  1. Citação Postado originalmente por rpclanhouse Ver Post
    Aqui segui o topico de instalação do Thunder pelo Ubuntu, porém, tive que fazer umas adaptações, como utilizo hotspot, tive que adaptra mais um pouco rsrsrsr la vai :
    Mangle
    Código:
    / ip firewall mangle add chain=forward protocol=tcp content="X-Cache: HIT" action=mark-connection \ new-connection-mark=forward-hits passthrough=yes comment="Cache \ Full" disabled=no add chain=forward connection-mark=forward-hits action=mark-packet \ new-packet-mark=cache-hits passthrough=yes comment="" disabled=no add chain=forward protocol=tcp content="!THUNDER: THUNDER" \ action=mark-connection new-connection-mark=thunder-connection \ passthrough=yes comment="Thunder Cache Full" disabled=no add chain=forward protocol=tcp connection-mark=thunder-connection \ action=mark-packet new-packet-mark=thunder-packs passthrough=yes \ comment="" disabled=no add chain=forward dst-address=192.168.10.250 protocol=tcp dst-port=80 \ action=mark-connection new-connection-mark=thunder-connection \ passthrough=yes comment="Thunder - Cache Full" disabled=yes
    NAT
    Código:
    / ip firewall nat add chain=srcnat src-address=192.168.10.0/24 action=masquerade \ comment="masquerade hotspot network" disabled=no add chain=dstnat dst-address-list="Sem proxy" action=accept comment="Teste \ Aceitar Proxy" disabled=no add chain=dstnat src-address=192.168.0.0/24 dst-address=!192.168.10.250 \ protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.10.250 \ to-ports=3128 comment="Teste Redirecionamento Thunder" disabled=no add chain=srcnat src-address=192.168.0.0/24 action=masquerade comment="" \ disabled=no add chain=srcnat src-address=192.168.0.0/24 action=masquerade \ comment="masquerade hotspot network" disabled=no
    Filter
    Código:
    / ip firewall filter add chain=forward src-address=192.168.10.0/24 action=accept comment="Thunder \ " disabled=no
    Obs - Coloque esta regra acima das demais
    Crie uma Queue Com o nome Thunder ( ou algo que te faça lembrar rsrsrs ) em target address
    coloque o Ip do seu Proxy. eu no meu caso deixo Ilimitado .
    Lembre-se Os ips que coloquei são da minha faixa de rede, altere de acordo com suas necessidades.
    Aqui estou usando uma Bridge e tudo passa por ela .
    Já para Hotspot va em Ip=>Hotspot=>Server=>Profiles escolha seu Hostpot em HTTP Proxy, coloque o Ip do seu Debian e em Port coloque 3128 ( se vc seguiu o tuto de instalação do Ubuntu do Bil Gates ) vai funcioar certim ...
    Bom Domingo a todos .
    Amigo agradeço as regras mas creio que meu problema seja no servidor proxy porque o sintoma é exatamente o mesmo adicionando suas regras e como eu citei antes independente se usar o hotspot ou somente uma configuração basica o sintoma é o mesmo, da uma impressão que ha navegação mas demora cerca de um minuto e depois da um erro de referencia ao cache, mas nao sei o que é inclusive copiei exatamente como esta o arquivo na pagina postado pelo Bill e nada.
    o que acho muito engraçado é que os pings funcionam perfeitamente para qualquer site tanto do cache como do mikrotik é como se tivesse alguma regra impedindo a navegação no squid
  2. Citação Postado originalmente por geba3uer Ver Post
    Muito estranho mesmo pois estava com o mesmo problema e resolvi fazendo estas adaptações, mas beleza se conseguir, avisa aqui como fez bele? afinal pode ser o problema de muitos !
  3. Citação Postado originalmente por Demo Bill Ver Post
    Deu trabalho mais rodou aqui o hotspot em paralelo com o thunder nas v3.13 e 3.22, em breve posto um tutor.
    Vlw colega,creio que a unica adaptação para a perfeita integração do Proxy-Thunder + MK,deve ser feita no proprio MK msm...
    Quando puder,coloque alguma coisa...Ai posso ver certinho e adaptar como mais uma parte do tuto!
    Vlw...
  4. Citação Postado originalmente por geba3uer Ver Post
    Vamos la... vamos rever alguns detalhes:
    - Vc esta usando regras de conexões simultâneas?
    - Como esta seu firewall? Cheio de varias regras,?
    - Esta usando LoadBalance? Caso SIM,esta fazendo-o no mesmo MK onde entra o Proxy?
    - Que mascara esta usando no proxy e no mk? Caso use mascara /24 na faixa de rede de seus clientes,então use mascara /30 para conectar o Proxy ao MK.
    - A regra de redirecionamento para o proxy esta por ultima no NAT?
    - Setou corretamente as portas tanto no proxy,como no MK?
    Após rever algumas das dicas acima,caso ainda encontre problemas,post aqui como esta seu:
    /ip address
    /ip firewall rules
    /ip firewall nat
    /ip firewall mangle
    t+
  5. Iniciei um tutorial básico de como usar mais de um HD no proxy,caso alguém tenha alguma dúvida,pode estar acompanhando o tópico...
    O modo é bastante simples,mas eficaz...
    1 HD para o Sistema
    1 HD para o SquidCache
    1 HD para o ThunderCache
    Segue o Link: Clique aqui!
  1. Respostas: 12
    Último Post: 30-09-2009, 10:28
  2. Respostas: 0
    Último Post: 09-08-2009, 20:05
  3. Respostas: 0
    Último Post: 08-08-2009, 20:14
  4. Respostas: 0
    Último Post: 08-08-2009, 13:33
  5. Respostas: 0
    Último Post: 08-08-2009, 11:12
