  1. So não pude conectar o rb no modem para fazer o export com ele ligado no modem! Ele ping por exeplo no terra.com.br mas não navega! se alguem puder me ajudar ficarei muito grato!
    # jan/02/1970 00:01:28 by RouterOS 4.11
    # software id = GGEU-2LBB
    /interface ethernet
    set 0 arp=reply-only auto-negotiation=yes comment="" disabled=no full-duplex=\
    yes l2mtu=1526 mac-address=00:0C:42:A0:E0:67 mtu=1500 name=Local speed=\
    100Mbps
    set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A0:E0:68 \
    master-port=none mtu=1500 name=Internet speed=100Mbps
    set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A0:E0:69 \
    master-port=none mtu=1500 name=ether3 speed=100Mbps
    set 3 arp=disabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    comment="" disabled=no full-duplex=yes l2mtu=1524 mac-address=\
    00:0C:42:A0:E0:6A master-port=none mtu=1500 name=Rede speed=100Mbps
    set 4 arp=disabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    00:0C:42:A0:E0:6B master-port=none mtu=1500 name=Link speed=100Mbps
    /interface ethernet switch
    set switch1 mirror-source=none mirror-target=none name=switch1
    /ip hotspot profile
    set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
    http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
    name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
    add dns-name="" hotspot-address=192.168.30.1 html-directory=hotspot \
    name=hsprof1 rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
    /ip hotspot user profile
    set default idle-timeout=none keepalive-timeout=2m name=default shared-users=\
    1 status-autorefresh=1m transparent-proxy=no
    /ip ipsec proposal
    set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
    /ip pool
    add name=pool1 ranges=192.168.30.10,192.168.30.240
    /ip dhcp-server
    add address-pool=pool1 authoritative=after-2sec-delay bootp-support=static \
    disabled=no interface=Local lease-time=1h name=dhcp1
    /ip hotspot
    add address-pool=pool1 addresses-per-mac=2 disabled=no idle-timeout=5m \
    interface=Local keepalive-timeout=none name=hotspot1 profile=hsprof1
    /ppp profile
    set default change-tcp-mss=yes comment="" name=default only-one=default \
    use-compression=default use-encryption=default use-vj-compression=default
    set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
    only-one=default use-compression=default use-encryption=yes \
    /interface pppoe-client
    add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=\
    "" dial-on-demand=no disabled=no interface=Internet max-mru=1482 max-mtu=\
    1482 mrru=disabled name=pppoe-out1 password= profile=default \
    service-name="" use-peer-dns=yes user=
    /queue type
    set default kind=pfifo name=default pfifo-limit=50
    set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
    set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
    sfq-perturb=5
    set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
    red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
    set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
    5
    set default-small kind=pfifo name=default-small pfifo-limit=10
    /queue simple
    add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" \
    direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=\
    0/0 max-limit=30k/90k name=terminal1 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.11/32 \
    total-queue=default-small
    0/0 max-limit=30k/90k name=terminal2 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.12/32 \
    0/0 max-limit=30k/90k name=Terminal3 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.13/32 \
    0/0 max-limit=30k/90k name=Terminal4 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.14/32 \
    0/0 max-limit=30k/90k name=Terminal5 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.15/32 \
    0/0 max-limit=30k/90k name=Terminal6 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.16/32 \
    0/0 max-limit=30k/90k name=Terminal7 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.17/32 \
    0/0 max-limit=30k/90k name=Terminal8 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.18/32 \
    0/0 max-limit=30k/90k name=Terminal9 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.19/32 \
    0/0 max-limit=30k/90k name=Terminal10 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.20/32 \
    0/0 max-limit=30k/90k name=Terminal11 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.21/32 \
    0/0 max-limit=0/0 name=Servidor parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.168.30.10/32 \
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
    max-limit=60k name=p2p_con packet-mark=p2p parent=global-in priority=8 \
    queue=default
    max-limit=60k name=p2pup packet-mark=p2p parent=global-out priority=8 \
    queue=default
    /routing bgp instance
    set default as=65530 client-to-client-reflection=yes comment="" disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
    /routing ospf instance
    set default comment="" disabled=no distribute-default=never in-filter=ospf-in \
    metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
    auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0
    /routing ospf area
    set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=\
    backbone type=default
    /snmp
    set contact="" enabled=no engine-boots=0 engine-id="" location="" \
    time-window=15 trap-sink=0.0.0.0 trap-version=1
    /snmp community
    set public address=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
    /system logging action
    set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
    set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
    set echo name=echo remember=yes target=echo
    set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
    /system routerboard settings
    Última edição por juniorlealdade; 10-05-2011 às 14:18.
  2. set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
    400MHz force-backup-booter=no silent-boot=no
    /user group
    add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass\
    word,web,sniff,sensitive,!ftp,!write,!policy"
    add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb\
    ox,password,web,sniff,sensitive,!ftp,!policy"
    add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy\
    ,test,winbox,password,web,sniff,sensitive"
    /interface bridge settings
    set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
    /interface ethernet switch port
    set (unknown) vlan-header=leave-as-is vlan-mode=fallback
    /interface l2tp-server server
    set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
    /interface ovpn-server server
    set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:72:A5:57:72:9D \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
    /interface pptp-server server
    set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
    /ip accounting
    set account-local-traffic=no enabled=no threshold=256
    /ip accounting web-access
    set accessible-via-web=no address=0.0.0.0/0
    /ip address
    add address=192.168.100.2/24 broadcast=192.168.100.240 comment="" disabled=no \
    interface=Internet network=192.168.100.0
    add address=192.168.30.10/24 broadcast=192.168.30.240 comment="" disabled=no \
    interface=Local network=192.168.30.10
    /ip dhcp-server config
    set store-leases-disk=5m
    /ip dhcp-server network
    add address=192.168.30.0/24 comment="hotspot network" gateway=192.168.30.1
    add address=192.168.200.0/24 comment="hotspot network" gateway=192.168.200.1
    /ip dns
    set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512 servers=200.165.132.147,200.165.132.155
    /ip dns static
    add address=192.168.30.1 comment="" disabled=no name=aws.com.br ttl=1d
    /ip firewall connection tracking
    set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
    /ip firewall filter
    add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
    add action=accept chain=input comment="" disabled=no dst-address=0.0.0.0/0 \
    src-address=0.0.0.0/0
    add action=accept chain=output comment="" disabled=no dst-address=0.0.0.0/0 \
    /ip firewall mangle
    add action=mark-connection chain=prerouting comment="" disabled=no \
    new-connection-mark=p2p_con p2p=all-p2p passthrough=yes
    add action=mark-packet chain=prerouting comment="" connection-mark=p2p_con \
    disabled=no new-packet-mark=p2p passthrough=yes
    /ip firewall nat
    add action=masquerade chain=srcnat comment="" disabled=no dst-address=\
    0.0.0.0/0 out-interface=pppoe-out1 src-address=0.0.0.0/0
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=5060,5061
    set pptp disabled=no
    /ip hotspot service-port
    /ip hotspot user
    add comment="" disabled=no name=admin password=202900 profile=default
    /ip neighbor discovery
    set Local discover=yes
    set Internet discover=yes
    set ether3 discover=yes
    set Rede discover=yes
    set Link discover=yes
    set pppoe-out1 discover=no
    /ip proxy
    set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
    /ip route
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.100.1 scope=30 target-scope=10
    /ip service
    set telnet address=0.0.0.0/0 disabled=no port=23
    set ftp address=0.0.0.0/0 disabled=no port=21
    set www address=0.0.0.0/0 disabled=no port=80
    set ssh address=0.0.0.0/0 disabled=no port=22
    set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
    set api address=0.0.0.0/0 disabled=yes port=8728
    set winbox address=0.0.0.0/0 disabled=no port=8291
    /ip socks
  3. set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
    /ip traffic-flow
    set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
    /ip upnp
    set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
    /mpls
    set dynamic-label-range=16-1048575 propagate-ttl=yes
    /mpls interface
    add comment="" disabled=no interface=all mpls-mtu=1508
    /mpls ldp
    set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
    /ppp aaa
    set accounting=yes interim-update=0s use-radius=no
    /queue interface
    set Local queue=ethernet-default
    set Internet queue=ethernet-default
    set ether3 queue=ethernet-default
    set Rede queue=ethernet-default
    set Link queue=ethernet-default
    set pppoe-out1 queue=default
    /radius incoming
    set accept=no port=3799
    /routing bfd interface
    set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec \
    multiplier=5
    /routing mme
    set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
    /routing rip
    set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
    /store
    add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
    /system clock
    set time-zone-name=manual
    /system clock manual
    set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
    /system console
    add disabled=no term=vt102
    /system health
    set
    /system identity
    set name=MikroTik
    /system logging
    add action=memory disabled=no prefix="" topics=info
    add action=memory disabled=no prefix="" topics=error
    add action=memory disabled=no prefix="" topics=warning
    add action=echo disabled=no prefix="" topics=critical
    /system note
    set note="" show-at-login=yes
    /system ntp client
    set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
    /system upgrade mirror
    set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
    /system watchdog
    set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
    /tool bandwidth-server
    set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
    /tool e-mail
    set from=<> password="" server=0.0.0.0:25 username=""
    /tool graphing
    set page-refresh=300 store-every=5min
    /tool mac-server
    add disabled=no interface=all
    /tool mac-server ping
    set enabled=yes
    /tool sms
    set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
    /tool sniffer
    set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=\
    yes interface=all memory-limit=10 memory-scroll=no only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0
    /user aaa
    set accounting=yes default-group=read interim-update=0s use-radius=no
  4. bacana, ta facil de resolver ai,
    de um system reset no terminal.]
    começe de novo.
    coloque por exemplo a ether1 como link. coloque uma faixa de IP/24 nela.( mesma de seu modem)
    crie um discador pppoe (cliente) pra esta interface.
    crie uma bridge e coloque o resto das ether nessa bridge.
    coloque uma faixa de IP nessa bridge de preferencia /24.
    va em dns em setings coloque o dns da sua operadora.
    va em ip>firewall>nat
    crie uma regra de nat. ( chain>srcnat e em action coloque masquerade somente isso) confirme.
    va em ip dhcp server va em setup e crie um servidor ai é so seguir na setinha confirme sua faixa de ip e interface.
    coloque um cabo em qualquer ether de 2 a 5 e faça um teste.
    depois agente olha a questao de como vai ser a forma dos pcs logarem, primeiro vamos por pra rodar ai.
    qualquer coisa me add no msn.
    mateus.assuncao@hotmail.com
  5. Bom dia! depois de muito quebrar a cabeça, perde muito tempo e horas de sono rssss, consegui colocar o rb750 pra funcionar, agora a rede esta configurada e navegando. So tem um unico problema q não consegui resolver. O controle de banda, mesmo definindo o controle de banda no RB750, as maquinas configuradas na rede, trafegam e fazem downloads livres, preciso controlar a banda, comprei o RB750 apenas para esse função. Por favor me ajudem.
    dmin@MikroTik] > export
    # jan/02/1970 03:43:59 by RouterOS 4.11
    /interface ethernet
    set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes \
    l2mtu=1526 mac-address=00:0C:42:A0:E0:67 mtu=1500 name=LINK speed=100Mbps
    set 1 arp=reply-only auto-negotiation=yes bandwidth=unlimited/unlimited \
    00:0C:42:A0:E0:68 master-port=none mtu=1500 name=REDE speed=100Mbps
    set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A0:E0:6A \
    master-port=none mtu=1500 name=ether4 speed=100Mbps
    set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A0:E0:6B \
    master-port=none mtu=1500 name=ether5 speed=100Mbps
    /ip hotspot profile
    use-radius=no
    use-radius=no
    add dns-name="" hotspot-address=192.168.100.2 html-directory=hotspot \
    name=hsprof2 rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
    /ip ipsec proposal
    /ip pool
    add name=pool1 ranges=192.168.30.10,192.168.30.254
    add name=hs-pool-1 ranges=192.168.100.1,192.168.100.3-192.168.100.254
    /ip dhcp-server
    disabled=no interface=REDE lease-time=1h name=dhcp1
    add address-pool=hs-pool-1 authoritative=after-2sec-delay bootp-support=\
    static disabled=no interface=LINK lease-time=1h name=dhcp2
    /ppp profile
    "" dial-on-demand=no disabled=no interface=LINK max-mru=1482 max-mtu=1482 \
    mrru=disabled name=Velox password= profile=default \
    service-name="" use-peer-dns=no user=
    /queue type
    sfq-perturb=5
    5
    /queue simple
    0/0 max-limit=20k/70k name=terminal1 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal2 parent=none priority=8 queue=\
    direction=both disabled=no dst-address=0.0.0.0/0 interface=LINK limit-at=\
    20k/70k max-limit=20k/70k name=terminal3 parent=none priority=8 queue=\
    default-small/default-small target-addresses=192.160.30.13/32 \
    20k/70k max-limit=20k/70k name=terminal4 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal5 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal6 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal7 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal8 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal9 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal10 parent=none priority=8 queue=\
    0/0 max-limit=20k/70k name=terminal11 parent=none priority=8 queue=\
    0/0 max-limit=0/0 name=server parent=none priority=8 queue=\
    /queue tree
    max-limit=30k name=controlep2p packet-mark=p2p parent=global-in priority=\
    8 queue=default
  1. Preciso de ajuda com a Rb 750
    Por Jeffer no fórum Redes
    Último Post: 11-07-2011, 10:50
  2. Preciso de ajuda com RB 750
    Por profandre no fórum Redes
    Respostas: 36
    Último Post: 23-05-2011, 15:09
  3. Preciso de Ajuda com o Mikrotik
    Por upgradealpha no fórum Redes
    Respostas: 5
    Último Post: 16-10-2009, 06:04
  4. Preciso de ajuda com Load Balance no mikrotik
    Por JeanGutemberg no fórum Redes
    Respostas: 7
    Último Post: 13-11-2007, 18:40
  5. Preciso de ajuda com o Mikrotik
    Por Machinerlz no fórum Redes
    Último Post: 17-03-2007, 09:45
