  1. Nturbo testa essas configurações aqui.
    Lembrando que aonde tiver yyy.yyy.yyy.yyy deve ser seu o GATEWAY do seu LINK1 e aonde estiver xxx.xxx.xxx.xxx deve ser o GATEWAY do seu LINK2
    Lembrando tambem que se voce tiver um terceiro link, apenas adicione mais conforme suas necessidades.
    /ip route
    add comment="ROTA PARA ROOT-SERVER "F" - FAILOVER LINK1" disabled=no distance=1 dst-address=192.5.5.241/32 gateway=yyy.yyy.yyy.yyy scope=30 target-scope=10
    add comment="ROTA PARA ROOT-SERVER "J" - FAILOVER LINK2" disabled=no distance=1 dst-address=192.58.128.30/32 gateway=xxx.xxx.xxx.xxx scope=30 target-scope=10
    /system script
    add name=LINK2-OFF policy=ftp,reboot,read,write,test,winbox source="
    /ip route find gateway=xxx.xxx.xxx.xxx] disable=yes
    /ip route find dst-address=192.58.128.30/32] disable=no"
    add name=LINK2-ON policy=ftp,reboot,read,write,policy,test,winbox source="
    /ip route find gateway=xxx.xxx.xxx.xxx] disable=no
    /ip route find dst-address=192.5.5.241/32] disable=no"
    add name=LINK1-OFF policy=ftp,reboot,read,write,policy,test,winbox source="
    /ip route find gateway=yyy.yyy.yyy.yyy] disable=yes
    /ip route find dst-address=192.5.5.241/32 disable=no"
    add name=LINK1-ON policy=ftp,reboot,read,write,policy,test,winbox source="
    /ip route find gateway=yyy.yyy.yyy.yyy disable=no"
    /ip route find dst-address=192.58.128.30/32 disable=no"
    add name=LINKS-UPS policy=ftp,reboot,read,write,policy,test,winbox source="
    /tool netwatch
    /tool netwatch find host=192.5.5.241 disable=no"
    /tool netwatch find host=192.58.128.30 disable=no"
    add comment=LINK1 disabled=no down-script=LINK1-OFF host=192.5.5.241 interval=5s timeout=3s up-script=LINK1-ON
    add comment=LINK2 disabled=no down-script=LINK2-OFF host=192.58.128.30 interval=5s timeout=3s up-script=LINK2-ON
    /system scheduler
    add comment="Forcar Verificacao dos Links" disabled=no interval=10s name=LINKS-UPS on-event=LINKS-UPS policy=ftp,read,policy,test,wi nbox,sniff start-date=sep/10/2009 start-time=00:00:00
    Ver melhorou agora Nturbo.
    Última edição por freitascs; 03-05-2011 às 01:28.
  2. Pow tem coisa D+ ai não.. to vendo \n\r ?
  3. ???
  4. Show, agora ta legal.. rsrs ( vc me ajudando e eu ainda te pedindo)
    Tomara q não de problema com o PCC pq ai se não der problema e funfar direitinho junto com ele isso pode ser incluído no próprio programa.
    Vou testar aki depois posto o result.
    vlw amigo
    Última edição por NTurbo; 03-05-2011 às 08:20.
  5. To com balance rodando aqui e preciso fazer com que um link que eu tenho aqui ip fixo, quando eu digite seu ip no internet explorer ele caia num servidor que esta atrás do balance...
  1. Respostas: 24
    Último Post: 25-03-2014, 07:52
  2. script para gerar tabelas dos logs???
    Por tomelin no fórum Linguagens de Programação
    Último Post: 26-06-2006, 09:25
  3. programa para testar segurança do firewall
    Por johnny no fórum Servidores de Rede
    Respostas: 9
    Último Post: 01-11-2005, 13:48
  4. problemas para gerar modulo do tomcat
    Por mcclaudio no fórum Servidores de Rede
    Último Post: 03-09-2004, 10:07
  5. Programa para gerenciar configuração!!!
    Por Algoritmo_PB no fórum Servidores de Rede
    Último Post: 24-07-2004, 15:10
