  1. Código :
    Squid Object Cache: Version 2.7.STABLE6
    Start Time:     Wed, 02 Sep 2009 05:24:48 GMT
    Current Time:   Wed, 02 Sep 2009 22:23:27 GMT
    Connection information for squid:
            Number of clients accessing cache:      0
            Number of HTTP requests received:       785185
            Number of ICP messages received:        0
            Number of ICP messages sent:    0
            Number of queued ICP replies:   0
            Number of HTCP messages received:       0
            Number of HTCP messages sent:   0
            Request failure ratio:   0.00
            Average HTTP requests per minute since start:   770.8
            Average ICP messages per minute since start:    0.0
            Select loop called: 12315310 times, 4.963 ms avg
    Cache information for squid:
            Request Hit Ratios:     5min: 14.6%, 60min: 23.8%
            Byte Hit Ratios:        5min: 18.3%, 60min: 25.9%
            Request Memory Hit Ratios:      5min: 13.0%, 60min: 8.6%
            Request Disk Hit Ratios:        5min: 56.6%, 60min: 52.8%
            Storage Swap size:      124415996 KB
            Storage Mem size:       32696 KB
            Mean Object Size:       29.83 KB
            Requests given to unlinkd:      0
    Median Service Times (seconds)  5 min    60 min:
            HTTP Requests (All):   0.00767  0.19742
            Cache Misses:          0.00678  0.33943
            Cache Hits:            0.05046  0.06640
            Near Hits:             2.79397  0.55240
            Not-Modified Replies:  0.00091  0.00091
            DNS Lookups:           0.00489  0.00278
            ICP Queries:           0.00000  0.00000
    Resource usage for squid:
            UP Time:        61118.639 seconds
            CPU Time:       4615.048 seconds
            CPU Usage:      7.55%
            CPU Usage, 5 minute avg:        16.50%
            CPU Usage, 60 minute avg:       12.95%
            Process Data Segment Size via sbrk(): 438812 KB
            Maximum Resident Size: 0 KB
            Page faults with physical i/o: 12925
    Memory usage for squid via mallinfo():
            Total space in arena:  438812 KB
            Ordinary blocks:       437480 KB   2021 blks
            Small blocks:               0 KB      0 blks
            Holding blocks:         11252 KB      4 blks
            Free Small blocks:          0 KB
            Free Ordinary blocks:    1331 KB
            Total in use:          448732 KB 100%
            Total free:              1331 KB 0%
            Total size:            450064 KB
    Memory accounted for:
            Total accounted:       366762 KB
            memPoolAlloc calls: 134190925
            memPoolFree calls: 121548593
    File descriptor usage for squid:
            Maximum number of file descriptors:   1024
            Largest file desc currently in use:    247
            Number of file desc currently in use:  203
            Files queued for open:                   0
            Available number of file descriptors:  821
            Reserved number of file descriptors:   100
            Store Disk files open:                   8
            IO loop method:                     poll
    Internal Data Structures:
            4173327 StoreEntries
              5025 StoreEntries with MemObjects
              4951 Hot Object Cache Items
            4170889 on-disk objects
  2. pirigoso, recompila teu proxy pra usar epoll !!
  3. Alexandre,
    Muito obrigado pelo comando, observe:
    Request Hit Ratios: 5min: 10.5%, 60min: 10.3%
    Byte Hit Ratios: 5min: 6.4%, 60min: 11.3%
    Está muito fraco meu cache, como eu faço para dar um otimizada?
  4. isso depende muito do perfil dos usuarios, quantidade de trafego..
    ativa isto:
    reload_into_ims on
    e espera um tempo.. deve subir um pouco os HITS
  1. Problemas no squid com a porta 8088
    Último Post: 17-02-2003, 08:42
  2. Squid com autenticação Samba automatica!
    Por sublinux no fórum Servidores de Rede
    Último Post: 21-01-2003, 08:41
  3. Squid com smb_auth!
    Respostas: 8
    Último Post: 17-01-2003, 08:45
  4. Desafio Ftp no squid com autenticação
    Por MiddleEarth no fórum Servidores de Rede
    Último Post: 09-01-2003, 16:15
  5. Squid com autenticação
    Último Post: 19-12-2002, 17:04
