=Rota2 disabled=yes in-interface=EthClientes new-routing-mark=Rota2 passthrough=no
    add action=accept chain=prerouting comment=\\\"SEM BALANCE\\\" disabled=no dst-address-list=sem_balance in-interface=EthClientes
    add action=mark-connection chain=input comment=\\\"\\\" connection-state=new disabled=no in-interface=EthLinkA new-connection-mark=conn_na passthrough=yes
    add action=mark-connection chain=input comment=\\\"\\\" connection-state=new disabled=no in-interface=EthLinkB new-connection-mark=conn_nb passthrough=yes
    add action=mark-routing chain=output comment=\\\"\\\" connection-mark=conn_na disabled=no new-routing-mark=to_ra passthrough=no
    add action=mark-routing chain=output comment=\\\"\\\" connection-mark=conn_nb disabled=no new-routing-mark=to_rb passthrough=no
    add action=mark-connection chain=prerouting comment=\\\"\\\" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_ma0 \
    passthrough=yes per-connection-classifier=both-addresses:2/0
    add action=mark-connection chain=prerouting comment=\\\"\\\" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_mb1 \
    passthrough=yes per-connection-classifier=both-addresses:2/1
    add action=mark-routing chain=prerouting comment=\\\"\\\" connection-mark=conn_ma0 disabled=no in-interface=EthClientes new-routing-mark=to_nra passthrough=no
    add action=mark-routing chain=prerouting comment=\\\"\\\" connection-mark=conn_mb1 disabled=no in-interface=EthClientes new-routing-mark=to_nrb passthrough=no
    NAT:
    /ip firewall nat
    add action=masquerade chain=srcnat comment=\\"MASCARAMENTO PCC\\" disabled=no out-interface=pppoe-out1
    add action=masquerade chain=srcnat comment=\\"\\" disabled=no out-interface=pppoe-out2
    Routes
    /ip firewall nat
    add action=masquerade chain=srcnat comment=\\"\\" disabled=no dst-address=192.168.254.254 out-interface=EthLinkA
    add action=masquerade chain=srcnat comment=\\"\\" disabled=no dst-address=192.168.1.1 out-interface=EthLinkB
    Lembrando que sao 2 links de 1MB
    Imagem em anexo
    Anexo 8888
  3. Bom dia,
    otimo post...
    fiz o bal. pcc e funcionou perfeito, no notebook. quando coloca ele no servidor ele nao pinga na rb750....
    link 1 - 192.168.254.254
    link 2 - 192.168.1.1
    ip pcc rb 750 - 192.168.100.1
    coloco no notebook
    192.168.100.2
    255.255.255.0
    192.168.100.1
    192.168.100.1
    funciona o perfeito, pingo nos dois modens.
    quanbdo coloco no servidor, nao vai por nada
    ja fiz ip fixo, dhcp
    uso o dns da google
    se alguem puder ajudar
    agradeço denovo pelo Post
  4. Aproveitando o topico quero fazer uma pergunta pra voce Tiago.
    Estou instalando 7 Links Dedicado de 2MB de uma operadora só (Telemar-Oi), ja tenho os roteadores cada um de 2 MB, são 7 roteadores saindo 2MB cada um, te pergunto se tem como fazer um Load em um PC ou RB entrando os 7Links e saindo uma interface ou seja um ip tipo 192.168.1.1/30 com 14MB?
    Se tem e se não for pedir de mais gostaria que voce postasse as regras pra eu fazer aki.
    Desde já Agradeço.
  5. Citação Postado originalmente por willianrcn Ver Post
    Desde já Agradeço.
    Seguinte amigo,
    o PCC ele não soma os links. No caso ele não pega 2MB+2MB e vai dar 4MB, e sim balancea a carga entre os links, fazendo com que o consumo seja dividido entre todos eles. Mas se caso um cliente seu fazer um download e pegar do link A por exemplo, o máximo que vai chegar a taxa de transferencia dele é em cima de um circuito de 2MB.
    Existe uma forma de configurar para que some os links, mas mesmo assim vc terá q usar no cliente um gerenciador de download para dar a soma dos link, com por exemplo o orbit, download celerator "nem sei mais se existe esse" etc, mas fiz testes aqui e não gostei.
    E para vc fazer o pcc com 7 links acredito q olhando bem as regras que tem aqui vc consegue.
    abraços
  1. PCC Balance de 3 a 16 links - Por: M4D3
    Por m4d3 no fórum Redes
    Respostas: 509
    Último Post: 30-05-2016, 12:59
  2. Ajuda PCC Mikrotik
    Por marsilba no fórum Redes
    Respostas: 5
    Último Post: 19-09-2009, 20:32
  3. Problemas depois de implementar PCC
    Por antonoel no fórum Redes
    Último Post: 14-08-2009, 09:57
  4. Lentidão depois do PCC
    Por Evilazio no fórum Redes
    Respostas: 17
    Último Post: 04-08-2009, 22:56
  5. Respostas: 2
    Último Post: 24-07-2009, 19:11
