  1. Apos ler quase que por completo esse topico. E ver a duvida de geral acabei chegando nessa configuração que esta me atendendo bem.
    Código :
    add action=mark-routing chain=output comment="" connection-mark=conn_na disabled=no new-routing-mark=to_ra passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=conn_nb disabled=no new-routing-mark=to_rb passthrough=no
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_ma0 passthrough=yes per-connection-classifier=both-addresses:2/0
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_mb1 passthrough=yes per-connection-classifier=both-addresses:2/1
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_ma0 disabled=no in-interface=EthClientes new-routing-mark=to_nra passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mb1 disabled=no in-interface=EthClientes new-routing-mark=to_nrb passthrough=no
    / ip firewall nat
    add action=masquerade chain=srcnat comment="MASCARAMENTO PCC" disabled=no out-interface=pppoe-out1
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=pppoe-out2
    / ip route
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
    add comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_nra scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_nrb scope=30 target-scope=10
    Pesquisando um pouco mais no forum e no wiki internacional do MK acabei me deparando com essa configuração aqui.
    Código :
    / ip firewall mangle
    add chain=prerouting dst-address=10.111.0.0/24  action=accept in-interface=LAN
    add chain=prerouting dst-address=10.112.0.0/24  action=accept in-interface=LAN
    add chain=prerouting in-interface=pppoe-out1 connection-mark=no-mark action=mark-connection \
        new-connection-mark=conn_na
    add chain=prerouting in-interface=pppoe-out2 connection-mark=no-mark action=mark-connection \
        new-connection-mark=conn_nb
    add chain=prerouting  in-interface=EthClientes connection-mark=no-mark dst-address-type=!local \ per-connection-classifier=both-addresses:2/0action=mark-connection new-connection-mark=conn_ma0
        per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=conn_mb1
    add chain=prerouting connection-mark=conn_na in-interface=EthClientes action=mark-routing \
    add chain=prerouting connection-mark=conn_nb in-interface=EthClientes action=mark-routing \
    add chain=output connection-mark=conn_na action=mark-routing new-routing-mark=to_ra
    add chain=output connection-mark=conn_nb action=mark-routing new-routing-mark=to_rb
    / ip route
    add dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_ra check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_rb check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=pppoe-out1 distance=1 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=pppoe-out2 distance=2 check-gateway=ping
    / ip firewall nat
    add chain=srcnat out-interface=pppoe-out1 action=masquerade
    add chain=srcnat out-interface=pppoe-out2 action=masquerade
    minha duvida é. qual seria a difereneça de uma para a outra? por que ao analizar ela vejo que a marcação de pacotes são diferentes e algumas outras coisas.
    Desde ja agradeço pela atenção.
  2. Fala galera, estou aqui novamente!!!
    Bom meu PCC depois das ultimas duvidas q o Aka2005 e o Geek me resolveu em relacao a o DNS, esta perfeito desde janeiro.
    Volte e meia tenho problemas com alguns sites, mais ai tiro do balanceador e fica td ok.
    Bom eu estava aqui analisando, e percebi q o link DSL soh fica ruim, quando o upload sobe muito. Ex.: Aqui to usando um dedicado de 10mb up e down, e dois DSL de 8mb. Bom os DSL 8mb ele chega ate 800kbps de up, porem quando passa dos 400kbps ele sobe a latencia e o ping sobe e consequentemente, sobe de todos que estao saindo por ele no momento.
    Bom ai pensei, e se limitar o upload do DSL para 400kbps!!!? Como tenho 10mb de up no link dedicado, acho que nao terei problemas pois o PCC ira balancear o up!!
    Bom tentei aqui, criei uma QUEUE para o discador pppoe, nao deu certo! Criei tbm uma queue para a interface do DSL e tbm nao deu certo!
    Fui na interface, achei uma opcao de Bandwidth tentei limitar o upload em 400kbps e tbm nao deu certo!!!
    Esse nao deu certo que falo é que nem chegou a discar o pppoe para o DSL. É soh eu limitar a banda que ele nao disca!!
    Bom entao estou aqui perguntando a vcs, se tem como eu limitar a banda UP do meu link DSL que esta em modo bridge discando pppoe????
    Eu pensei em colocar uma RB antes para discar e limitar o PPPoE do DSL, mas nao fiz o teste ainda. Se caso ninguem souber como limitar o upload direto da router que disca, irei fazer esse teste com outra RB.
    Aguardo. Obrigado.
  3. Parabéns pelo tópico muito bem explicado.
    Tenho uma dúvida pois no meu caso tenho 3 Links dedicado + 1 link PTT na seguinte forma:
    Operadora A 50 Mbps
    Operadora B 50 Mbps
    Operadora C 30 Mbps
    Link PTT 20 Mbps
    Como posso fazer um loadbalance nesse caso pois todos meus clientes utilizam meus IPs de minha AS.
    Como fazer Loand Balance com BGP com 4 links diferentes usando IPs públicos de uma AS sem fazer mascarade ???
  4. Parabéns pelo tópico muito bem explicado.
    Operadora A 50 Mbps
    Operadora B 50 Mbps
    Operadora C 30 Mbps
    Link PTT 20 Mbps
  5. Eduardo, procura pelos artigos do Julião Braga (abraço julião), tem material suficiente pra escrever um livro, ou pra resolver o seu problema se assim preferir.
    O alexandre também escreveu aqui no fórum sobre o prepeend no bgp, tem diversos artigos abordando isso aqui no underlinux.
    Valeu
  1. Respostas: 12
    Último Post: 15-05-2015, 17:14
  2. Respostas: 6
    Último Post: 08-03-2015, 02:04
  3. Respostas: 2
    Último Post: 18-06-2014, 16:27
  4. Respostas: 273
    Último Post: 20-09-2012, 10:39
  5. duvida sobre link dedicado por balance de operadora
    Por boneco no fórum Servidores de Rede
    Respostas: 13
    Último Post: 05-05-2011, 18:07
