    Padrão Squid não esta bloqueando sites
    Bom dia,
    Tenho o seguinte problema, antes eu usava o kurumim 7 com squid e bloqueava tudo liberando somente os ip da diretoria e o resto alguns sites especificos. Agora mudei para o fedora 9 e o squid não esta bloqueando nada.
    Squid 3.0 stable2
    Segue o meu squid.conf:
    http_port 3128 transparent
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    cache_mem 16 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 51200 16 256
    visible_hostname srvinternet
    ftp_user [email protected]
    refresh_pattern . 15 20% 2280
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    acl diretoria src 192.168.0.106 192.168.0.111 192.168.0.103
    acl bloqueados url_regex -i "/etc/squid/bloqueados"
    http_access deny bloqueados !diretoria
    #bloqueio de msn
    acl msn_port port 1863
    acl msn_port2 port 5223
    acl serv_msn dst 200.46.110.0/24
    acl serv_msn dst 64.4.13.0/24
    acl app_msn req_mime_type -i ^application/x-msn-messenger$
    acl msn_messenger url_regex -i gateway.dll
    acl msn_dom dstdomain loginnet.passport.com
    acl msn_dom dstdomain messenger.msn.com
    acl msn_dom dstdomain messenger.msn.ca
    acl msn_dom dstdomain messenger.msn.net
    acl msn_dom dstdomain im.sapo.pt
    acl msn_dom dstdomain webmessenger.msn.com
    acl msn_dom dstdomain c.msn.com
    acl msn_dom dstdomain config.messenger.msn.com
    acl msn_dom dstdomain login.live.com
    acl msn_dom dstdomain amsn-project.net
    acl liberados_msn src "/etc/squid/liberados_msn"
    http_access deny CONNECT msn_port !liberados_msn
    http_access deny msn_port !liberados_msn
    http_access deny msn_port2 !liberados_msn
    http_access deny serv_msn !liberados_msn
    http_access deny app_msn !liberados_msn
    http_access deny msn_dom !liberados_msn
    http_access deny msn_messenger !liberados_msn
    # A acl "proibidos" é usada para fazer bloqueio baseado em palavras
    acl proibidos dstdom_regex "/etc/squid/proibidos"
    http_access deny proibidos
    acl redelocal src 192.168.0.0/24
    http_access deny redelocal
    http_access deny all
    #http_access allow all
    Padrão Re: Squid não esta bloqueando sites
    Bom dia Marcelo,
    Não é o Marcelo de Nova Aurora - PR? hahah...
    Bem .. vamos ao que interessa...Eu uso aqui a versão 2.7 no squid..
    se eu não me engano nas versões acima o "transparent" que fica na primeira linha sai..
    Da uma olhada no seu log primeiramente.. Seria bom vc passar o seu firewall..
    Pode ser que não esta sendo feito o redirecionamento com o iptables..
    iptables -t nat -A PREROUTING -s 192.168.0.0/24 -i eth1 -p tcp -m tcp --dport 80 -j REDIRECT --to 3128
    * Considerando que a eth1 seria a sua placa de rede interna..
    ** Se tiver mais placas tera que ser feito o redicionamento..
    Dependendo onde estiver essa linha pode não funcionar...
    Muito obrigado pela dica, rodei o comando que vc me passou e realmente o acesso começou a passar pelo proxy, so que agora so roda se informa o proxy no navegador, pelo transparente acontece o seguinte erro:
    ERRO
    A URL solicitada não pode ser recuperada
    Na tentativa de recuperar a URL: /
    O seguinte erro foi encontrado:
    • URL inválida
    Alguns aspectos de requisições URL são incorretos. Possíveis causas:
    • Protocolo de acesso incorreto ou faltando (deve ser `http://` ou similar)
    • Faltou o hostname
    • Hostname com caracter inválido; não são permitidos underscores.
    Generated Thu, 16 Sep 2010 22:43:15 GMT by srvinternet (squid/3.0.STABLE2) se alguém puder me ajudar, porque ja passei a tarde pesquisando e não achei solução
    Aug 2008
    Araguari - Minas Gerais
    Retorne o transparent.
    Se o squid antigo era o 2.7, continue usando ele. Pode ser incompatibilidade de ACL.
    Você conferiu os arquivos de bloqueio? Se o squid tem permissão?
    Ja olhei as permissões e esta tudo certo, o estranho que so acontece pelo proxy transparente, quando configuro o proxy pelo navegador navega normal, inclusive bloqueando os sites e liberando total para a diretoria.O erro continua:
    • URL inválida
    • Faltou o hostname
    Aug 2008
    Citação Postado originalmente por marceloeidt Ver Post
    • URL inválida
    • Faltou o hostname
    Não leu minha resposta, mas tá blz...
    zoltan's blog: Transparent proxy with Squid 3 on Ubuntu server
