  1. Citação Postado originalmente por mktguaruja Ver Post
    Genis, então essas minhas marcações tambem estão incorretas pois eu usei o mesmo Qos postado pelo Edilson.
    Segue abaixo:
    # jun/03/2010 09:07:32 by RouterOS 3.28
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=2M \
    max-limit=3M name=SquidCache-Down packet-mark=proxy-squid parent=\
    global-out priority=8 queue=cache
    max-limit=3M name=SquidCache-Up packet-mark=proxy-squid parent=global-in \
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=yes limit-at=2M \
    max-limit=3M name=ThunderCache-Down packet-mark=thunder-packs parent=\
    max-limit=3M name=ThunderCache-Up packet-mark=thunder-packs parent=\
    global-in priority=8 queue=cache
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
    max-limit=1M name=ServicosDaRede packet-mark=servicosdarede parent=\
    global-total priority=1 queue=default
    max-limit=0 name=Ssl packet-mark=ssl parent=global-total priority=2 \
    queue=default
    max-limit=200k name=P2P packet-mark=p2p parent=global-total priority=8 \
    queue=default
    max-limit=1M name=BatePapo packet-mark=batepapo parent=global-total \
    priority=2 queue=default
    max-limit=0 name=Udp packet-mark="" parent=global-total priority=3 queue=\
    default
    max-limit=0 name=Udp-100 packet-mark=udp-100 parent=Udp priority=1 queue=\
    default
    max-limit=0 name=Udp-500 packet-mark=upd-500 parent=Udp priority=2 queue=\
    default
    max-limit=0 name=Udp-Other packet-mark=upd-other parent=Udp priority=3 \
    queue=default
    max-limit=0 name=Email packet-mark="" parent=global-total priority=4 \
    queue=default
    max-limit=0 name=Pop3 packet-mark=pop3 parent=Email priority=1 queue=\
    default
    max-limit=0 name=Imap packet-mark=imap parent=Email priority=3 queue=\
    default
    max-limit=0 name=Http packet-mark="" parent=global-total priority=2 \
    queue=default
    max-limit=12M name=Http-Navegacao packet-mark=http-navegacao parent=\
    max-limit=0 name=Http-1Mbyte packet-mark=http-1Mbyte parent=Http \
    max-limit=0 name=Http-3Mbyte packet-mark=http-3Mbyte parent=Http \
    priority=3 queue=default
    max-limit=0 name=Http-6Mbyte packet-mark=http-6Mbyte parent=Http \
    priority=4 queue=default
    max-limit=0 name=Http-30Mbyte packet-mark=http-30Mbyte parent=Http \
    priority=5 queue=default
    max-limit=0 name=Http-60Mbytes packet-mark=http-60Mbytes parent=Http \
    priority=6 queue=default
    max-limit=600k name=Http-Infinite packet-mark=http-Infinite parent=Http \
    priority=7 queue=default
    max-limit=0 name=Youtube packet-mark=Youtube parent=Http priority=4 \
    queue=default
    max-limit=0 name=Outros packet-mark="" parent=global-total priority=7 \
    queue=default
    max-limit=0 name=Outros-0bytes packet-mark=0bytes parent=Outros priority=\
    1 queue=default
    max-limit=0 name=Outros-1Mbyte packet-mark=1Mbyte parent=Outros priority=\
    2 queue=default
    max-limit=0 name=Outros-3Mbyte packet-mark=3Mbyte parent=Outros priority=\
    3 queue=default
    max-limit=0 name=Outros-6Mbyte packet-mark=6Mbyte parent=Outros priority=\
    4 queue=default
    max-limit=0 name=Outros-30Mbyte packet-mark=30Mbyte parent=Outros \
    max-limit=0 name=Outros-60Mbytes packet-mark=60Mbytes parent=Outros \
    max-limit=0 name=Outros-Infinite packet-mark=Infinite parent=Outros \
    max-limit=0 name=Outros-Desconhecidos packet-mark=Outros parent=Outros \
    priority=8 queue=default
    max-limit=0 name=AcessoRemoto packet-mark=acessoremoto parent=\
    global-total priority=3 queue=default
    max-limit=0 name=Voip packet-mark=voip parent=global-total priority=6 \
    queue=default
    max-limit=0 name=Smtp packet-mark=smtp parent=Email priority=2 queue=\
    default
    max-limit=1M name="Colheita Feliz" packet-mark=pacote_colheitafeliz \
    parent=global-out priority=2 queue=default
    max-limit=1M name="Mini Colheita Feliz" packet-mark=pacote_minifazenda \
    max-limit=0 name=Globo.com packet-mark=Globo parent=Http priority=4 \
    queue=default
    max-limit=0 name=Terra packet-mark=Terra parent=Http priority=4 queue=\
    default
    mesmo este só a colheita voce limitou, o resto voce só priorizou, mais não limitou assim todos passa usar todo o seu link mesmo sendo encaminhado como fz priorizando, então o que é prioridade 1 por exmp. pode consumir todo o seu link faltando para o resto 2,3,4,5,6,7 e 8
  2. Citação Postado originalmente por Genis Ver Post
    no script voce não esta fazendo QoS, pois esta todas as regras de liberação estão zeradas, voce define quem tem prioridade
    Não entendo quase nada de QoS, mas agora fiquei sem entender mais ainda. Como assim não estar fazendo porque estão zeradas? Veja minha imagem:
Nome:	         QOS.JPG
Visualizações:	210
Tamanho: 	121,9 KB
  3. eu acho que entendi o que ele disse, pois a gente não ta limitando a velocidade no max limit.
    Seria isso Genis ?
    Citação Postado originalmente por EdilsonLSouza Ver Post
Nome:	         QOS.JPG
Visualizações:	210
Tamanho: 	121,9 KB
  4. Mas estar exatamente como no tutorial, eu fui mudando o controle de banda de acordo com meu tráfego, pois queria apenas priorizar e não limitar velocidades.
  5. Se você so queria priorizar os serviços então ta certinhos.
    Agora uma duvida minhas, que tem prioridade a queue tree ou a queue simples. Pois derepente o cliente ta passando alem da velocidade contratada.
  1. Respostas: 21
    Último Post: 18-03-2014, 09:44
  2. Respostas: 11
    Último Post: 03-09-2012, 22:56
  3. Respostas: 8
    Último Post: 18-12-2010, 09:39
  4. Respostas: 7
    Último Post: 09-10-2010, 10:15
  5. roteador para link de 1 MB
    Por alisson no fórum Servidores de Rede
    Respostas: 5
    Último Post: 06-08-2004, 16:41
