  1. bom tarde estou com um problema aqui na minha configuracao gostaria que os amigos se pudece me ajudace nessa caminhada , quando o mikrotik vai buscar as paginas no squid o navegador retorna
    ERROR
    The requested URL could not be retrieved
    gostaria de saber o que estou errando.
    tenho um mikrotik 3.30 com 3placas 1para o link , 1 para o proxy squid e 1 para os clientes de redes e um serve squid com uma placa de rede,
    o modelo do meu squid ta assim
    http_port 172.1.1.2:2608 transparent
    #hierarchy_stoplist cgi-bin ?
    #acl QUERY urlpath_regex cgi-bin \?
    #cache deny QUERY
    #acl apache rep_header Server ^Apache
    #broken_vary_encoding allow apache
    cache_mem 512 MB
    cache_swap_low 80
    cache_swap_high 85
    maximum_object_size 50 MB
    maximum_object_size_in_memory 256 KB
    cache_dir ufs /var/spool/squid 20000 16 256
    #access_log /var/log/squid/access.log squid
    acl all src all
    acl localhost src 127.0.0.1/32
    acl localnet src 172.16.0.0/12 # RFC1918 possible internal network
    acl localnet src 172.1.1.2/26 # RFC1918 possible internal network
    acl SSL_ports port 443 # https
    acl SSL_ports port 563 # snews
    acl SSL_ports port 873 # rsync
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl Safe_ports port 631 # cups
    acl Safe_ports port 873 # rsync
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localnet
    http_access deny all
    icp_access allow localnet
    icp_access deny all
    #http_port 3128
    refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
    refresh_pattern (Release|Package(.gz)*)$ 0 20% 2880
    refresh_pattern . 0 20% 4320
    acl shoutcast rep_header X-HTTP09-First-Line ^ICY\s[0-9]
    upgrade_http0.9 deny shoutcast
    extension_methods REPORT MERGE MKACTIVITY CHECKOUT
    hosts_file /etc/hosts
    coredump_dir /var/spool/squid
    so que dar erro quando busco o cache no linux
    minhas regras no mikr
    nat
    chain =srcnat
    action= masquerade
    general
    chain = srcnat
    src.address= 10.1.1.0/26
    action=masquerade
    general
    chain=dstnat
    protocol=6 tcp
    dst port =80
    action=dst-nat
    to addresses=172.1.1.2
    to ports = 2608
  2. Bom dia meus amigos, fiz tudo a risca e funcionou!!
    Só tem um problema, ele me mostra que só existe um usuariário que é o IP do Mk que vai para o Proxy.
    Tem como fazer o log mas mostrando os IPs da rede Interna?
  3. Os erros que dao neste sistema . sobre as url grandes. e basicamento . nas pastas de log do squid. dentro da pasta var..... eles e que dao problema. .. tenho o sistema implantado aqui a 1 ano. e enquanto nao limitei o tamanho destes logs tive que muitas vezes refazer os servidores. vai uma dica. para quem usar o sistema. limite o cache em 1000 16 256 no seu squid para ele nao ficar lerdo. e tambem . a limpesa do cache ser mais rapida. e nao proporcionar muito relatorio o que fara que o squid pare por algumas vezes..
  4. Alou pessoal estou iniciando nesta conectividade do Mikrotik com o Squid, fiz todos os passos e navega normalmente, agora sites com https ele não abre dá erro o que pode ser???
    Valeu!!!
  1. Respostas: 17
    Último Post: 26-04-2013, 17:19
  2. Web-proxy Mikrotik Ou Squid Em Linux
    Por MPFER no fórum Redes
    Último Post: 18-04-2007, 22:05
  3. Respostas: 0
    Último Post: 16-07-2006, 21:31
  4. problemas com proxy squid, iptables
    Por computech no fórum Servidores de Rede
    Último Post: 17-11-2004, 20:31
  5. E-mail com proxy squid limitado.
    Por tonton no fórum Servidores de Rede
    Último Post: 01-10-2003, 17:05
