Segue ai o Squid.conf correto!
##SQUID BY RAFAEL RAMON##
http_port 3128 transparent
##CACHE CONFIG##
cache_mem 640 MB
maximum_object_size 1024 MB
maximum_object_size_in_memory 96 KB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir ufs /var/spool/squid3 60000 16 256
refresh_pattern (cgi-bin|\?) 0 0% 0
refresh_pattern . 0 20% 4320
quick_abort_max 16 KB
quick_abort_pct 95
quick_abort_min 16 KB
request_header_max_size 20 KB
reply_header_max_size 20 KB
request_body_max_size 0 KB
##CACHE WINDOWS UPDATE##
refresh_pattern windowsupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
refresh_pattern download.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
refresh_pattern www.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
refresh_pattern download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
refresh_pattern update.microsoft.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
access_log /var/log/squid3/access.log squid
cache_log /var/log/squid3/cache.log
cache_mgr rafael@transoeste.com.br
dns_nameservers 201.10.128.2 201.10.120.3
acl all src
acl transoeste src 192.168.1.0/255.255.255.0
acl SSL_ports port 443 563 873
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 563 873 # https, snews
acl Safe_ports port 901 # swat
acl Safe_ports port 1025-65535 # portas altas
acl purge method PURGE
acl CONNECT method CONNECT
acl palavrasb url_regex "/etc/squid3/palavrasb"
acl sites url_regex -i "/etc/squid3/sites"
acl ipliberado src "/etc/squid3/ipliberado"
acl restritos src "/etc/squid3/restritos"
acl bloqued url_regex "/etc/squid3/bloqued"
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
http_access allow ipliberado
http_access allow sites
http_access deny bloqued
http_access allow restritos
http_access deny palavrasb
http_access allow transoeste
http_access allow localhost
http_access deny all
cache_mgr Rafael_Ramon
visible_hostname SQUID_TRANSOESTE
deny_info Erro palavrasb bloqued
error_directory /usr/share/squid3/errors/pt-br
