  1. Feche o squid primeiro, depois inicie do terminal com squid -d5
    O loader.php aqui não funcionava, vamos ver se é o mesmo bug.
  2. root@palmito:~# /etc/init.d/squid status
    * squid is not running
    root@palmito:~# squid -d5
    root@palmito:~# 2009/08/24 20:46:25| Starting Squid Cache version 2.7.STABLE3 for i386-debian-linux-gnu...
    2009/08/24 20:46:25| Process ID 4115
    2009/08/24 20:46:25| With 1024 file descriptors available
    2009/08/24 20:46:25| Using epoll for the IO loop
    2009/08/24 20:46:25| Performing DNS Tests...
    2009/08/24 20:46:25| Successful DNS name lookup tests...
    2009/08/24 20:46:25| DNS Socket created at 0.0.0.0, port 38914, FD 6
    2009/08/24 20:46:25| Adding nameserver 189.7.40.15 from /etc/resolv.conf
    2009/08/24 20:46:25| Adding nameserver 189.7.40.16 from /etc/resolv.conf
    2009/08/24 20:46:25| helperOpenServers: Starting 200 'loader.php' processes
    2009/08/24 20:46:47| User-Agent logging is disabled.
    2009/08/24 20:46:47| Referer logging is disabled.
    2009/08/24 20:46:47| logfileOpen: opening log /var/log/squid/access.log
    2009/08/24 20:46:47| Unlinkd pipe opened on FD 211
    2009/08/24 20:46:47| Swap maxSize 4194304 KB, estimated 322638 objects
    2009/08/24 20:46:47| Target number of buckets: 16131
    2009/08/24 20:46:47| Using 16384 Store buckets
    2009/08/24 20:46:47| Max Mem size: 16384 KB
    2009/08/24 20:46:47| Max Swap size: 4194304 KB
    2009/08/24 20:46:47| Local cache digest enabled; rebuild/rewrite every 3600/3600 sec
    2009/08/24 20:46:47| logfileOpen: opening log /var/log/squid/store.log
    2009/08/24 20:46:47| Rebuilding storage in /var/spool/squid (CLEAN)
    2009/08/24 20:46:47| Using Least Load store dir selection
    2009/08/24 20:46:47| Current Directory is /root
    2009/08/24 20:46:47| Loaded Icons.
    2009/08/24 20:46:52| Accepting transparently proxied HTTP connections at 0.0.0.0, port 3128, FD 213.
    2009/08/24 20:46:52| Accepting ICP messages at 0.0.0.0, port 3130, FD 214.
    2009/08/24 20:46:52| HTCP Disabled.
    2009/08/24 20:46:52| WCCP Disabled.
    2009/08/24 20:46:52| Ready to serve requests.
    2009/08/24 20:46:52| Done reading /var/spool/squid swaplog (2535 entries)
    2009/08/24 20:46:52| Finished rebuilding storage from disk.
    2009/08/24 20:46:52| 2535 Entries scanned
    2009/08/24 20:46:52| 0 Invalid entries.
    2009/08/24 20:46:52| 0 With invalid flags.
    2009/08/24 20:46:52| 2535 Objects loaded.
    2009/08/24 20:46:52| 0 Objects expired.
    2009/08/24 20:46:52| 0 Objects cancelled.
    2009/08/24 20:46:52| 0 Duplicate URLs purged.
    2009/08/24 20:46:52| 0 Swapfile clashes avoided.
    2009/08/24 20:46:52| Took 5.5 seconds ( 458.3 objects/sec).
    2009/08/24 20:46:52| Beginning Validation Procedure
    2009/08/24 20:46:52| Completed Validation Procedure
    2009/08/24 20:46:52| Validated 2535 Entries
    2009/08/24 20:46:52| store_swap_size = 27824k
    2009/08/24 20:46:53| storeLateRelease: released 0 objects
    dai continuo abrindo aquele tanto de processo...
    dai vi que esta abrindo 200 processos eu alterei na configuração do squid(squid.conf)
    estava assim redirect_children 200 (mudei para 10) abriram 10 processos agora ....
    acho que isso nao deveria fazer isso nao.... deveria?? o.O'
    Description redirect_children
    This tag is used to set the number of redirect processes to spawn
  3. Essa qntidade de loader.php acontecia com uma versão anterior do thunder, mas ja foi solucionado, utilize a ulltimo thunder postado no repositorio Index of /repo se continuar, verefique as permissões do loader.php, e do downloader.php, e nao esqueça de fazer os links simbolicos do thunder.php, thundercache.php e thunder.css para a pasta var/www .... outro detalhe é ver a configuração do seu thunder.conf, posta ele.
    Boa sorte
  4. Citação Postado originalmente por paulojrandrade Ver Post
    Boa sorte
    pois é to usando aquele thunder cache v21 as permissões certas e os link's tbm foram criados ... o.O'
    mas ainda ta abrindo 10 processos iguais mencionei ... ingraçado !!!
    thunder.conf
    <?php
    * This program is free software; you can redistribute it and/or modify
    * it under the terms of the GNU General Public License as published by
    * the Free Software Foundation; either version 2 of the License, or
    * (at your option) any later version.
    * This program is distributed in the hope that it will be useful,
    * but WITHOUT ANY WARRANTY; without even the implied warranty of
    * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    * GNU Library General Public License for more details.
    * You should have received a copy of the GNU General Public License
    * along with this program; if not, write to the Free Software
    * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
    * (C) Copyright 2008-2009 Thunder Cache
    * For more information check http://thundercache.org
    * Configurations of system
    * @author rodrigo manga <rodrigomanga@yahoo.com.br>
    $cache_dir = "/var/www/thunder";
    $disk_max = 80; // in percent
    $cache_scr = "/etc/squid";
    $server_ip = "189.35.169.62";
    $cache_url = "http://$server_ip/thunder";
    $download_speed = 1024; // kbytes
    $logadd_on = false;
    $redir = ""; // keep empty if you need a internal rewriter
    $proxy_host = ""; // keep it empty if you dont need proxy
    $proxy_port = "3128";
    //limpeza
    $time_delete = 15; // in Day
    $disk_limit = 60; // in percent
    $list_files = 50; // in number
    //advanced params - IF YOU DONT KNOW, DONT TOUCH!
    $packet_size = 5900; // in bytes
    $packet_delay = 60000; // time in micro second
    $download_timeout = 25;
  5. Citação Postado originalmente por netscaper Ver Post
    2009/08/24 19:41:42| Squid is already running! Process ID 2106
    sem o loader.php !
    e executar o loader.php acontece nada !!
    Demorei muito, né?! Mas vamos lá.
    Primeiro instale o php-cli e/ou certifique-se que ele está operante em seguida derrube o squid com um
    Código :
    killall -s9 squid
    e aí sim execute
    Código :
    squid -d5
  1. Respostas: 14
    Último Post: 23-07-2011, 01:11
  2. Mk + Squid Paralelo + Thunder Cache
    Por macewindu no fórum Redes
    Respostas: 6
    Último Post: 18-09-2010, 10:17
  3. Proxy (Squid + Thunder Cache) bloqueando acesso ?
    Por prgcao no fórum Servidores de Rede
    Respostas: 8
    Último Post: 07-04-2010, 01:02
  4. Squid+Thunder Cache
    Por sunnetwork no fórum Redes
    Último Post: 08-09-2009, 22:01
  5. Respostas: 44
    Último Post: 30-08-2009, 15:49
