  1. Citação Postado originalmente por Arlin Ver Post
    ja ta inndo de thunder 3 ou ainda não ?
    vo passar as regras de redirecionamento pra vc por ai no mk pra ver se funciona e me avise ok .
    /ip firewall connection tracking
    set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
    /ip firewall filter
    add action=accept chain=forward comment=\
    "Aceitar todos os tipos de conexoes ou pacotes que venham do proxy" \
    disabled=no src-address=192.168.6.0/30
    add action=drop chain=forward comment=\
    "Limite de 15 conexoes simultaneas por cliente" connection-limit=15,32 \
    disabled=no dst-address=!192.168.6.0/24 protocol=tcp src-address=\
    192.168.0.0/24 tcp-flags=syn
    "Bloqueio de usuarios por falta de pagamento.Suspensao" disabled=no \
    dst-port=81 protocol=tcp src-address-list=Bloqueio-Debito-Suspensao
    add action=accept chain=forward comment="" disabled=no dst-port=53 protocol=\
    udp src-address-list=Bloqueio-Debito-Suspensao
    add action=drop chain=forward comment="" disabled=no src-address-list=\
    /ip firewall mangle
    add action=mark-connection chain=prerouting comment="Squid - Cache Full" \
    disabled=no dscp=12 new-connection-mark=proxy-hits passthrough=yes
    add action=mark-packet chain=prerouting comment="" connection-mark=proxy-hits \
    disabled=no new-packet-mark=proxy-squid passthrough=no
    add action=mark-connection chain=prerouting comment="Thunder - Cache Full" \
    disabled=no dst-address=192.168.6.2 dst-port=80 new-connection-mark=\
    thunder-connection passthrough=yes protocol=tcp
    add action=mark-packet chain=prerouting comment="" connection-mark=\
    thunder-connection disabled=no new-packet-mark=thunder-packs passthrough=\
    no protocol=tcp
    add action=mark-connection chain=prerouting comment="Limite p2p" disabled=no \
    new-connection-mark="conex\E3o-p2p" p2p=all-p2p passthrough=yes
    "conex\E3o-p2p" disabled=no new-packet-mark=Pacotes-P2P passthrough=yes
    /ip firewall nat
    add action=masquerade chain=srcnat comment="NAT CLIENTES" disabled=no \
    out-interface=LINK src-address=192.168.0.0/24
    add action=masquerade chain=srcnat comment=\
    "Redirecionamento para pagina de aviso" disabled=yes src-address=\
    192.168.0.0/24
    add action=same chain=dstnat comment=\
    "Controle de clientes por falta de pagamento.Debito 15 dias de atraso" \
    disabled=no dst-port=80 protocol=tcp same-not-by-dst=no src-address-list=\
    Bloqueio-Debito to-addresses=192.168.6.2 to-ports=81
    add action=masquerade chain=srcnat comment="NAT THUNDER" disabled=no \
    add action=dst-nat chain=dstnat comment="Redirecionamento para o Proxy" \
    disabled=no dst-address=!192.168.6.2 dst-port=80 protocol=tcp \
    src-address=192.168.0.0/24 to-addresses=192.168.6.2 to-ports=3128
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=5060,5061
    set pptp disabled=no
    192.168.6.2 IP THUNDER 3
    192.168.0.0 IPs Clientes
    Então, fiz assim: instalei o Debian, baixei os pacotes com apt-get e apt get install, instalei o thunder do www.thundercache.org/repo/thundercachev21.tar e testei como está no topico, não foi! depois reinstalei, fiz tudo denovo e testei com suas regras, agora irei testar com o thunder 3 mas ta de rosca, rsrsrs o engraçado que na 2.cracked ia tranquilo . rsrs
    valeu amigo vou testando e postando ... como diria o silvio santos ! testannnndo e postannnnndo hahai !
  2. Citação Postado originalmente por Arlin Ver Post
    Arlin, consegui, fui até o fórum do TC3 Forum ThunderCache - View topic - [Tutorial] Instalando/Migrando para Thunder 3, consegui juntamente com as dicasdo "Osmano" e sua grande ajuda, que se não fosse por vc não estaria rodando, integrar o sistema Paralelo. Basta agora, fazer algumas alterações para minhas necessidades. Valeu mesmo amigo.
  3. Citação Postado originalmente por rpclanhouse Ver Post
    então deu certo ?
    muito bem faça com o thunder 3 pois ta muito bom ele qual quer coisa estamos por ai ok falow
  4. Citação Postado originalmente por Arlin Ver Post
    então deu certo ?
    Vamos lá ao que eu fiz, :
    Instalei o Debian 5.02
    após instalar dei um apt-get update
    deposi apt-get install squid apache2 php5 php5-cli iptraf ssh
    dai utilizei o thunder da pcram : wget http://pcram.com.br/conlinux/conlinuxZ4.sh
    depois : dei a permissão chmod +x conlinuxZ4.sh
    e executei ./conlinux.Z4.sh
    segui a instalação na tela que foi muito rapido e reiniciei !
    pronto, primeira parte pronta !
    No Mk :
    Ip-firewall - mangle
    ;;;;Marca o Squid & Thunder
    chain=forward action=mark-connection new-connection-mark=Squid-Conection
    passthrough=yes protocol=tcp src-address=192.168.0.0/24 src-port=3128
    content=X-Cache: HIT
    chain=forward action=mark-packet new-packet-mark=Squid-Packets
    passthrough=no connection-mark=Squid-Conection
    Ip firewall nat
    ;;;;Redirecionamento para o Proxy
    chain=dstnat action=dst-nat to-addresses=192.168.10.250 to-ports=3128
    protocol=tcp src-address=192.168.0.0/24 dst-address=!192.168.6.2
    dst-port=80
    ;;;;NAT THUNDER
    chain=srcnat action=masquerade src-address=192.168.10.0/24
    ;;;;Aceitar todos os tipos de conexoes ou pacotes que venham do proxy
    chain=forward action=accept src-address=!192.168.10.0/24 ( aqui enquanto não marquei a "!" não ia nem por decreto. )
    agora ta rodando de boa, valeu mesmo pela sua atenção. e a partir de sexta serei mais um colaborador do projeto thunder.
    Abraços a todos e principalmente ao Bill, pleo ótimo post, ao Osmano pelo trabalho perfeito, e à vc Arlin pela paciencia. Me perdoe por chama-lo na Mp.
    Ps- só nao achei ainda onde colocar os banners de publicidade.
    Fiquem com Deus
    Ricardo Sobrinho.
  5. os baners de bublicidades vc cria no squid.conf
    #Publicidade no MSN
    acl ADSAdClient url_regex ADSAdClient31.dll
    http_access deny ADSAdClient
    deny_info http://192.168.6.2:85/msn.gif ADSAdClient
    #Publicidade no Orkut
    acl ork.users url_regex ork.users
    http_access deny ork.users
    deny_info http://192.168.6.2:85/orkut.jpg ork.users
    #Publicidade no Google
    acl Google url_regex /pt-BR_br/images/logo.gif
    http_access deny Google
    deny_info http://192.168.6.2:85/google.jpg Google
    cria as portas e as pastas como no tutorial do bill gates do thunde 2 que é a mesma coisa do thunder 3 a publicidade falow
  1. Respostas: 12
    Último Post: 30-09-2009, 10:28
  2. Respostas: 0
    Último Post: 09-08-2009, 20:05
  3. Respostas: 0
    Último Post: 08-08-2009, 20:14
  4. Respostas: 0
    Último Post: 08-08-2009, 13:33
  5. Respostas: 0
    Último Post: 08-08-2009, 11:12
