  1. Loaded plugins: fastestmirror, priorities
    Loading mirror speeds from cached hostfile
    * addons: mirror.anl.gov
    * base: centos.promopeddler.com
    * extras: mirror.cisp.com
    * rpmforge: fr2.rpmfind.net
    * updates: holmes.umflint.edu
    Setting up Install Process
    No package wine available.
    Nothing to do
    aparece isoo.
    esta certo?
  2. yum –enablerepo=rpmforge install wine
    Tenta assim
  3. aparece isso
    [root@calhost ~]# yum –enablerepo=rpmforge
    usage: yum [options] COMMAND
    List of Commands:
    check-update Check for available package updates
    clean Remove cached data
    deplist List a package's dependencies
    downgrade downgrade a package
    erase Remove a package or packages from your system
    groupinfo Display details about a package group
    groupinstall Install the packages in a group on your system
    grouplist List available package groups
    groupremove Remove the packages in a group from your system
    help Display a helpful usage message
    info Display details about a package or group of packages
    install Install a package or packages on your system
    list List a package or groups of packages
    localinstall Install a local RPM
    makecache Generate the metadata cache
    provides Find what package provides the given value
    reinstall reinstall a package
    repolist Display the configured software repositories
    resolvedep Determine which package provides the given dependency
    search Search package details for the given string
    shell Run an interactive yum shell
    update Update a package or packages on your system
    upgrade Update packages taking obsoletes into account
    options:
    -h, --help show this help message and exit
    -t, --tolerant be tolerant of errors
    -C run entirely from cache, don't update cache
    -c [config file] config file location
    -R [minutes] maximum command wait time
    -d [debug level] debugging output level
    --showduplicates show duplicates, in repos, in list/search commands
    -e [error level] error output level
    -q, --quiet quiet operation
    -v, --verbose verbose operation
    -y answer yes for all questions
    --version show Yum version and exit
    --installroot=[path] set install root
    --enablerepo=[repo] enable one or more repositories (wildcards allowed)
    --disablerepo=[repo] disable one or more repositories (wildcards allowed)
    -x [package], --exclude=[package]
    exclude package(s) by name or glob
    --disableexcludes=[repo]
    disable exclude from main, for a repo or for
    everything
    --obsoletes enable obsoletes processing during updates
    --noplugins disable Yum plugins
    --nogpgcheck disable gpg signature checking
    --disableplugin=[plugin]
    disable plugins by name
    --enableplugin=[plugin]
    enable plugins by name
    --skip-broken skip packages with depsolving problems
    --color=COLOR control whether color is used
    --samearch-priorities
    Priority-exclude packages based on name + arch
    Plugin Options:
    oq faço?
  4. Desculpa, o comando é ...
    Código :
    yum --enablerepo=rpmforge
  5. olha oque aparece
    [root@calhost ~]# yum --enablerepo=rpmforge
    /etc/host.conf: line 11: bad command `alert on'
    * addons: centos.corenetworks.net
    You need to give some command
    List of Commands:
    options:
    everything
    Plugin Options:
  1. Não consigo acessar/ler cd-rom no Mandrake 9.1
    Por argonilton no fórum Servidores de Rede
    Último Post: 20-06-2003, 16:42
  2. Não consigo instalar meu modem LG no linux !!!
    Por GuE no fórum Servidores de Rede
    Último Post: 15-04-2003, 16:02
  3. Não consigo conectar no mysql
    Último Post: 11-04-2003, 13:33
  4. Profiles no Samba-Não Consigo desabilitar
    Por osni_passos no fórum Servidores de Rede
    Último Post: 10-02-2003, 08:39
  5. Não consigo exergar o linux no windows
    Por sandalo no fórum Servidores de Rede
    Último Post: 13-05-2002, 08:46
