  1. Citação Postado originalmente por clecioe Ver Post
    boa tarde a todos do forum, estou com a seguinte situação tenho uma rb450g e dois adsl.
    1º) adsl endereço ip: 192.168.254.6
    gateway: 192.168.254.2
    2º) adsl endereço ip: 192.168.253.6
    gateway: 192.168.253.2
    no software coloquei da seguinte maneira
    ip address: 192.168.100.1
    network: 192.168.100.0
    masc: 24
    interface: Ether5
    dns primario: 192.168.100.1
    dns segundario: 192.168.100.2
    link
    ip address: 192.168.253.6
    network: 192.168.253.0
    masc: 24
    velocidade: 1024
    interface: Ether1
    link adsl
    ip address: 192.168.254.6
    network: 192.168.254.0
    masc: 24
    velocidade: 1024
    interface: Ether2
    link adsl
    codigo gerado pelo software
    /ip address add address=192.168.100.1/24 interface=ether5
    /ip dns set primary-dns=192.168.100.2
    /ip dns set secondary-dns=192.168.100.3
    /ip firewall address-list add address=200.155.80.0-200.155.255.255 comment=bradesco disabled=no list=loopback
    /ip firewall address-list add address=200.220.186.0/24 comment=bradesco disabled=no list=loopback
    /ip firewall address-list add address=200.220.178.0/24 comment=bradesco disabled=no list=loopback
    /ip firewall address-list add address=64.38.29.0/24 comment=rapidshare disabled=no list=loopback
    /ip firewall address-list add address=208.69.32.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=208.67.217.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=201.7.178.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=201.7.176.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=200.159.128.0/24 comment=bradesco disabled=no list=loopback
    /ip firewall address-list add address=201.7.176.0/20 comment=\"vídeos - globo\" disabled=no list=loopback
    /ip firewall address-list add address=208.84.247.0/24 comment=\"vídeos - terratv\" disabled=no list=loopback
    /ip firewall address-list add address=200.154.56.0/24 comment=\"vídeos - terratv\" disabled=no list=loopback
    /ip firewall address-list add address=200.201.160.0/24 comment=\"caixa economica federal\" disabled=no list=loopback
    /ip firewall address-list add address=200.201.166.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=200.201.173.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=200.201.174.0/24 comment=\"\" disabled=no list=loopback
    /ip firewall address-list add address=200.141.207.3 comment=detran disabled=no list=loopback
    /ip firewall mangle add action=accept chain=prerouting comment=\"fora do loadbalaced\" disabled=no dst-address-list=loopback in-interface=ether5
    /ip dhcp-client add add-default-route=yes comment=\"\" default-route-distance=0 disabled=no interface=ether1 use-peer-dns=yes use-peer-ntp=yes
    /ip dhcp-client add add-default-route=yes comment=\"\" default-route-distance=0 disabled=no interface=ether2 use-peer-dns=yes use-peer-ntp=yes
    /ip firewall nat add action=masquerade chain=srcnat comment=\"\" disabled=no out-interface=ether1
    /ip firewall nat add action=masquerade chain=srcnat comment=\"\" disabled=no out-interface=ether2
    /ip firewall filter add action=accept chain=input comment=\"\" disabled=no in-interface=!ether1 src-address=192.168.100.0/24
    /ip firewall filter add action=accept chain=input comment=\"\" disabled=no in-interface=!ether2 src-address=192.168.100.0/24
    /ip firewall mangle add action=mark-connection chain=input comment=\"\" disabled=no in-interface=ether1 new-connection-mark=ether1_conn passthrough=yes
    /ip firewall mangle add action=mark-connection chain=input comment=\"\" disabled=no in-interface=ether2 new-connection-mark=ether2_conn passthrough=yes
    /ip firewall mangle add action=mark-routing chain=output comment=\"\" connection-mark=ether1_conn disabled=no new-routing-mark=to_ether1 passthrough=yes
    /ip firewall mangle add action=mark-routing chain=output comment=\"\" connection-mark=ether2_conn disabled=no new-routing-mark=to_ether2 passthrough=yes
    /ip firewall mangle add action=mark-connection chain=prerouting comment=\"\" disabled=no dst-address-type=!local in-interface=ether5 new-connection-mark=ether1_conn passthrough=yes per-connection-classifier=both-addresses:2/0
    /ip firewall mangle add action=mark-connection chain=prerouting comment=\"\" disabled=no dst-address-type=!local in-interface=ether5 new-connection-mark=ether2_conn passthrough=yes per-connection-classifier=both-addresses:2/1
    /ip firewall mangle add action=mark-routing chain=prerouting comment=\"\" connection-mark=ether1_conn disabled=no in-interface=ether5 new-routing-mark=to_ether1 passthrough=yes
    /ip firewall mangle add action=mark-routing chain=prerouting comment=\"\" connection-mark=ether2_conn disabled=no in-interface=ether5 new-routing-mark=to_ether2 passthrough=yes
    /ip route add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether1 routing-mark=to_ether1
    /ip route add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether2 routing-mark=to_ether2
    /ip route add check-gateway=ping comment=\"\" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether1 scope=30 target-scope=10
    /ip route add check-gateway=ping comment=\"\" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=ether2 scope=30 target-scope=10
    ai quando coloco o codigo ele não navega mas pinga dentro da rb pelo terminal ping uol - o melhor conteúdo
    informe o dns corretamente !!!
  2.    Publicidade
  3. Olá scan
    muito obrigado pela ajuda
    esse programa é muito bom mesmo
    usei ele para montar meu balancer
    só que to com um problema
    to usando um balancer paralelo com o servidor principal
    mais tentei de tudo e as requsições só saem por um link
    e mesmo assim tive que desativar a opção invert nas regras do mangle
    ai vai minhas regras
    Código :
    /ip address add address=192.168.30.1/24  interface=SAIDA
    /ip dns set primary-dns=208.67.222.222
    /ip dns set secondary-dns=208.67.220.220
    /ip firewall address-list add address=200.155.80.0-200.155.255.255 comment=BRADESCO disabled=no list=loopback
    /ip firewall address-list add address=200.220.186.0/24 comment=BRADESCO disabled=no list=loopback
    /ip firewall address-list add address=200.220.178.0/24 comment=BRADESCO disabled=no list=loopback
    /ip firewall address-list add address=64.38.29.0/24 comment=RapidShare disabled=no list=loopback
    /ip firewall address-list add address=208.69.32.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=208.67.217.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=201.7.178.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=201.7.176.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=200.159.128.0/24 comment=BRADESCO disabled=no list=loopback
    /ip firewall address-list add address=201.7.176.0/20 comment="Vídeos - Globo" disabled=no list=loopback
    /ip firewall address-list add address=208.84.247.0/24 comment="Vídeos - terratv" disabled=no list=loopback
    /ip firewall address-list add address=200.154.56.0/24 comment="Vídeos - terratv" disabled=no list=loopback
    /ip firewall address-list add address=200.201.160.0/24 comment="Caixa Economica Federal" disabled=no list=loopback
    /ip firewall address-list add address=200.201.166.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=200.201.173.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=200.201.174.0/24 comment="" disabled=no list=loopback
    /ip firewall address-list add address=200.141.207.3 comment=Detran disabled=no list=loopback
    /ip firewall mangle add action=accept chain=prerouting comment="FORA DO LOADBALACED" disabled=no dst-address-list=loopback in-interface=SAIDA
    /ip dhcp-client add add-default-route=yes comment="" default-route-distance=0 disabled=no interface=LINK1 use-peer-dns=yes use-peer-ntp=yes
    /ip dhcp-client add add-default-route=yes comment="" default-route-distance=0 disabled=no interface=LINK2 use-peer-dns=yes use-peer-ntp=yes
    /ip firewall nat add action=masquerade chain=srcnat comment="" disabled=no out-interface=LINK1
    /ip firewall nat add action=masquerade chain=srcnat comment="" disabled=no out-interface=LINK2
    /ip firewall filter add action=accept chain=input comment="" disabled=no in-interface=!LINK1 src-address=192.168.30.0/24
    /ip firewall filter add action=accept chain=input comment="" disabled=no in-interface=!LINK2 src-address=192.168.30.0/24
    /ip firewall mangle add action=mark-connection chain=input comment="" disabled=no in-interface=LINK1 new-connection-mark=LINK1_conn passthrough=yes
    /ip firewall mangle add action=mark-connection chain=input comment="" disabled=no in-interface=LINK2 new-connection-mark=LINK2_conn passthrough=yes
    /ip firewall mangle add action=mark-routing chain=output comment="" connection-mark=LINK1_conn disabled=no new-routing-mark=to_LINK1 passthrough=yes
    /ip firewall mangle add action=mark-routing chain=output comment="" connection-mark=LINK2_conn disabled=no new-routing-mark=to_LINK2 passthrough=yes
    /ip firewall mangle add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=SAIDA new-connection-mark=LINK1_conn passthrough=yes per-connection-classifier=both-addresses:3/0
    /ip firewall mangle add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=SAIDA new-connection-mark=LINK1_conn passthrough=yes per-connection-classifier=both-addresses:3/1
    /ip firewall mangle add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=SAIDA new-connection-mark=LINK2_conn passthrough=yes per-connection-classifier=both-addresses:3/2
    /ip firewall mangle add action=mark-routing chain=prerouting comment="" connection-mark=LINK1_conn disabled=no in-interface=SAIDA new-routing-mark=to_LINK1 passthrough=yes
    /ip firewall mangle add action=mark-routing chain=prerouting comment="" connection-mark=LINK2_conn disabled=no in-interface=SAIDA new-routing-mark=to_LINK2 passthrough=yes
    /ip route add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=LINK1 routing-mark=to_LINK1
    /ip route add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=LINK2 routing-mark=to_LINK2
    /ip route add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=LINK1 scope=30 target-scope=10
    /ip route add check-gateway=ping comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=LINK2 scope=30 target-scope=10
    se puder me dar uma ajuda agradeço faz 5 dias que eu tento na madrugada e não consigo
    obrigado
  4. ainda continuo com o mesmo problema coloco os dns
    e nem compartilha internet, teno uma rb450g será que alguem poderia me ajudar, ja tentei de tudo
  5. Bom dia Clecioe! na configuração gerada, o unico problema que pude observar foi o DNS, exatamente como o amigo Interhome citou... Outro detalhe é que o gerador de código para ADSL foi implementado na versão 0.5, e até agora não foi modificado por não apontarem nenhum erro no mesmo, não sei lhe falar se funciona corretamente para ADSL pois não tenho ADSL, já com ip dedicado, eu fiz os testes e funciona normalmente..
    OBS: caso encontrem erros no código gerado para ADSL, favor me avizem....
    OBS: no seu caso, na interface do adsl, deve ser colocada a conexão ppoe, assim eu vi num post aqui do forum, e foi por este post que me basiei para gerar o programa..
  6. bom dia Ivovid!
    veja se a interface esta correta, pois tem a questão do adsl de não colocar a interfece em si e sim a conexão ppoe ...
Tags para este Tópico
