  1. Coloquei assim da uma olhada vê se tem alguma coisa errada !
    Segue abaixo as regras:
    /ip firewall mangle
    add action=mark-connection chain=postrouting comment=\
    "MARCA\C7\C3O COM E SEM ( TOS )" disabled=no dscp=12 new-connection-mark=\
    n-cache passthrough=yes protocol=tcp src-port=3128
    add action=mark-connection chain=postrouting comment="" disabled=no dscp=!12 \
    new-connection-mark=s-cache passthrough=yes protocol=tcp src-port=3128
    add action=mark-packet chain=postrouting comment="CACHE FULL (( MK-AUTH ))" \
    connection-mark=n-cache disabled=no new-packet-mark=Cache-Packet \
    passthrough=no
    add action=mark-connection chain=prerouting comment="QoS - Http" disabled=no \
    dst-port=80 new-connection-mark=conexao-http passthrough=yes protocol=tcp
    add action=mark-packet chain=prerouting comment="" connection-mark=\
    conexao-http disabled=no new-packet-mark=pacotes-http passthrough=yes
    add action=mark-connection chain=prerouting comment="QoS - MSN" disabled=no \
    dst-port=1863 new-connection-mark=Messenger-Conexao passthrough=yes \
    protocol=tcp
    add action=mark-connection chain=prerouting comment="" disabled=no dst-port=\
    1863 new-connection-mark=Messenger-Conexao passthrough=yes protocol=udp
    6891-6901 new-connection-mark=Messenger-Conexao passthrough=yes protocol=\
    tcp
    udp
    5190 new-connection-mark=Messenger-Conexao passthrough=yes protocol=udp
    Messenger-Conexao disabled=no new-packet-mark=Messenger-Pacotes \
    passthrough=no
    add action=change-mss chain=forward comment="Alterar MSS do MSN para 1440" \
    disabled=no dst-port=1863 new-mss=1440 protocol=tcp tcp-flags=syn \
    tcp-mss=1441-65535
    Agora só falta eu montar o queue Tree
Nome:	         1.jpg
Visualizações:	184
Tamanho: 	68,5 KB
  2. Montei um queue tree aqui vê se esta certo ! ?
Nome:	         2.jpg
Visualizações:	118
Tamanho: 	39,9 KB
  3. Pronto.. As suas configurações estão corretas!
    Seguem as configurações da minha queue tree dos pacotes de HTTP e MSN:
    name="QoS - 1" parent=global-total packet-mark="" limit-at=0 priority=1
    max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
    name="1-Messenger" parent=QoS - 1 packet-mark=Messenger-Pacotes limit-at=>
    queue=default priority=1 max-limit=0 burst-limit=0 burst-threshold=0
    burst-time=0s
    name="7-Http-Geral" parent=QoS - 1 packet-mark=pacotes-http limit-at=0
    queue=default priority=7 max-limit=0 burst-limit=0 burst-threshold=0
    burst-time=0s
    Última edição por lessa; 06-01-2010 às 15:34.
  4. Beleza Se pode posta ai qual foi a marcação que vc fez. no Mangle do QOS ! porque para mim montar esse queue tree preciso da marcação do qos no mangle ! como segue ai nas suas regras !
  5. Segue o passo-a-passo detalhado:
    :: QOS HTTP
    1º - Marca os pacotes HTTP porta 80:
    / ip firewall mangle
    add chain=prerouting protocol=tcp dst-port=80 action=mark-connection \
    new-connection-mark=http_conn passthrough=yes comment="MARCA PACOTES HTTP" \
    disabled=no
    add chain=prerouting connection-mark=http_conn action=mark-packet \
    new-packet-mark=http passthrough=yes comment="" disabled=no
    2º - Cria a queue tree com reserva de banda desejada e prioriza em 1 ou 2:
    / queue tree
    add name="HTTP_down" parent=global-in packet-mark=http limit-at=100000 queue=default priority=2 max-limit=256000 \
    burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    :: QOS MSN
    ip firewall mangle
    add chain=prerouting protocol=tcp src-port=1863 action=mark-packet new-packet-mark=msn-out passthrough=yes comment="MSN" \
    disabled=no
    add chain=prerouting protocol=tcp dst-port=1863 action=mark-packet new-packet-mark=msn-in passthrough=yes comment="" \
    disabled=no
    add chain=forward protocol=tcp tcp-flags=syn action=change-mss new-mss=1360 comment="" disabled=no
    queues tree
    add name="msn-in" parent=global-in packet-mark=msn-in limit-at=256000 queue=default priority=1 max-limit=256000 \
    add name="msn-out" parent=global-out packet-mark=msn-out limit-at=300000 queue=default priority=1 max-limit=300000 \
    :: QOS VOIP
    new-connection-mark=teste passthrough=yes comment="PORTAS ALTAS - VOIP" \
    disabled=no
    add chain=prerouting connection-mark=teste action=mark-packet \
    new-packet-mark=teste2 passthrough=yes comment="" disabled=no
    add chain=prerouting protocol=udp src-port=1571 action=mark-connection \
    new-connection-mark=voip_out passthrough=yes comment="VOIP-OUT" \
    disabled=no
    add chain=prerouting connection-mark=voip_out action=mark-packet \
    new-packet-mark=VOIP_OUT passthrough=yes comment="" disabled=no
    add chain=prerouting protocol=udp src-port=5060 action=mark-connection \
    new-connection-mark=voip_in passthrough=yes comment="VOIP-IN" disabled=no
    add chain=prerouting connection-mark=voip_in action=mark-packet \
    new-packet-mark=VOIP_IN passthrough=yes comment="" disabled=no
    add chain=postrouting protocol=udp dst-port=1571 action=mark-connection \
    new-connection-mark=voip3 passthrough=yes comment="VOIP \(PORTA EXTERNA DA \
    VONO\)" disabled=no
    add chain=postrouting connection-mark=voip3 action=mark-packet \
    new-packet-mark=voip3 passthrough=yes comment="" disabled=no
    add chain=output connection-state=new action=mark-connection \
    new-connection-mark=teste passthrough=yes comment="" disabled=no
    Ae colocas estas no queue tree:
    / queue tree
    add name="voip_in" parent=global-in packet-mark=VOIP_IN limit-at=200000 \
    queue=default priority=1 max-limit=200000 burst-limit=0 burst-threshold=0 \
    add name="voip_out" parent=global-out packet-mark=VOIP_OUT limit-at=128000 \
    queue=default priority=1 max-limit=128000 burst-limit=0 burst-threshold=0 \
    add name="voip_in2" parent=global-out packet-mark=VOIP_IN limit-at=200000 \
    add name="voip_out2" parent=global-in packet-mark=VOIP_OUT limit-at=128000 \
    add name="queue1" parent=global-in packet-mark=teste2 limit-at=200000 \
    :: Anexo segue o QOS utilizando Layer-7
  1. loadbalance por marcação de pacotes ADSL+ADSL
    Por wireless&cia no fórum Redes
    Respostas: 22
    Último Post: 12-04-2008, 09:35
  2. loadbalance p/ 3 adsl com marcação de pacotes
    Respostas: 11
    Último Post: 19-02-2008, 22:06
  3. Dupla marcação de pacote --MARK no IPTABLES
    Por quecosuix no fórum Servidores de Rede
    Último Post: 21-11-2006, 09:09
  4. Webmail + Marcação de Pacotes
    Por _AGM_ no fórum Servidores de Rede
    Último Post: 12-04-2006, 00:01
  5. Marcação de Pacotes e Balanceamento de Links!!!
    Último Post: 10-10-2005, 07:26
